root/radiance/ray/src/common/fvect.c
Revision: 2.8
Committed: Tue Sep 16 06:30:20 2003 UTC (20 years, 9 months ago) by greg
Changes since 2.7: +95 -21 lines
Wrote closestapproach() function to find closest point for two rays
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.8 static const char RCSid[] = "$Id: fvect.c,v 2.7 2003/02/25 02:47:21 greg Exp $";
3 greg 1.1 #endif
4 greg 2.6 /*
5     * fvect.c - routines for floating-point vector calculations
6     */
7 greg 1.1
8 greg 2.7 #include "copyright.h"
9 greg 1.1
10 greg 2.2 #include <math.h>
11 greg 1.1 #include "fvect.h"
12
13
14     double
15 greg 2.8 fdot( /* return the dot product of two vectors */
16     register FVECT v1,
17     register FVECT v2
18     )
19 greg 1.1 {
20     return(DOT(v1,v2));
21     }
22
23
24     double
25 greg 2.8 dist2( /* return square of distance between points */
26     register FVECT p1,
27     register FVECT p2
28     )
29 greg 1.1 {
30 gwlarson 2.4 FVECT delta;
31 greg 1.1
32     delta[0] = p2[0] - p1[0];
33     delta[1] = p2[1] - p1[1];
34     delta[2] = p2[2] - p1[2];
35 gwlarson 2.5
36 greg 1.1 return(DOT(delta, delta));
37     }
38
39
40     double
41 greg 2.8 dist2line( /* return square of distance to line */
42     FVECT p, /* the point */
43     FVECT ep1,
44     FVECT ep2 /* points on the line */
45     )
46 greg 1.1 {
47 gwlarson 2.4 register double d, d1, d2;
48 greg 1.1
49     d = dist2(ep1, ep2);
50     d1 = dist2(ep1, p);
51 gwlarson 2.5 d2 = d + d1 - dist2(ep2, p);
52 greg 1.1
53 gwlarson 2.5 return(d1 - 0.25*d2*d2/d);
54 greg 1.1 }
55
56
57     double
58 greg 2.8 dist2lseg( /* return square of distance to line segment */
59     FVECT p, /* the point */
60     FVECT ep1,
61     FVECT ep2 /* the end points */
62     )
63 greg 1.1 {
64 gwlarson 2.4 register double d, d1, d2;
65 greg 1.1
66     d = dist2(ep1, ep2);
67     d1 = dist2(ep1, p);
68     d2 = dist2(ep2, p);
69
70     if (d2 > d1) { /* check if past endpoints */
71     if (d2 - d1 > d)
72     return(d1);
73     } else {
74     if (d1 - d2 > d)
75     return(d2);
76     }
77 gwlarson 2.5 d2 = d + d1 - d2;
78 greg 1.1
79 gwlarson 2.5 return(d1 - 0.25*d2*d2/d); /* distance to line */
80 greg 1.1 }
81
82
83 greg 2.6 void
84 greg 2.8 fcross( /* vres = v1 X v2 */
85     register FVECT vres,
86     register FVECT v1,
87     register FVECT v2
88     )
89 greg 1.1 {
90     vres[0] = v1[1]*v2[2] - v1[2]*v2[1];
91     vres[1] = v1[2]*v2[0] - v1[0]*v2[2];
92     vres[2] = v1[0]*v2[1] - v1[1]*v2[0];
93     }
94
95
96 greg 2.6 void
97 greg 2.8 fvsum( /* vres = v0 + f*v1 */
98     register FVECT vres,
99     register FVECT v0,
100     register FVECT v1,
101     register double f
102     )
103 greg 1.4 {
104     vres[0] = v0[0] + f*v1[0];
105     vres[1] = v0[1] + f*v1[1];
106     vres[2] = v0[2] + f*v1[2];
107     }
108
109
110 greg 1.1 double
111 greg 2.8 normalize( /* normalize a vector, return old magnitude */
112     register FVECT v
113     )
114 greg 1.1 {
115 gwlarson 2.5 register double len, d;
116 greg 1.1
117 gwlarson 2.5 d = DOT(v, v);
118 greg 1.1
119 gwlarson 2.5 if (d <= 0.0)
120 greg 1.1 return(0.0);
121
122 gwlarson 2.5 if (d <= 1.0+FTINY && d >= 1.0-FTINY)
123     len = 0.5 + 0.5*d; /* first order approximation */
124 greg 2.3 else
125 gwlarson 2.5 len = sqrt(d);
126 greg 1.1
127 gwlarson 2.5 v[0] *= d = 1.0/len;
128     v[1] *= d;
129     v[2] *= d;
130 greg 2.3
131 greg 1.1 return(len);
132     }
133 greg 1.5
134
135 greg 2.8 int
136     closestapproach( /* closest approach of two rays */
137     RREAL t[2], /* returned distances along each ray */
138     FVECT rorg0, /* first origin */
139     FVECT rdir0, /* first direction (normalized) */
140     FVECT rorg1, /* second origin */
141     FVECT rdir1 /* second direction (normalized) */
142     )
143     {
144     double dotprod = DOT(rdir0, rdir1);
145     double denom = 1. - dotprod*dotprod;
146     double o1o2_d1;
147     FVECT o0o1;
148
149     if (denom <= FTINY) { /* check if lines are parallel */
150     t[0] = t[1] = 0.0;
151     return(0);
152     }
153     VSUB(o0o1, rorg0, rorg1);
154     o1o2_d1 = DOT(o0o1, rdir1);
155     t[0] = (o1o2_d1*dotprod - DOT(o0o1,rdir0)) / denom;
156     t[1] = o1o2_d1 + t[0]*dotprod;
157     return(1);
158     }
159
160
161     #if 0
162     int
163     closestapproach( /* closest approach of two rays */
164     RREAL t[2], /* returned distances along each ray */
165     FVECT rorg0, /* first origin */
166     FVECT rdir0, /* first direction (unnormalized) */
167     FVECT rorg1, /* second origin */
168     FVECT rdir1 /* second direction (unnormalized) */
169     )
170     {
171     double dotprod = DOT(rdir0, rdir1);
172     double d0n2 = DOT(rdir0, rdir0);
173     double d1n2 = DOT(rdir1, rdir1);
174     double denom = d0n2*d1n2 - dotprod*dotprod;
175     double o1o2_d1;
176     FVECT o0o1;
177
178     if (denom <= FTINY) { /* check if lines are parallel */
179     t[0] = t[1] = 0.0;
180     return(0);
181     }
182     VSUB(o0o1, rorg0, rorg1);
183     o1o2_d1 = DOT(o0o1, rdir1);
184     t[0] = (o1o2_d1*dotprod - DOT(o0o1,rdir0)*d1n2) / denom;
185     t[1] = (o1o2_d1 + t[0]*dotprod) / d1n2;
186     return(1);
187     }
188     #endif
189
190
191 greg 2.6 void
192 greg 2.8 spinvector( /* rotate vector around normal */
193     FVECT vres, /* returned vector */
194     FVECT vorig, /* original vector */
195     FVECT vnorm, /* normalized vector for rotation */
196     double theta /* left-hand radians */
197     )
198 greg 1.5 {
199 greg 1.6 double sint, cost, normprod;
200 greg 1.5 FVECT vperp;
201     register int i;
202
203     if (theta == 0.0) {
204 greg 1.6 if (vres != vorig)
205     VCOPY(vres, vorig);
206 greg 1.5 return;
207     }
208 greg 1.6 cost = cos(theta);
209 greg 1.5 sint = sin(theta);
210 greg 1.6 normprod = DOT(vorig, vnorm)*(1.-cost);
211 greg 1.5 fcross(vperp, vnorm, vorig);
212     for (i = 0; i < 3; i++)
213 greg 1.6 vres[i] = vorig[i]*cost + vnorm[i]*normprod + vperp[i]*sint;
214 greg 1.5 }
