1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* fvect.c - routines for float vector calculations |
9 |
10 |
* 8/14/85 |
11 |
12 |
13 |
#include <math.h> |
14 |
#include "fvect.h" |
15 |
16 |
17 |
double |
18 |
fdot(v1, v2) /* return the dot product of two vectors */ |
19 |
register FVECT v1, v2; |
20 |
21 |
return(DOT(v1,v2)); |
22 |
23 |
24 |
25 |
double |
26 |
dist2(p1, p2) /* return square of distance between points */ |
27 |
register FVECT p1, p2; |
28 |
29 |
FVECT delta; |
30 |
31 |
delta[0] = p2[0] - p1[0]; |
32 |
delta[1] = p2[1] - p1[1]; |
33 |
delta[2] = p2[2] - p1[2]; |
34 |
return(DOT(delta, delta)); |
35 |
36 |
37 |
38 |
double |
39 |
dist2line(p, ep1, ep2) /* return square of distance to line */ |
40 |
FVECT p; /* the point */ |
41 |
FVECT ep1, ep2; /* points on the line */ |
42 |
43 |
register double d, d1, d2; |
44 |
45 |
d = dist2(ep1, ep2); |
46 |
d1 = dist2(ep1, p); |
47 |
d2 = dist2(ep2, p); |
48 |
49 |
return(d1 - (d+d1-d2)*(d+d1-d2)/d/4); |
50 |
51 |
52 |
53 |
double |
54 |
dist2lseg(p, ep1, ep2) /* return square of distance to line segment */ |
55 |
56 |
FVECT ep1, ep2; /* the end points */ |
57 |
58 |
59 |
60 |
61 |
62 |
63 |
64 |
if (d2 > d1) { /* check if past endpoints */ |
65 |
if (d2 - d1 > d) |
66 |
return(d1); |
67 |
} else { |
68 |
if (d1 - d2 > d) |
69 |
return(d2); |
70 |
71 |
72 |
return(d1 - (d+d1-d2)*(d+d1-d2)/d/4); /* distance to line */ |
73 |
74 |
75 |
76 |
fcross(vres, v1, v2) /* vres = v1 X v2 */ |
77 |
register FVECT vres, v1, v2; |
78 |
79 |
vres[0] = v1[1]*v2[2] - v1[2]*v2[1]; |
80 |
vres[1] = v1[2]*v2[0] - v1[0]*v2[2]; |
81 |
vres[2] = v1[0]*v2[1] - v1[1]*v2[0]; |
82 |
83 |
84 |
85 |
fvsum(vres, v0, v1, f) /* vres = v0 + f*v1 */ |
86 |
FVECT vres, v0, v1; |
87 |
double f; |
88 |
89 |
vres[0] = v0[0] + f*v1[0]; |
90 |
vres[1] = v0[1] + f*v1[1]; |
91 |
vres[2] = v0[2] + f*v1[2]; |
92 |
93 |
94 |
95 |
double |
96 |
normalize(v) /* normalize a vector, return old magnitude */ |
97 |
register FVECT v; |
98 |
99 |
register double len; |
100 |
101 |
len = DOT(v, v); |
102 |
103 |
if (len <= 0.0) |
104 |
return(0.0); |
105 |
106 |
if (len <= 1.0+FTINY && len >= 1.0-FTINY) |
107 |
len = 0.5 + 0.5*len; /* first order approximation */ |
108 |
else |
109 |
len = sqrt(len); |
110 |
111 |
v[0] /= len; |
112 |
v[1] /= len; |
113 |
v[2] /= len; |
114 |
115 |
return(len); |
116 |
117 |
118 |
119 |
spinvector(vres, vorig, vnorm, theta) /* rotate vector around normal */ |
120 |
FVECT vres, vorig, vnorm; |
121 |
double theta; |
122 |
123 |
double sint, cost, normprod; |
124 |
FVECT vperp; |
125 |
register int i; |
126 |
127 |
if (theta == 0.0) { |
128 |
if (vres != vorig) |
129 |
VCOPY(vres, vorig); |
130 |
return; |
131 |
132 |
cost = cos(theta); |
133 |
sint = sin(theta); |
134 |
normprod = DOT(vorig, vnorm)*(1.-cost); |
135 |
fcross(vperp, vnorm, vorig); |
136 |
for (i = 0; i < 3; i++) |
137 |
vres[i] = vorig[i]*cost + vnorm[i]*normprod + vperp[i]*sint; |
138 |
