root/radiance/ray/src/common/fvect.h
Wed Dec 15 01:38:50 2021 UTC (3 years, 4 months ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 2.22
refactor: removed prefix from SDdisk2square() and SDsquare2disk() & made consistent
Revision 2.22 - (view) (download) (annotate) - [selected]
Mon Dec 13 21:05:00 2021 UTC (3 years, 4 months ago) by greg
Changes since 2.21: +4 -2 lines
Diff to previous 2.21
refactor: moved SDdisk2square() and SDsquare2disk() declarations to fvect.h
Fri Jul 23 17:54:47 2021 UTC (3 years, 9 months ago) by greg
Diff to previous 2.20 , to selected 2.22
fix: repaired incorrect equality tests
Fri Apr 9 17:37:47 2021 UTC (4 years ago) by greg
Changes since 2.19: +4 -1 lines
Diff to previous 2.19 , to selected 2.22
feat: Added VLERP() macro to interpolate two points (position along 3-D line)
Fri Feb 12 00:41:18 2021 UTC (4 years, 2 months ago) by greg
Changes since 2.18: +9 -1 lines
Diff to previous 2.18 , to selected 2.22
refactor: Created comparison macros for RREAL and FVECT types
Thu May 21 05:54:54 2015 UTC (9 years, 11 months ago) by greg
CVS Tags: rad5R0, rad5R1, rad5R2, rad5R3
Diff to previous 2.17 , to selected 2.22
Thu Dec 4 05:26:27 2014 UTC (10 years, 5 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16 , to selected 2.22
Fri Apr 11 20:27:23 2014 UTC (11 years ago) by greg
Diff to previous 2.15 , to selected 2.22
Made reading of vectors more consistent with FVFORMAT macro
Sat Jun 29 21:03:44 2013 UTC (11 years, 10 months ago) by greg
Diff to previous 2.14 , to selected 2.22
Thu Sep 6 00:07:43 2012 UTC (12 years, 8 months ago) by greg
Changes since 2.13: +6 -3 lines
Diff to previous 2.13 , to selected 2.22
Fri Feb 18 00:40:25 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.12: +12 -10 lines
Diff to previous 2.12 , to selected 2.22
Tue Sep 16 06:30:20 2003 UTC (21 years, 7 months ago) by greg
Changes since 2.11: +3 -1 lines
Diff to previous 2.11 , to selected 2.22
Wrote closestapproach() function to find closest point for two rays
Fri Jun 27 06:53:21 2003 UTC (21 years, 10 months ago) by greg
Changes since 2.10: +1 -3 lines
Diff to previous 2.10 , to selected 2.22
Thu Jun 26 00:58:09 2003 UTC (21 years, 10 months ago) by schorsch
Diff to previous 2.9 , to selected 2.22
Fri Jun 6 16:38:47 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.8: +11 -7 lines
Diff to previous 2.8 , to selected 2.22
*** empty log message ***
Tue Feb 25 02:47:21 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 2.7 , to selected 2.22
Sat Feb 22 02:07:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.6: +76 -2 lines
Diff to previous 2.6 , to selected 2.22
Wed Aug 12 17:56:51 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 2.5: +12 -2 lines
Diff to previous 2.5 , to selected 2.22
added VSUB(), VADD() and VCROSS() macros
Wed Oct 22 14:15:47 1997 UTC (27 years, 6 months ago) by gregl
Diff to previous 2.4 , to selected 2.22
added VLEN(v) macro for vector magnitude
Fri Oct 2 15:54:57 1992 UTC (32 years, 7 months ago) by greg
Diff to previous 2.3 , to selected 2.22
Thu Jul 9 15:34:29 1992 UTC (32 years, 10 months ago) by greg
Diff to previous 2.2 , to selected 2.22
changed FTINY for SMLFLT
Fri Jan 17 13:27:49 1992 UTC (33 years, 3 months ago) by greg
Diff to previous 2.1 , to selected 2.22
increased value of FTINY with SMLFLT
Tue Nov 12 16:54:16 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.3 , to selected 2.22
Wed Oct 23 13:43:07 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.2: +4 -3 lines
Diff to previous 1.2 , to selected 2.22
Wed Oct 23 12:19:23 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.1: +12 -1 lines
Diff to previous 1.1 , to selected 2.22
added FLOAT definition for vectors and matrices
Thu Feb 2 10:34:16 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 2.22
