--- ray/src/common/fvect.c 2011/04/19 21:31:22 2.14 +++ ray/src/common/fvect.c 2012/11/08 00:31:17 2.16 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: fvect.c,v 2.14 2011/04/19 21:31:22 greg Exp $"; +static const char RCSid[] = "$Id: fvect.c,v 2.16 2012/11/08 00:31:17 greg Exp $"; #endif /* * fvect.c - routines for floating-point vector calculations @@ -119,7 +119,7 @@ FVECT v if (d == 0.0) return(0.0); - if (d <= 1.0+FTINY && d >= 1.0-FTINY) { + if ((d <= 1.0+FTINY) & (d >= 1.0-FTINY)) { len = 0.5 + 0.5*d; /* first order approximation */ d = 2.0 - len; } else { @@ -162,7 +162,7 @@ const FVECT rdir1 /* second direction (normalized) */ void spinvector( /* rotate vector around normal */ -FVECT vres, /* returned vector */ +FVECT vres, /* returned vector (same magnitude as vorig) */ const FVECT vorig, /* original vector */ const FVECT vnorm, /* normalized vector for rotation */ double theta /* right-hand radians */ @@ -183,4 +183,49 @@ double theta /* right-hand radians */ fcross(vperp, vnorm, vorig); for (i = 0; i < 3; i++) vres[i] = vorig[i]*cost + vnorm[i]*normprod + vperp[i]*sint; +} + +double +geodesic( /* rotate vector on great circle towards target */ +FVECT vres, /* returned vector (same magnitude as vorig) */ +const FVECT vorig, /* original vector */ +const FVECT vtarg, /* vector we are rotating towards */ +double t, /* amount along arc directed towards vtarg */ +int meas /* distance measure (radians, absolute, relative) */ +) +{ + FVECT normtarg; + double volen, dotprod, sint, cost; + int i; + + VCOPY(normtarg, vtarg); /* in case vtarg==vres */ + if (vres != vorig) + VCOPY(vres, vorig); + if (t == 0.0) + return(VLEN(vres)); /* no rotation requested */ + if ((volen = normalize(vres)) == 0.0) + return(0.0); + if (normalize(normtarg) == 0.0) + return(0.0); /* target vector is zero */ + dotprod = DOT(vres, normtarg); + /* check for colinear */ + if (dotprod >= 1.0-FTINY*FTINY) { + if (meas != GEOD_REL) + return(0.0); + vres[0] *= volen; vres[1] *= volen; vres[2] *= volen; + return(volen); + } + if (dotprod <= -1.0+FTINY*FTINY) + return(0.0); + if (meas == GEOD_ABS) + t /= volen; + else if (meas == GEOD_REL) + t *= acos(dotprod); + cost = cos(t); + sint = sin(t); + for (i = 0; i < 3; i++) + vres[i] = volen*( cost*vres[i] + + sint*(normtarg[i] - dotprod*vres[i]) ); + + return(volen); /* return vector length */ }
