root/radiance/ray/src/common/fvect.c
Revision: 2.1
Committed: Tue Nov 12 16:55:09 1991 UTC (33 years, 9 months ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * fvect.c - routines for float vector calculations
9 *
10 * 8/14/85
11 */
12
13 #include "fvect.h"
14
15
16 double
17 fdot(v1, v2) /* return the dot product of two vectors */
18 register FVECT v1, v2;
19 {
20 return(DOT(v1,v2));
21 }
22
23
24 double
25 dist2(p1, p2) /* return square of distance between points */
26 register FVECT p1, p2;
27 {
28 static FVECT delta;
29
30 delta[0] = p2[0] - p1[0];
31 delta[1] = p2[1] - p1[1];
32 delta[2] = p2[2] - p1[2];
33 return(DOT(delta, delta));
34 }
35
36
37 double
38 dist2line(p, ep1, ep2) /* return square of distance to line */
39 FVECT p; /* the point */
40 FVECT ep1, ep2; /* points on the line */
41 {
42 static double d, d1, d2;
43
44 d = dist2(ep1, ep2);
45 d1 = dist2(ep1, p);
46 d2 = dist2(ep2, p);
47
48 return(d1 - (d+d1-d2)*(d+d1-d2)/d/4);
49 }
50
51
52 double
53 dist2lseg(p, ep1, ep2) /* return square of distance to line segment */
54 FVECT p; /* the point */
55 FVECT ep1, ep2; /* the end points */
56 {
57 static double d, d1, d2;
58
59 d = dist2(ep1, ep2);
60 d1 = dist2(ep1, p);
61 d2 = dist2(ep2, p);
62
63 if (d2 > d1) { /* check if past endpoints */
64 if (d2 - d1 > d)
65 return(d1);
66 } else {
67 if (d1 - d2 > d)
68 return(d2);
69 }
70
71 return(d1 - (d+d1-d2)*(d+d1-d2)/d/4); /* distance to line */
72 }
73
74
75 fcross(vres, v1, v2) /* vres = v1 X v2 */
76 register FVECT vres, v1, v2;
77 {
78 vres[0] = v1[1]*v2[2] - v1[2]*v2[1];
79 vres[1] = v1[2]*v2[0] - v1[0]*v2[2];
80 vres[2] = v1[0]*v2[1] - v1[1]*v2[0];
81 }
82
83
84 fvsum(vres, v0, v1, f) /* vres = v0 + f*v1 */
85 FVECT vres, v0, v1;
86 double f;
87 {
88 vres[0] = v0[0] + f*v1[0];
89 vres[1] = v0[1] + f*v1[1];
90 vres[2] = v0[2] + f*v1[2];
91 }
92
93
94 double
95 normalize(v) /* normalize a vector, return old magnitude */
96 register FVECT v;
97 {
98 static double len;
99
100 len = DOT(v, v);
101
102 if (len <= 0.0)
103 return(0.0);
104
105 /****** problematic
106 if (len >= (1.0-FTINY)*(1.0-FTINY) &&
107 len <= (1.0+FTINY)*(1.0+FTINY))
108 return(1.0);
109 ******/
110
111 len = sqrt(len);
112 v[0] /= len;
113 v[1] /= len;
114 v[2] /= len;
115 return(len);
116 }
117
118
119 spinvector(vres, vorig, vnorm, theta) /* rotate vector around normal */
120 FVECT vres, vorig, vnorm;
121 double theta;
122 {
123 extern double cos(), sin();
124 double sint, cost, normprod;
125 FVECT vperp;
126 register int i;
127
128 if (theta == 0.0) {
129 if (vres != vorig)
130 VCOPY(vres, vorig);
131 return;
132 }
133 cost = cos(theta);
134 sint = sin(theta);
135 normprod = DOT(vorig, vnorm)*(1.-cost);
136 fcross(vperp, vnorm, vorig);
137 for (i = 0; i < 3; i++)
138 vres[i] = vorig[i]*cost + vnorm[i]*normprod + vperp[i]*sint;
139 }
