1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: fvect.c,v 2.21 2014/12/08 23:51:12 greg Exp $"; |
3 |
#endif |
4 |
5 |
* fvect.c - routines for floating-point vector calculations |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#define _USE_MATH_DEFINES |
11 |
#include <math.h> |
12 |
#include "fvect.h" |
13 |
#include "random.h" |
14 |
15 |
double |
16 |
Acos(double x) /* insurance for touchy math library */ |
17 |
18 |
if (x <= -1.+FTINY*FTINY) |
19 |
return(M_PI); |
20 |
if (x >= 1.-FTINY*FTINY) |
21 |
return(.0); |
22 |
return(acos(x)); |
23 |
24 |
25 |
double |
26 |
Asin(double x) /* insurance for touchy math library */ |
27 |
28 |
29 |
return(-M_PI/2.); |
30 |
31 |
return(M_PI/2); |
32 |
return(asin(x)); |
33 |
34 |
35 |
double |
36 |
fdot( /* return the dot product of two vectors */ |
37 |
const FVECT v1, |
38 |
const FVECT v2 |
39 |
40 |
41 |
return(DOT(v1,v2)); |
42 |
43 |
44 |
45 |
double |
46 |
dist2( /* return square of distance between points */ |
47 |
const FVECT p1, |
48 |
const FVECT p2 |
49 |
50 |
51 |
FVECT delta; |
52 |
53 |
VSUB(delta, p2, p1); |
54 |
55 |
return(DOT(delta, delta)); |
56 |
57 |
58 |
59 |
double |
60 |
dist2line( /* return square of distance to line */ |
61 |
const FVECT p, /* the point */ |
62 |
const FVECT ep1, |
63 |
const FVECT ep2 /* points on the line */ |
64 |
65 |
66 |
double d, d1, d2; |
67 |
68 |
d = dist2(ep1, ep2); |
69 |
d1 = dist2(ep1, p); |
70 |
d2 = d + d1 - dist2(ep2, p); |
71 |
72 |
return(d1 - 0.25*d2*d2/d); |
73 |
74 |
75 |
76 |
double |
77 |
dist2lseg( /* return square of distance to line segment */ |
78 |
79 |
const FVECT ep1, |
80 |
const FVECT ep2 /* the end points */ |
81 |
82 |
83 |
double d, d1, d2; |
84 |
85 |
86 |
87 |
d2 = dist2(ep2, p); |
88 |
89 |
if (d2 > d1) { /* check if past endpoints */ |
90 |
if (d2 - d1 > d) |
91 |
return(d1); |
92 |
} else { |
93 |
if (d1 - d2 > d) |
94 |
return(d2); |
95 |
96 |
d2 = d + d1 - d2; |
97 |
98 |
return(d1 - 0.25*d2*d2/d); /* distance to line */ |
99 |
100 |
101 |
102 |
void |
103 |
fcross( /* vres = v1 X v2 */ |
104 |
FVECT vres, |
105 |
const FVECT v1, |
106 |
const FVECT v2 |
107 |
108 |
109 |
if ((vres == v1) | (vres == v2)) { |
110 |
FVECT vtmp; |
111 |
VCROSS(vtmp, v1, v2); |
112 |
VCOPY(vres, vtmp); |
113 |
return; |
114 |
115 |
VCROSS(vres, v1, v2); |
116 |
117 |
118 |
119 |
void |
120 |
fvsum( /* vres = v0 + f*v1 */ |
121 |
FVECT vres, |
122 |
const FVECT v0, |
123 |
const FVECT v1, |
124 |
double f |
125 |
126 |
127 |
VSUM(vres, v0, v1, f); |
128 |
129 |
130 |
131 |
double |
132 |
normalize( /* normalize a vector, return old magnitude */ |
133 |
FVECT v |
134 |
135 |
136 |
double len, d; |
137 |
138 |
d = DOT(v, v); |
139 |
140 |
if (d == 0.0) |
141 |
return(0.0); |
142 |
143 |
if ((d <= 1.0+FTINY) & (d >= 1.0-FTINY)) { |
144 |
len = 0.5 + 0.5*d; /* first order approximation */ |
145 |
d = 2.0 - len; |
146 |
} else { |
147 |
len = sqrt(d); |
148 |
d = 1.0/len; |
149 |
150 |
v[0] *= d; |
151 |
v[1] *= d; |
152 |
v[2] *= d; |
153 |
154 |
return(len); |
155 |
156 |
157 |
158 |
int |
159 |
getperpendicular( /* choose perpedicular direction */ |
160 |
FVECT vp, /* returns normalized */ |
161 |
const FVECT v, /* input vector must be normalized */ |
162 |
int randomize /* randomize orientation */ |
163 |
164 |
165 |
int ord[3]; |
166 |
FVECT v1; |
167 |
int i; |
168 |
169 |
if (randomize) { /* randomize coordinates? */ |
170 |
v1[0] = 0.5 - frandom(); |
171 |
v1[1] = 0.5 - frandom(); |
172 |
v1[2] = 0.5 - frandom(); |
173 |
switch (ord[0] = (int)(frandom()*2.99999)) { |
174 |
case 0: |
175 |
ord[1] = 1 + (frandom() > .5); |
176 |
ord[2] = 2 - ord[1]; |
177 |
break; |
178 |
case 1: |
179 |
ord[1] = 2*(frandom() > .5); |
180 |
181 |
break; |
182 |
case 2: |
183 |
ord[1] = (frandom() > .5); |
184 |
ord[2] = 1 - ord[1]; |
185 |
break; |
186 |
187 |
} else { |
188 |
v1[0] = v1[1] = v1[2] = .0; |
189 |
ord[0] = 0; ord[1] = 1; ord[2] = 2; |
190 |
191 |
192 |
for (i = 3; i--; ) |
193 |
if ((-0.6 < v[ord[i]]) & (v[ord[i]] < 0.6)) |
194 |
break; |
195 |
if (i < 0) |
196 |
return(0); |
197 |
198 |
v1[ord[i]] = 1.0; |
199 |
fcross(vp, v1, v); |
200 |
201 |
return(normalize(vp) > 0.0); |
202 |
203 |
204 |
205 |
int |
206 |
closestapproach( /* closest approach of two rays */ |
207 |
RREAL t[2], /* returned distances along each ray */ |
208 |
const FVECT rorg0, /* first origin */ |
209 |
const FVECT rdir0, /* first direction (normalized) */ |
210 |
const FVECT rorg1, /* second origin */ |
211 |
const FVECT rdir1 /* second direction (normalized) */ |
212 |
213 |
214 |
double dotprod = DOT(rdir0, rdir1); |
215 |
double denom = 1. - dotprod*dotprod; |
216 |
double o1o2_d1; |
217 |
FVECT o0o1; |
218 |
219 |
if (denom <= FTINY) { /* check if lines are parallel */ |
220 |
t[0] = t[1] = 0.0; |
221 |
return(0); |
222 |
223 |
VSUB(o0o1, rorg0, rorg1); |
224 |
o1o2_d1 = DOT(o0o1, rdir1); |
225 |
t[0] = (o1o2_d1*dotprod - DOT(o0o1,rdir0)) / denom; |
226 |
t[1] = o1o2_d1 + t[0]*dotprod; |
227 |
return(1); |
228 |
229 |
230 |
231 |
void |
232 |
spinvector( /* rotate vector around normal */ |
233 |
FVECT vres, /* returned vector (same magnitude as vorig) */ |
234 |
const FVECT vorig, /* original vector */ |
235 |
const FVECT vnorm, /* normalized vector for rotation */ |
236 |
double theta /* right-hand radians */ |
237 |
238 |
239 |
double sint, cost, normprod; |
240 |
FVECT vperp; |
241 |
int i; |
242 |
243 |
if (theta == 0.0) { |
244 |
if (vres != vorig) |
245 |
VCOPY(vres, vorig); |
246 |
return; |
247 |
248 |
cost = cos(theta); |
249 |
sint = sin(theta); |
250 |
normprod = DOT(vorig, vnorm)*(1.-cost); |
251 |
VCROSS(vperp, vnorm, vorig); |
252 |
for (i = 0; i < 3; i++) |
253 |
vres[i] = vorig[i]*cost + vnorm[i]*normprod + vperp[i]*sint; |
254 |
255 |
256 |
double |
257 |
geodesic( /* rotate vector on great circle towards target */ |
258 |
259 |
260 |
const FVECT vtarg, /* vector we are rotating towards */ |
261 |
double t, /* amount along arc directed towards vtarg */ |
262 |
int meas /* distance measure (radians, absolute, relative) */ |
263 |
264 |
265 |
FVECT normtarg; |
266 |
double volen, dotprod, sintr, cost; |
267 |
int i; |
268 |
269 |
VCOPY(normtarg, vtarg); /* in case vtarg==vres */ |
270 |
271 |
272 |
if (t == 0.0) |
273 |
return(VLEN(vres)); /* no rotation requested */ |
274 |
if ((volen = normalize(vres)) == 0.0) |
275 |
return(0.0); |
276 |
if (normalize(normtarg) == 0.0) |
277 |
return(0.0); /* target vector is zero */ |
278 |
dotprod = DOT(vres, normtarg); |
279 |
/* check for colinear */ |
280 |
if (dotprod >= 1.0-FTINY*FTINY) { |
281 |
if (meas != GEOD_REL) |
282 |
return(0.0); |
283 |
vres[0] *= volen; vres[1] *= volen; vres[2] *= volen; |
284 |
return(volen); |
285 |
286 |
if (dotprod <= -1.0+FTINY*FTINY) |
287 |
return(0.0); |
288 |
if (meas == GEOD_ABS) |
289 |
t /= volen; |
290 |
else if (meas == GEOD_REL) |
291 |
t *= acos(dotprod); |
292 |
cost = cos(t); |
293 |
sintr = sin(t) / sqrt(1. - dotprod*dotprod); |
294 |
295 |
vres[i] = volen*( cost*vres[i] + |
296 |
sintr*(normtarg[i] - dotprod*vres[i]) ); |
297 |
298 |
return(volen); /* return vector length */ |
299 |
