1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: fvect.c,v 2.8 2003/09/16 06:30:20 greg Exp $"; |
3 |
#endif |
4 |
5 |
* fvect.c - routines for floating-point vector calculations |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <math.h> |
11 |
#include "fvect.h" |
12 |
13 |
14 |
double |
15 |
fdot( /* return the dot product of two vectors */ |
16 |
register FVECT v1, |
17 |
register FVECT v2 |
18 |
19 |
20 |
return(DOT(v1,v2)); |
21 |
22 |
23 |
24 |
double |
25 |
dist2( /* return square of distance between points */ |
26 |
register FVECT p1, |
27 |
register FVECT p2 |
28 |
29 |
30 |
FVECT delta; |
31 |
32 |
delta[0] = p2[0] - p1[0]; |
33 |
delta[1] = p2[1] - p1[1]; |
34 |
delta[2] = p2[2] - p1[2]; |
35 |
36 |
return(DOT(delta, delta)); |
37 |
38 |
39 |
40 |
double |
41 |
dist2line( /* return square of distance to line */ |
42 |
FVECT p, /* the point */ |
43 |
FVECT ep1, |
44 |
FVECT ep2 /* points on the line */ |
45 |
46 |
47 |
register double d, d1, d2; |
48 |
49 |
d = dist2(ep1, ep2); |
50 |
d1 = dist2(ep1, p); |
51 |
d2 = d + d1 - dist2(ep2, p); |
52 |
53 |
return(d1 - 0.25*d2*d2/d); |
54 |
55 |
56 |
57 |
double |
58 |
dist2lseg( /* return square of distance to line segment */ |
59 |
60 |
FVECT ep1, |
61 |
FVECT ep2 /* the end points */ |
62 |
63 |
64 |
65 |
66 |
67 |
68 |
d2 = dist2(ep2, p); |
69 |
70 |
if (d2 > d1) { /* check if past endpoints */ |
71 |
if (d2 - d1 > d) |
72 |
return(d1); |
73 |
} else { |
74 |
if (d1 - d2 > d) |
75 |
return(d2); |
76 |
77 |
d2 = d + d1 - d2; |
78 |
79 |
return(d1 - 0.25*d2*d2/d); /* distance to line */ |
80 |
81 |
82 |
83 |
void |
84 |
fcross( /* vres = v1 X v2 */ |
85 |
register FVECT vres, |
86 |
87 |
register FVECT v2 |
88 |
89 |
90 |
vres[0] = v1[1]*v2[2] - v1[2]*v2[1]; |
91 |
vres[1] = v1[2]*v2[0] - v1[0]*v2[2]; |
92 |
vres[2] = v1[0]*v2[1] - v1[1]*v2[0]; |
93 |
94 |
95 |
96 |
void |
97 |
fvsum( /* vres = v0 + f*v1 */ |
98 |
99 |
register FVECT v0, |
100 |
101 |
register double f |
102 |
103 |
104 |
vres[0] = v0[0] + f*v1[0]; |
105 |
vres[1] = v0[1] + f*v1[1]; |
106 |
vres[2] = v0[2] + f*v1[2]; |
107 |
108 |
109 |
110 |
double |
111 |
normalize( /* normalize a vector, return old magnitude */ |
112 |
register FVECT v |
113 |
114 |
115 |
register double len, d; |
116 |
117 |
d = DOT(v, v); |
118 |
119 |
if (d <= FTINY*FTINY) |
120 |
return(0.0); |
121 |
122 |
if (d <= 1.0+FTINY && d >= 1.0-FTINY) |
123 |
len = 0.5 + 0.5*d; /* first order approximation */ |
124 |
else |
125 |
len = sqrt(d); |
126 |
127 |
v[0] *= d = 1.0/len; |
128 |
v[1] *= d; |
129 |
v[2] *= d; |
130 |
131 |
return(len); |
132 |
133 |
134 |
135 |
int |
136 |
closestapproach( /* closest approach of two rays */ |
137 |
RREAL t[2], /* returned distances along each ray */ |
138 |
FVECT rorg0, /* first origin */ |
139 |
FVECT rdir0, /* first direction (normalized) */ |
140 |
FVECT rorg1, /* second origin */ |
141 |
FVECT rdir1 /* second direction (normalized) */ |
142 |
143 |
144 |
double dotprod = DOT(rdir0, rdir1); |
145 |
double denom = 1. - dotprod*dotprod; |
146 |
double o1o2_d1; |
147 |
FVECT o0o1; |
148 |
149 |
if (denom <= FTINY) { /* check if lines are parallel */ |
150 |
t[0] = t[1] = 0.0; |
151 |
return(0); |
152 |
153 |
VSUB(o0o1, rorg0, rorg1); |
154 |
o1o2_d1 = DOT(o0o1, rdir1); |
155 |
t[0] = (o1o2_d1*dotprod - DOT(o0o1,rdir0)) / denom; |
156 |
t[1] = o1o2_d1 + t[0]*dotprod; |
157 |
return(1); |
158 |
159 |
160 |
161 |
#if 0 |
162 |
int |
163 |
164 |
165 |
166 |
FVECT rdir0, /* first direction (unnormalized) */ |
167 |
168 |
FVECT rdir1 /* second direction (unnormalized) */ |
169 |
170 |
171 |
172 |
double d0n2 = DOT(rdir0, rdir0); |
173 |
double d1n2 = DOT(rdir1, rdir1); |
174 |
double denom = d0n2*d1n2 - dotprod*dotprod; |
175 |
double o1o2_d1; |
176 |
FVECT o0o1; |
177 |
178 |
179 |
180 |
return(0); |
181 |
182 |
183 |
184 |
t[0] = (o1o2_d1*dotprod - DOT(o0o1,rdir0)*d1n2) / denom; |
185 |
t[1] = (o1o2_d1 + t[0]*dotprod) / d1n2; |
186 |
return(1); |
187 |
188 |
#endif |
189 |
190 |
191 |
void |
192 |
spinvector( /* rotate vector around normal */ |
193 |
FVECT vres, /* returned vector */ |
194 |
FVECT vorig, /* original vector */ |
195 |
FVECT vnorm, /* normalized vector for rotation */ |
196 |
double theta /* left-hand radians */ |
197 |
198 |
199 |
double sint, cost, normprod; |
200 |
FVECT vperp; |
201 |
register int i; |
202 |
203 |
if (theta == 0.0) { |
204 |
if (vres != vorig) |
205 |
VCOPY(vres, vorig); |
206 |
return; |
207 |
208 |
cost = cos(theta); |
209 |
sint = sin(theta); |
210 |
normprod = DOT(vorig, vnorm)*(1.-cost); |
211 |
fcross(vperp, vnorm, vorig); |
212 |
for (i = 0; i < 3; i++) |
213 |
vres[i] = vorig[i]*cost + vnorm[i]*normprod + vperp[i]*sint; |
214 |
