--- ray/src/common/fvect.c 2003/02/25 02:47:21 2.7 +++ ray/src/common/fvect.c 2003/09/16 06:30:20 2.8 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: fvect.c,v 2.7 2003/02/25 02:47:21 greg Exp $"; +static const char RCSid[] = "$Id: fvect.c,v 2.8 2003/09/16 06:30:20 greg Exp $"; #endif /* * fvect.c - routines for floating-point vector calculations @@ -12,16 +12,20 @@ static const char RCSid[] = "$Id: fvect.c,v 2.7 2003/0 double -fdot(v1, v2) /* return the dot product of two vectors */ -register FVECT v1, v2; +fdot( /* return the dot product of two vectors */ +register FVECT v1, +register FVECT v2 +) { return(DOT(v1,v2)); } double -dist2(p1, p2) /* return square of distance between points */ -register FVECT p1, p2; +dist2( /* return square of distance between points */ +register FVECT p1, +register FVECT p2 +) { FVECT delta; @@ -34,9 +38,11 @@ register FVECT p1, p2; double -dist2line(p, ep1, ep2) /* return square of distance to line */ -FVECT p; /* the point */ -FVECT ep1, ep2; /* points on the line */ +dist2line( /* return square of distance to line */ +FVECT p, /* the point */ +FVECT ep1, +FVECT ep2 /* points on the line */ +) { register double d, d1, d2; @@ -49,9 +55,11 @@ FVECT ep1, ep2; /* points on the line */ double -dist2lseg(p, ep1, ep2) /* return square of distance to line segment */ -FVECT p; /* the point */ -FVECT ep1, ep2; /* the end points */ +dist2lseg( /* return square of distance to line segment */ +FVECT p, /* the point */ +FVECT ep1, +FVECT ep2 /* the end points */ +) { register double d, d1, d2; @@ -73,8 +81,11 @@ FVECT ep1, ep2; /* the end points */ void -fcross(vres, v1, v2) /* vres = v1 X v2 */ -register FVECT vres, v1, v2; +fcross( /* vres = v1 X v2 */ +register FVECT vres, +register FVECT v1, +register FVECT v2 +) { vres[0] = v1[1]*v2[2] - v1[2]*v2[1]; vres[1] = v1[2]*v2[0] - v1[0]*v2[2]; @@ -83,9 +94,12 @@ register FVECT vres, v1, v2; void -fvsum(vres, v0, v1, f) /* vres = v0 + f*v1 */ -register FVECT vres, v0, v1; -register double f; +fvsum( /* vres = v0 + f*v1 */ +register FVECT vres, +register FVECT v0, +register FVECT v1, +register double f +) { vres[0] = v0[0] + f*v1[0]; vres[1] = v0[1] + f*v1[1]; @@ -94,8 +108,9 @@ register double f; double -normalize(v) /* normalize a vector, return old magnitude */ -register FVECT v; +normalize( /* normalize a vector, return old magnitude */ +register FVECT v +) { register double len, d; @@ -117,10 +132,69 @@ register FVECT v; } +int +closestapproach( /* closest approach of two rays */ +RREAL t[2], /* returned distances along each ray */ +FVECT rorg0, /* first origin */ +FVECT rdir0, /* first direction (normalized) */ +FVECT rorg1, /* second origin */ +FVECT rdir1 /* second direction (normalized) */ +) +{ + double dotprod = DOT(rdir0, rdir1); + double denom = 1. - dotprod*dotprod; + double o1o2_d1; + FVECT o0o1; + + if (denom <= FTINY) { /* check if lines are parallel */ + t[0] = t[1] = 0.0; + return(0); + } + VSUB(o0o1, rorg0, rorg1); + o1o2_d1 = DOT(o0o1, rdir1); + t[0] = (o1o2_d1*dotprod - DOT(o0o1,rdir0)) / denom; + t[1] = o1o2_d1 + t[0]*dotprod; + return(1); +} + + +#if 0 +int +closestapproach( /* closest approach of two rays */ +RREAL t[2], /* returned distances along each ray */ +FVECT rorg0, /* first origin */ +FVECT rdir0, /* first direction (unnormalized) */ +FVECT rorg1, /* second origin */ +FVECT rdir1 /* second direction (unnormalized) */ +) +{ + double dotprod = DOT(rdir0, rdir1); + double d0n2 = DOT(rdir0, rdir0); + double d1n2 = DOT(rdir1, rdir1); + double denom = d0n2*d1n2 - dotprod*dotprod; + double o1o2_d1; + FVECT o0o1; + + if (denom <= FTINY) { /* check if lines are parallel */ + t[0] = t[1] = 0.0; + return(0); + } + VSUB(o0o1, rorg0, rorg1); + o1o2_d1 = DOT(o0o1, rdir1); + t[0] = (o1o2_d1*dotprod - DOT(o0o1,rdir0)*d1n2) / denom; + t[1] = (o1o2_d1 + t[0]*dotprod) / d1n2; + return(1); +} +#endif + + void -spinvector(vres, vorig, vnorm, theta) /* rotate vector around normal */ -FVECT vres, vorig, vnorm; -double theta; +spinvector( /* rotate vector around normal */ +FVECT vres, /* returned vector */ +FVECT vorig, /* original vector */ +FVECT vnorm, /* normalized vector for rotation */ +double theta /* left-hand radians */ +) { double sint, cost, normprod; FVECT vperp;
