| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: fvect.c,v 2.9 2005/03/23 01:54:55 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* fvect.c - routines for floating-point vector calculations
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <math.h>
| 11 |
#include "fvect.h"
| 12 |
| 13 |
| 14 |
double
| 15 |
fdot( /* return the dot product of two vectors */
| 16 |
register FVECT v1,
| 17 |
register FVECT v2
| 18 |
| 19 |
| 20 |
return(DOT(v1,v2));
| 21 |
| 22 |
| 23 |
| 24 |
double
| 25 |
dist2( /* return square of distance between points */
| 26 |
register FVECT p1,
| 27 |
register FVECT p2
| 28 |
| 29 |
| 30 |
FVECT delta;
| 31 |
| 32 |
delta[0] = p2[0] - p1[0];
| 33 |
delta[1] = p2[1] - p1[1];
| 34 |
delta[2] = p2[2] - p1[2];
| 35 |
| 36 |
return(DOT(delta, delta));
| 37 |
| 38 |
| 39 |
| 40 |
double
| 41 |
dist2line( /* return square of distance to line */
| 42 |
FVECT p, /* the point */
| 43 |
FVECT ep1,
| 44 |
FVECT ep2 /* points on the line */
| 45 |
| 46 |
| 47 |
register double d, d1, d2;
| 48 |
| 49 |
d = dist2(ep1, ep2);
| 50 |
d1 = dist2(ep1, p);
| 51 |
d2 = d + d1 - dist2(ep2, p);
| 52 |
| 53 |
return(d1 - 0.25*d2*d2/d);
| 54 |
| 55 |
| 56 |
| 57 |
double
| 58 |
dist2lseg( /* return square of distance to line segment */
| 59 |
| 60 |
FVECT ep1,
| 61 |
FVECT ep2 /* the end points */
| 62 |
| 63 |
| 64 |
| 65 |
| 66 |
| 67 |
d1 = dist2(ep1, p);
| 68 |
d2 = dist2(ep2, p);
| 69 |
| 70 |
if (d2 > d1) { /* check if past endpoints */
| 71 |
if (d2 - d1 > d)
| 72 |
return(d1);
| 73 |
} else {
| 74 |
if (d1 - d2 > d)
| 75 |
return(d2);
| 76 |
| 77 |
d2 = d + d1 - d2;
| 78 |
| 79 |
return(d1 - 0.25*d2*d2/d); /* distance to line */
| 80 |
| 81 |
| 82 |
| 83 |
void
| 84 |
fcross( /* vres = v1 X v2 */
| 85 |
register FVECT vres,
| 86 |
register FVECT v1,
| 87 |
register FVECT v2
| 88 |
| 89 |
| 90 |
vres[0] = v1[1]*v2[2] - v1[2]*v2[1];
| 91 |
vres[1] = v1[2]*v2[0] - v1[0]*v2[2];
| 92 |
vres[2] = v1[0]*v2[1] - v1[1]*v2[0];
| 93 |
| 94 |
| 95 |
| 96 |
void
| 97 |
fvsum( /* vres = v0 + f*v1 */
| 98 |
| 99 |
register FVECT v0,
| 100 |
register FVECT v1,
| 101 |
register double f
| 102 |
| 103 |
| 104 |
vres[0] = v0[0] + f*v1[0];
| 105 |
vres[1] = v0[1] + f*v1[1];
| 106 |
vres[2] = v0[2] + f*v1[2];
| 107 |
| 108 |
| 109 |
| 110 |
double
| 111 |
normalize( /* normalize a vector, return old magnitude */
| 112 |
register FVECT v
| 113 |
| 114 |
| 115 |
register double len, d;
| 116 |
| 117 |
d = DOT(v, v);
| 118 |
| 119 |
if (d == 0.0)
| 120 |
return(0.0);
| 121 |
| 122 |
if (d <= 1.0+FTINY && d >= 1.0-FTINY)
| 123 |
len = 0.5 + 0.5*d; /* first order approximation */
| 124 |
else
| 125 |
len = sqrt(d);
| 126 |
| 127 |
v[0] *= d = 1.0/len;
| 128 |
v[1] *= d;
| 129 |
v[2] *= d;
| 130 |
| 131 |
return(len);
| 132 |
| 133 |
| 134 |
| 135 |
int
| 136 |
closestapproach( /* closest approach of two rays */
| 137 |
RREAL t[2], /* returned distances along each ray */
| 138 |
FVECT rorg0, /* first origin */
| 139 |
FVECT rdir0, /* first direction (normalized) */
| 140 |
FVECT rorg1, /* second origin */
| 141 |
FVECT rdir1 /* second direction (normalized) */
| 142 |
| 143 |
| 144 |
double dotprod = DOT(rdir0, rdir1);
| 145 |
double denom = 1. - dotprod*dotprod;
| 146 |
double o1o2_d1;
| 147 |
FVECT o0o1;
| 148 |
| 149 |
if (denom <= FTINY) { /* check if lines are parallel */
| 150 |
t[0] = t[1] = 0.0;
| 151 |
return(0);
| 152 |
| 153 |
VSUB(o0o1, rorg0, rorg1);
| 154 |
o1o2_d1 = DOT(o0o1, rdir1);
| 155 |
t[0] = (o1o2_d1*dotprod - DOT(o0o1,rdir0)) / denom;
| 156 |
t[1] = o1o2_d1 + t[0]*dotprod;
| 157 |
return(1);
| 158 |
| 159 |
| 160 |
| 161 |
#if 0
| 162 |
int
| 163 |
| 164 |
| 165 |
| 166 |
FVECT rdir0, /* first direction (unnormalized) */
| 167 |
| 168 |
FVECT rdir1 /* second direction (unnormalized) */
| 169 |
| 170 |
| 171 |
| 172 |
double d0n2 = DOT(rdir0, rdir0);
| 173 |
double d1n2 = DOT(rdir1, rdir1);
| 174 |
double denom = d0n2*d1n2 - dotprod*dotprod;
| 175 |
double o1o2_d1;
| 176 |
FVECT o0o1;
| 177 |
| 178 |
| 179 |
t[0] = t[1] = 0.0;
| 180 |
return(0);
| 181 |
| 182 |
| 183 |
| 184 |
t[0] = (o1o2_d1*dotprod - DOT(o0o1,rdir0)*d1n2) / denom;
| 185 |
t[1] = (o1o2_d1 + t[0]*dotprod) / d1n2;
| 186 |
return(1);
| 187 |
| 188 |
#endif
| 189 |
| 190 |
| 191 |
void
| 192 |
spinvector( /* rotate vector around normal */
| 193 |
FVECT vres, /* returned vector */
| 194 |
FVECT vorig, /* original vector */
| 195 |
FVECT vnorm, /* normalized vector for rotation */
| 196 |
double theta /* left-hand radians */
| 197 |
| 198 |
| 199 |
double sint, cost, normprod;
| 200 |
FVECT vperp;
| 201 |
register int i;
| 202 |
| 203 |
if (theta == 0.0) {
| 204 |
if (vres != vorig)
| 205 |
VCOPY(vres, vorig);
| 206 |
return;
| 207 |
| 208 |
cost = cos(theta);
| 209 |
sint = sin(theta);
| 210 |
normprod = DOT(vorig, vnorm)*(1.-cost);
| 211 |
fcross(vperp, vnorm, vorig);
| 212 |
for (i = 0; i < 3; i++)
| 213 |
vres[i] = vorig[i]*cost + vnorm[i]*normprod + vperp[i]*sint;
| 214 |
