root/radiance/ray/src/common/fvect.c
Sat Jun 29 21:03:44 2013 UTC (10 years, 11 months ago) by greg
Changes since 2.18: +21 -1 lines
Diff to previous 2.18 , to selected 2.17
Wed Apr 3 00:22:12 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.17: +5 -11 lines
Diff to previous 2.17
Added more use of macros
Revision 2.17 - (view) (download) (annotate) - [selected]
Thu Nov 22 06:07:17 2012 UTC (11 years, 6 months ago) by greg
Diff to previous 2.16
Thu Nov 8 00:31:17 2012 UTC (11 years, 6 months ago) by greg
Diff to previous 2.15 , to selected 2.17
Thu Sep 6 00:07:43 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.14: +48 -3 lines
Diff to previous 2.14 , to selected 2.17
Tue Apr 19 21:31:22 2011 UTC (13 years, 1 month ago) by greg
Diff to previous 2.13 , to selected 2.17
Fixed interface for determining BSDF solid angles
Changes since 2.12: +21 -21 lines
Diff to previous 2.12 , to selected 2.17
Sun Sep 26 15:42:48 2010 UTC (13 years, 8 months ago) by greg
Changes since 2.11: +7 -5 lines
Diff to previous 2.11 , to selected 2.17
Improved speed of near-normalized approximation
Thu May 7 21:38:35 2009 UTC (15 years ago) by greg
Changes since 2.10: +17 -47 lines
Diff to previous 2.10 , to selected 2.17
Removed some dead code.
Tue Jun 24 02:16:14 2008 UTC (15 years, 11 months ago) by greg
Diff to previous 2.9 , to selected 2.17
Eliminated FTINY test in normalize(), comparing to zero instead
Wed Mar 23 01:54:55 2005 UTC (19 years, 2 months ago) by greg
Diff to previous 2.8 , to selected 2.17
Added epsilon back to normalize() test
Tue Sep 16 06:30:20 2003 UTC (20 years, 8 months ago) by greg
Changes since 2.7: +95 -21 lines
Diff to previous 2.7 , to selected 2.17
Wrote closestapproach() function to find closest point for two rays
Diff to previous 2.6 , to selected 2.17
Changes since 2.5: +61 -6 lines
Diff to previous 2.5 , to selected 2.17
Wed Nov 25 16:56:33 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 2.4: +16 -14 lines
Diff to previous 2.4 , to selected 2.17
modest efficiency improvements
Wed Aug 12 17:57:19 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 2.3: +6 -6 lines
Diff to previous 2.3 , to selected 2.17
changed static variables to register
Fri Dec 10 09:53:30 1993 UTC (30 years, 5 months ago) by greg
Changes since 2.2: +5 -6 lines
Diff to previous 2.2 , to selected 2.17
added first order approximation for sqrt() to normalize()
Fri Oct 2 16:02:43 1992 UTC (31 years, 8 months ago) by greg
Diff to previous 2.1 , to selected 2.17
Tue Nov 12 16:55:09 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.7 , to selected 2.17
Wed Oct 23 13:43:15 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.6: +0 -2 lines
Diff to previous 1.6 , to selected 2.17
Tue Apr 2 15:27:44 1991 UTC (33 years, 2 months ago) by greg
Changes since 1.5: +7 -7 lines
Diff to previous 1.5 , to selected 2.17
improved efficiency of spinvector() slightly
Tue Mar 19 13:14:19 1991 UTC (33 years, 2 months ago) by greg
Changes since 1.4: +23 -0 lines
Diff to previous 1.4 , to selected 2.17
added spinvector()
Tue Oct 17 13:35:30 1989 UTC (34 years, 7 months ago) by greg
Diff to previous 1.3 , to selected 2.17
added fvsum() to compute v0+f*v1
Mon May 8 08:40:56 1989 UTC (35 years, 1 month ago) by greg
Diff to previous 1.2 , to selected 2.17
changed length test to absolute zero
Sun May 7 21:41:40 1989 UTC (35 years, 1 month ago) by greg
Diff to previous 1.1 , to selected 2.17
removed conditional code from normalize()
Thu Feb 2 10:34:32 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.17
