--- ray/src/common/fvect.c 1991/10/23 13:43:15 1.7 +++ ray/src/common/fvect.c 1998/11/25 16:56:33 2.5 @@ -1,7 +1,7 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static char SCCSid[] = "$SunId$ SGI"; #endif /* @@ -10,6 +10,7 @@ static char SCCSid[] = "$SunId$ LBL"; * 8/14/85 */ +#include #include "fvect.h" @@ -25,11 +26,12 @@ double dist2(p1, p2) /* return square of distance between points */ register FVECT p1, p2; { - static FVECT delta; + FVECT delta; delta[0] = p2[0] - p1[0]; delta[1] = p2[1] - p1[1]; delta[2] = p2[2] - p1[2]; + return(DOT(delta, delta)); } @@ -39,13 +41,13 @@ dist2line(p, ep1, ep2) /* return square of distance t FVECT p; /* the point */ FVECT ep1, ep2; /* points on the line */ { - static double d, d1, d2; + register double d, d1, d2; d = dist2(ep1, ep2); d1 = dist2(ep1, p); - d2 = dist2(ep2, p); + d2 = d + d1 - dist2(ep2, p); - return(d1 - (d+d1-d2)*(d+d1-d2)/d/4); + return(d1 - 0.25*d2*d2/d); } @@ -54,7 +56,7 @@ dist2lseg(p, ep1, ep2) /* return square of distance t FVECT p; /* the point */ FVECT ep1, ep2; /* the end points */ { - static double d, d1, d2; + register double d, d1, d2; d = dist2(ep1, ep2); d1 = dist2(ep1, p); @@ -67,8 +69,9 @@ FVECT ep1, ep2; /* the end points */ if (d1 - d2 > d) return(d2); } + d2 = d + d1 - d2; - return(d1 - (d+d1-d2)*(d+d1-d2)/d/4); /* distance to line */ + return(d1 - 0.25*d2*d2/d); /* distance to line */ } @@ -82,8 +85,8 @@ register FVECT vres, v1, v2; fvsum(vres, v0, v1, f) /* vres = v0 + f*v1 */ -FVECT vres, v0, v1; -double f; +register FVECT vres, v0, v1; +register double f; { vres[0] = v0[0] + f*v1[0]; vres[1] = v0[1] + f*v1[1]; @@ -95,23 +98,22 @@ double normalize(v) /* normalize a vector, return old magnitude */ register FVECT v; { - static double len; + register double len, d; - len = DOT(v, v); + d = DOT(v, v); - if (len <= 0.0) + if (d <= 0.0) return(0.0); - /****** problematic - if (len >= (1.0-FTINY)*(1.0-FTINY) && - len <= (1.0+FTINY)*(1.0+FTINY)) - return(1.0); - ******/ + if (d <= 1.0+FTINY && d >= 1.0-FTINY) + len = 0.5 + 0.5*d; /* first order approximation */ + else + len = sqrt(d); - len = sqrt(len); - v[0] /= len; - v[1] /= len; - v[2] /= len; + v[0] *= d = 1.0/len; + v[1] *= d; + v[2] *= d; + return(len); } @@ -120,7 +122,6 @@ spinvector(vres, vorig, vnorm, theta) /* rotate vector FVECT vres, vorig, vnorm; double theta; { - extern double cos(), sin(); double sint, cost, normprod; FVECT vperp; register int i;
