root/radiance/ray/src/common/fvect.c
Tue Sep 16 06:30:20 2003 UTC (20 years, 7 months ago) by greg
Changes since 2.7: +95 -21 lines
Diff to previous 2.7 , to selected 1.1
Wrote closestapproach() function to find closest point for two rays
Diff to previous 2.6 , to selected 1.1
Changes since 2.5: +61 -6 lines
Diff to previous 2.5 , to selected 1.1
Wed Nov 25 16:56:33 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 2.4: +16 -14 lines
Diff to previous 2.4 , to selected 1.1
modest efficiency improvements
Wed Aug 12 17:57:19 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 2.3: +6 -6 lines
Diff to previous 2.3 , to selected 1.1
changed static variables to register
Fri Dec 10 09:53:30 1993 UTC (30 years, 4 months ago) by greg
Changes since 2.2: +5 -6 lines
Diff to previous 2.2 , to selected 1.1
added first order approximation for sqrt() to normalize()
Fri Oct 2 16:02:43 1992 UTC (31 years, 7 months ago) by greg
Diff to previous 2.1 , to selected 1.1
Tue Nov 12 16:55:09 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.7 , to selected 1.1
Wed Oct 23 13:43:15 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.6: +0 -2 lines
Diff to previous 1.6 , to selected 1.1
Tue Apr 2 15:27:44 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.5: +7 -7 lines
Diff to previous 1.5 , to selected 1.1
improved efficiency of spinvector() slightly
Tue Mar 19 13:14:19 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.4: +23 -0 lines
Diff to previous 1.4 , to selected 1.1
added spinvector()
Tue Oct 17 13:35:30 1989 UTC (34 years, 6 months ago) by greg
Diff to previous 1.3 , to selected 1.1
added fvsum() to compute v0+f*v1
Mon May 8 08:40:56 1989 UTC (35 years ago) by greg
Diff to previous 1.2 , to selected 1.1
changed length test to absolute zero
Sun May 7 21:41:40 1989 UTC (35 years ago) by greg
Diff to previous 1.1
removed conditional code from normalize()
Revision 1.1 - (view) (download) (annotate) - [selected]
Thu Feb 2 10:34:32 1989 UTC (35 years, 3 months ago) by greg
