| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
| 5 |
* fvect.c - routines for floating-point vector calculations
| 6 |
| 7 |
| 8 |
| 9 |
* The Radiance Software License, Version 1.0
| 10 |
| 11 |
* Copyright (c) 1990 - 2002 The Regents of the University of California,
| 12 |
* through Lawrence Berkeley National Laboratory. All rights reserved.
| 13 |
| 14 |
* Redistribution and use in source and binary forms, with or without
| 15 |
* modification, are permitted provided that the following conditions
| 16 |
* are met:
| 17 |
| 18 |
* 1. Redistributions of source code must retain the above copyright
| 19 |
* notice, this list of conditions and the following disclaimer.
| 20 |
| 21 |
* 2. Redistributions in binary form must reproduce the above copyright
| 22 |
* notice, this list of conditions and the following disclaimer in
| 23 |
* the documentation and/or other materials provided with the
| 24 |
* distribution.
| 25 |
| 26 |
* 3. The end-user documentation included with the redistribution,
| 27 |
* if any, must include the following acknowledgment:
| 28 |
* "This product includes Radiance software
| 29 |
* (http://radsite.lbl.gov/)
| 30 |
* developed by the Lawrence Berkeley National Laboratory
| 31 |
* (http://www.lbl.gov/)."
| 32 |
* Alternately, this acknowledgment may appear in the software itself,
| 33 |
* if and wherever such third-party acknowledgments normally appear.
| 34 |
| 35 |
* 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
| 36 |
* and "The Regents of the University of California" must
| 37 |
* not be used to endorse or promote products derived from this
| 38 |
* software without prior written permission. For written
| 39 |
* permission, please contact [email protected].
| 40 |
| 41 |
* 5. Products derived from this software may not be called "Radiance",
| 42 |
* nor may "Radiance" appear in their name, without prior written
| 43 |
* permission of Lawrence Berkeley National Laboratory.
| 44 |
| 45 |
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
| 46 |
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
| 47 |
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
| 48 |
* DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
| 49 |
* ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
| 50 |
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
| 51 |
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
| 52 |
* USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
| 53 |
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
| 54 |
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
| 55 |
* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
| 56 |
* SUCH DAMAGE.
| 57 |
| 58 |
| 59 |
* This software consists of voluntary contributions made by many
| 60 |
* individuals on behalf of Lawrence Berkeley National Laboratory. For more
| 61 |
* information on Lawrence Berkeley National Laboratory, please see
| 62 |
* <http://www.lbl.gov/>.
| 63 |
| 64 |
| 65 |
#include <math.h>
| 66 |
#include "fvect.h"
| 67 |
| 68 |
| 69 |
double
| 70 |
fdot(v1, v2) /* return the dot product of two vectors */
| 71 |
register FVECT v1, v2;
| 72 |
| 73 |
return(DOT(v1,v2));
| 74 |
| 75 |
| 76 |
| 77 |
double
| 78 |
dist2(p1, p2) /* return square of distance between points */
| 79 |
register FVECT p1, p2;
| 80 |
| 81 |
FVECT delta;
| 82 |
| 83 |
delta[0] = p2[0] - p1[0];
| 84 |
delta[1] = p2[1] - p1[1];
| 85 |
delta[2] = p2[2] - p1[2];
| 86 |
| 87 |
return(DOT(delta, delta));
| 88 |
| 89 |
| 90 |
| 91 |
double
| 92 |
dist2line(p, ep1, ep2) /* return square of distance to line */
| 93 |
FVECT p; /* the point */
| 94 |
FVECT ep1, ep2; /* points on the line */
| 95 |
| 96 |
register double d, d1, d2;
| 97 |
| 98 |
d = dist2(ep1, ep2);
| 99 |
d1 = dist2(ep1, p);
| 100 |
d2 = d + d1 - dist2(ep2, p);
| 101 |
| 102 |
return(d1 - 0.25*d2*d2/d);
| 103 |
| 104 |
| 105 |
| 106 |
double
| 107 |
dist2lseg(p, ep1, ep2) /* return square of distance to line segment */
| 108 |
| 109 |
FVECT ep1, ep2; /* the end points */
| 110 |
| 111 |
| 112 |
| 113 |
| 114 |
d1 = dist2(ep1, p);
| 115 |
d2 = dist2(ep2, p);
| 116 |
| 117 |
if (d2 > d1) { /* check if past endpoints */
| 118 |
if (d2 - d1 > d)
| 119 |
return(d1);
| 120 |
} else {
| 121 |
if (d1 - d2 > d)
| 122 |
return(d2);
| 123 |
| 124 |
d2 = d + d1 - d2;
| 125 |
| 126 |
return(d1 - 0.25*d2*d2/d); /* distance to line */
| 127 |
| 128 |
| 129 |
| 130 |
void
| 131 |
fcross(vres, v1, v2) /* vres = v1 X v2 */
| 132 |
register FVECT vres, v1, v2;
| 133 |
| 134 |
vres[0] = v1[1]*v2[2] - v1[2]*v2[1];
| 135 |
vres[1] = v1[2]*v2[0] - v1[0]*v2[2];
| 136 |
vres[2] = v1[0]*v2[1] - v1[1]*v2[0];
| 137 |
| 138 |
| 139 |
| 140 |
void
| 141 |
fvsum(vres, v0, v1, f) /* vres = v0 + f*v1 */
| 142 |
register FVECT vres, v0, v1;
| 143 |
register double f;
| 144 |
| 145 |
vres[0] = v0[0] + f*v1[0];
| 146 |
vres[1] = v0[1] + f*v1[1];
| 147 |
vres[2] = v0[2] + f*v1[2];
| 148 |
| 149 |
| 150 |
| 151 |
double
| 152 |
normalize(v) /* normalize a vector, return old magnitude */
| 153 |
register FVECT v;
| 154 |
| 155 |
register double len, d;
| 156 |
| 157 |
d = DOT(v, v);
| 158 |
| 159 |
if (d <= 0.0)
| 160 |
return(0.0);
| 161 |
| 162 |
if (d <= 1.0+FTINY && d >= 1.0-FTINY)
| 163 |
len = 0.5 + 0.5*d; /* first order approximation */
| 164 |
else
| 165 |
len = sqrt(d);
| 166 |
| 167 |
v[0] *= d = 1.0/len;
| 168 |
v[1] *= d;
| 169 |
v[2] *= d;
| 170 |
| 171 |
return(len);
| 172 |
| 173 |
| 174 |
| 175 |
void
| 176 |
spinvector(vres, vorig, vnorm, theta) /* rotate vector around normal */
| 177 |
FVECT vres, vorig, vnorm;
| 178 |
double theta;
| 179 |
| 180 |
double sint, cost, normprod;
| 181 |
FVECT vperp;
| 182 |
register int i;
| 183 |
| 184 |
if (theta == 0.0) {
| 185 |
if (vres != vorig)
| 186 |
VCOPY(vres, vorig);
| 187 |
return;
| 188 |
| 189 |
cost = cos(theta);
| 190 |
sint = sin(theta);
| 191 |
normprod = DOT(vorig, vnorm)*(1.-cost);
| 192 |
fcross(vperp, vnorm, vorig);
| 193 |
for (i = 0; i < 3; i++)
| 194 |
vres[i] = vorig[i]*cost + vnorm[i]*normprod + vperp[i]*sint;
| 195 |
