root/Development/ray/src/common/fvect.c
Revision: 2.14
Committed: Tue Apr 19 21:31:22 2011 UTC (14 years, 6 months ago) by greg
Fixed interface for determining BSDF solid angles
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.14 static const char RCSid[] = "$Id: fvect.c,v 2.13 2011/02/18 00:40:25 greg Exp $";
3 greg 1.1 #endif
4 greg 2.6 /*
5     * fvect.c - routines for floating-point vector calculations
6     */
7 greg 1.1
8 greg 2.7 #include "copyright.h"
9 greg 1.1
10 greg 2.2 #include <math.h>
11 greg 1.1 #include "fvect.h"
12
13
14     double
15 greg 2.8 fdot( /* return the dot product of two vectors */
16 greg 2.13 const FVECT v1,
17     const FVECT v2
18 greg 2.8 )
19 greg 1.1 {
20     return(DOT(v1,v2));
21     }
22
23
24     double
25 greg 2.8 dist2( /* return square of distance between points */
26 greg 2.13 const FVECT p1,
27     const FVECT p2
28 greg 2.8 )
29 greg 1.1 {
30 gwlarson 2.4 FVECT delta;
31 greg 1.1
32     delta[0] = p2[0] - p1[0];
33     delta[1] = p2[1] - p1[1];
34     delta[2] = p2[2] - p1[2];
35 gwlarson 2.5
36 greg 1.1 return(DOT(delta, delta));
37     }
38
39
40     double
41 greg 2.8 dist2line( /* return square of distance to line */
42 greg 2.13 const FVECT p, /* the point */
43     const FVECT ep1,
44     const FVECT ep2 /* points on the line */
45 greg 2.8 )
46 greg 1.1 {
47 greg 2.11 double d, d1, d2;
48 greg 1.1
49     d = dist2(ep1, ep2);
50     d1 = dist2(ep1, p);
51 gwlarson 2.5 d2 = d + d1 - dist2(ep2, p);
52 greg 1.1
53 gwlarson 2.5 return(d1 - 0.25*d2*d2/d);
54 greg 1.1 }
55
56
57     double
58 greg 2.8 dist2lseg( /* return square of distance to line segment */
59 greg 2.13 const FVECT p, /* the point */
60     const FVECT ep1,
61     const FVECT ep2 /* the end points */
62 greg 2.8 )
63 greg 1.1 {
64 greg 2.11 double d, d1, d2;
65 greg 1.1
66     d = dist2(ep1, ep2);
67     d1 = dist2(ep1, p);
68     d2 = dist2(ep2, p);
69
70     if (d2 > d1) { /* check if past endpoints */
71     if (d2 - d1 > d)
72     return(d1);
73     } else {
74     if (d1 - d2 > d)
75     return(d2);
76     }
77 gwlarson 2.5 d2 = d + d1 - d2;
78 greg 1.1
79 gwlarson 2.5 return(d1 - 0.25*d2*d2/d); /* distance to line */
80 greg 1.1 }
81
82
83 greg 2.6 void
84 greg 2.8 fcross( /* vres = v1 X v2 */
85 greg 2.11 FVECT vres,
86 greg 2.13 const FVECT v1,
87     const FVECT v2
88 greg 2.8 )
89 greg 1.1 {
90     vres[0] = v1[1]*v2[2] - v1[2]*v2[1];
91     vres[1] = v1[2]*v2[0] - v1[0]*v2[2];
92     vres[2] = v1[0]*v2[1] - v1[1]*v2[0];
93     }
94
95
96 greg 2.6 void
97 greg 2.8 fvsum( /* vres = v0 + f*v1 */
98 greg 2.11 FVECT vres,
99 greg 2.13 const FVECT v0,
100     const FVECT v1,
101 greg 2.11 double f
102 greg 2.8 )
103 greg 1.4 {
104     vres[0] = v0[0] + f*v1[0];
105     vres[1] = v0[1] + f*v1[1];
106     vres[2] = v0[2] + f*v1[2];
107     }
108
109
110 greg 1.1 double
111 greg 2.8 normalize( /* normalize a vector, return old magnitude */
112 greg 2.11 FVECT v
113 greg 2.8 )
114 greg 1.1 {
115 greg 2.11 double len, d;
116 greg 1.1
117 gwlarson 2.5 d = DOT(v, v);
118 greg 1.1
119 greg 2.10 if (d == 0.0)
120 greg 1.1 return(0.0);
121
122 greg 2.12 if (d <= 1.0+FTINY && d >= 1.0-FTINY) {
123 gwlarson 2.5 len = 0.5 + 0.5*d; /* first order approximation */
124 greg 2.12 d = 2.0 - len;
125     } else {
126 gwlarson 2.5 len = sqrt(d);
127 greg 2.12 d = 1.0/len;
128     }
129     v[0] *= d;
130 gwlarson 2.5 v[1] *= d;
131     v[2] *= d;
132 greg 2.3
133 greg 1.1 return(len);
134     }
135 greg 1.5
136
137 greg 2.8 int
138     closestapproach( /* closest approach of two rays */
139     RREAL t[2], /* returned distances along each ray */
140 greg 2.13 const FVECT rorg0, /* first origin */
141     const FVECT rdir0, /* first direction (normalized) */
142     const FVECT rorg1, /* second origin */
143     const FVECT rdir1 /* second direction (normalized) */
144 greg 2.8 )
145     {
146     double dotprod = DOT(rdir0, rdir1);
147     double denom = 1. - dotprod*dotprod;
148     double o1o2_d1;
149     FVECT o0o1;
150
151     if (denom <= FTINY) { /* check if lines are parallel */
152     t[0] = t[1] = 0.0;
153     return(0);
154     }
155     VSUB(o0o1, rorg0, rorg1);
156     o1o2_d1 = DOT(o0o1, rdir1);
157     t[0] = (o1o2_d1*dotprod - DOT(o0o1,rdir0)) / denom;
158     t[1] = o1o2_d1 + t[0]*dotprod;
159     return(1);
160     }
161
162
163 greg 2.6 void
164 greg 2.8 spinvector( /* rotate vector around normal */
165     FVECT vres, /* returned vector */
166 greg 2.13 const FVECT vorig, /* original vector */
167     const FVECT vnorm, /* normalized vector for rotation */
168 greg 2.14 double theta /* right-hand radians */
169 greg 2.8 )
170 greg 1.5 {
171 greg 1.6 double sint, cost, normprod;
172 greg 1.5 FVECT vperp;
173 greg 2.11 int i;
174 greg 1.5
175     if (theta == 0.0) {
176 greg 1.6 if (vres != vorig)
177     VCOPY(vres, vorig);
178 greg 1.5 return;
179     }
180 greg 1.6 cost = cos(theta);
181 greg 1.5 sint = sin(theta);
182 greg 1.6 normprod = DOT(vorig, vnorm)*(1.-cost);
183 greg 1.5 fcross(vperp, vnorm, vorig);
184     for (i = 0; i < 3; i++)
185 greg 1.6 vres[i] = vorig[i]*cost + vnorm[i]*normprod + vperp[i]*sint;
186 greg 1.5 }
