1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* fvect.c - routines for float vector calculations |
9 |
10 |
* 8/14/85 |
11 |
12 |
13 |
#include "fvect.h" |
14 |
15 |
#define FTINY 1e-7 |
16 |
17 |
18 |
double |
19 |
fdot(v1, v2) /* return the dot product of two vectors */ |
20 |
register FVECT v1, v2; |
21 |
22 |
return(DOT(v1,v2)); |
23 |
24 |
25 |
26 |
double |
27 |
dist2(p1, p2) /* return square of distance between points */ |
28 |
register FVECT p1, p2; |
29 |
30 |
static FVECT delta; |
31 |
32 |
delta[0] = p2[0] - p1[0]; |
33 |
delta[1] = p2[1] - p1[1]; |
34 |
delta[2] = p2[2] - p1[2]; |
35 |
return(DOT(delta, delta)); |
36 |
37 |
38 |
39 |
double |
40 |
dist2line(p, ep1, ep2) /* return square of distance to line */ |
41 |
FVECT p; /* the point */ |
42 |
FVECT ep1, ep2; /* points on the line */ |
43 |
44 |
static double d, d1, d2; |
45 |
46 |
d = dist2(ep1, ep2); |
47 |
d1 = dist2(ep1, p); |
48 |
d2 = dist2(ep2, p); |
49 |
50 |
return(d1 - (d+d1-d2)*(d+d1-d2)/d/4); |
51 |
52 |
53 |
54 |
double |
55 |
dist2lseg(p, ep1, ep2) /* return square of distance to line segment */ |
56 |
57 |
FVECT ep1, ep2; /* the end points */ |
58 |
59 |
60 |
61 |
62 |
63 |
64 |
65 |
if (d2 > d1) { /* check if past endpoints */ |
66 |
if (d2 - d1 > d) |
67 |
return(d1); |
68 |
} else { |
69 |
if (d1 - d2 > d) |
70 |
return(d2); |
71 |
72 |
73 |
return(d1 - (d+d1-d2)*(d+d1-d2)/d/4); /* distance to line */ |
74 |
75 |
76 |
77 |
fcross(vres, v1, v2) /* vres = v1 X v2 */ |
78 |
register FVECT vres, v1, v2; |
79 |
80 |
vres[0] = v1[1]*v2[2] - v1[2]*v2[1]; |
81 |
vres[1] = v1[2]*v2[0] - v1[0]*v2[2]; |
82 |
vres[2] = v1[0]*v2[1] - v1[1]*v2[0]; |
83 |
84 |
85 |
86 |
double |
87 |
normalize(v) /* normalize a vector, return old magnitude */ |
88 |
register FVECT v; |
89 |
90 |
static double len; |
91 |
92 |
len = DOT(v, v); |
93 |
94 |
if (len <= FTINY*FTINY) |
95 |
return(0.0); |
96 |
97 |
/****** problematic |
98 |
if (len >= (1.0-FTINY)*(1.0-FTINY) && |
99 |
len <= (1.0+FTINY)*(1.0+FTINY)) |
100 |
return(1.0); |
101 |
102 |
103 |
len = sqrt(len); |
104 |
v[0] /= len; |
105 |
v[1] /= len; |
106 |
v[2] /= len; |
107 |
return(len); |
108 |
