root/Development/ray/src/common/fvect.c
Tue Apr 19 21:31:22 2011 UTC (14 years, 6 months ago) by greg
Diff to previous 2.13
Fixed interface for determining BSDF solid angles
Fri Feb 18 00:40:25 2011 UTC (14 years, 8 months ago) by greg
Changes since 2.12: +21 -21 lines
Diff to previous 2.12
Sun Sep 26 15:42:48 2010 UTC (15 years, 1 month ago) by greg
Changes since 2.11: +7 -5 lines
Improved speed of near-normalized approximation
Thu May 7 21:38:35 2009 UTC (16 years, 6 months ago) by greg
Changes since 2.10: +17 -47 lines
Removed some dead code.
Tue Jun 24 02:16:14 2008 UTC (17 years, 4 months ago) by greg
Eliminated FTINY test in normalize(), comparing to zero instead
Wed Mar 23 01:54:55 2005 UTC (20 years, 7 months ago) by greg
Added epsilon back to normalize() test
Tue Sep 16 06:30:20 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.7: +95 -21 lines
Wrote closestapproach() function to find closest point for two rays
Tue Feb 25 02:47:21 2003 UTC (22 years, 8 months ago) by greg
Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.5: +61 -6 lines
Wed Nov 25 16:56:33 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 2.4: +16 -14 lines
modest efficiency improvements
Wed Aug 12 17:57:19 1998 UTC (27 years, 3 months ago) by gwlarson
Changes since 2.3: +6 -6 lines
changed static variables to register
Fri Dec 10 09:53:30 1993 UTC (31 years, 11 months ago) by greg
Changes since 2.2: +5 -6 lines
added first order approximation for sqrt() to normalize()
Fri Oct 2 16:02:43 1992 UTC (33 years, 1 month ago) by greg
Tue Nov 12 16:55:09 1991 UTC (34 years ago) by greg
Diff to previous 1.7
Wed Oct 23 13:43:15 1991 UTC (34 years ago) by greg
Changes since 1.6: +0 -2 lines
Diff to previous 1.6
Tue Apr 2 15:27:44 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.5: +7 -7 lines
Diff to previous 1.5
improved efficiency of spinvector() slightly
Tue Mar 19 13:14:19 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.4: +23 -0 lines
Diff to previous 1.4
added spinvector()
Tue Oct 17 13:35:30 1989 UTC (36 years ago) by greg
Diff to previous 1.3
added fvsum() to compute v0+f*v1
Mon May 8 08:40:56 1989 UTC (36 years, 6 months ago) by greg
Diff to previous 1.2
changed length test to absolute zero
Sun May 7 21:41:40 1989 UTC (36 years, 6 months ago) by greg
Diff to previous 1.1
removed conditional code from normalize()
Thu Feb 2 10:34:32 1989 UTC (36 years, 9 months ago) by greg
