1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: fvect.c,v 2.17 2012/11/22 06:07:17 greg Exp $"; |
3 |
#endif |
4 |
5 |
* fvect.c - routines for floating-point vector calculations |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <math.h> |
11 |
#include "fvect.h" |
12 |
13 |
14 |
double |
15 |
fdot( /* return the dot product of two vectors */ |
16 |
const FVECT v1, |
17 |
const FVECT v2 |
18 |
19 |
20 |
return(DOT(v1,v2)); |
21 |
22 |
23 |
24 |
double |
25 |
dist2( /* return square of distance between points */ |
26 |
const FVECT p1, |
27 |
const FVECT p2 |
28 |
29 |
30 |
FVECT delta; |
31 |
32 |
VSUB(delta, p2, p1); |
33 |
34 |
return(DOT(delta, delta)); |
35 |
36 |
37 |
38 |
double |
39 |
dist2line( /* return square of distance to line */ |
40 |
const FVECT p, /* the point */ |
41 |
const FVECT ep1, |
42 |
const FVECT ep2 /* points on the line */ |
43 |
44 |
45 |
double d, d1, d2; |
46 |
47 |
d = dist2(ep1, ep2); |
48 |
d1 = dist2(ep1, p); |
49 |
d2 = d + d1 - dist2(ep2, p); |
50 |
51 |
return(d1 - 0.25*d2*d2/d); |
52 |
53 |
54 |
55 |
double |
56 |
dist2lseg( /* return square of distance to line segment */ |
57 |
58 |
const FVECT ep1, |
59 |
const FVECT ep2 /* the end points */ |
60 |
61 |
62 |
double d, d1, d2; |
63 |
64 |
65 |
66 |
d2 = dist2(ep2, p); |
67 |
68 |
if (d2 > d1) { /* check if past endpoints */ |
69 |
if (d2 - d1 > d) |
70 |
return(d1); |
71 |
} else { |
72 |
if (d1 - d2 > d) |
73 |
return(d2); |
74 |
75 |
d2 = d + d1 - d2; |
76 |
77 |
return(d1 - 0.25*d2*d2/d); /* distance to line */ |
78 |
79 |
80 |
81 |
void |
82 |
fcross( /* vres = v1 X v2 */ |
83 |
FVECT vres, |
84 |
const FVECT v1, |
85 |
const FVECT v2 |
86 |
87 |
88 |
VCROSS(vres, v1, v2); |
89 |
90 |
91 |
92 |
void |
93 |
fvsum( /* vres = v0 + f*v1 */ |
94 |
FVECT vres, |
95 |
const FVECT v0, |
96 |
const FVECT v1, |
97 |
double f |
98 |
99 |
100 |
VSUM(vres, v0, v1, f); |
101 |
102 |
103 |
104 |
double |
105 |
normalize( /* normalize a vector, return old magnitude */ |
106 |
FVECT v |
107 |
108 |
109 |
double len, d; |
110 |
111 |
d = DOT(v, v); |
112 |
113 |
if (d == 0.0) |
114 |
return(0.0); |
115 |
116 |
if ((d <= 1.0+FTINY) & (d >= 1.0-FTINY)) { |
117 |
len = 0.5 + 0.5*d; /* first order approximation */ |
118 |
d = 2.0 - len; |
119 |
} else { |
120 |
len = sqrt(d); |
121 |
d = 1.0/len; |
122 |
123 |
v[0] *= d; |
124 |
v[1] *= d; |
125 |
v[2] *= d; |
126 |
127 |
return(len); |
128 |
129 |
130 |
131 |
int |
132 |
closestapproach( /* closest approach of two rays */ |
133 |
RREAL t[2], /* returned distances along each ray */ |
134 |
const FVECT rorg0, /* first origin */ |
135 |
const FVECT rdir0, /* first direction (normalized) */ |
136 |
const FVECT rorg1, /* second origin */ |
137 |
const FVECT rdir1 /* second direction (normalized) */ |
138 |
139 |
140 |
double dotprod = DOT(rdir0, rdir1); |
141 |
double denom = 1. - dotprod*dotprod; |
142 |
double o1o2_d1; |
143 |
FVECT o0o1; |
144 |
145 |
if (denom <= FTINY) { /* check if lines are parallel */ |
146 |
t[0] = t[1] = 0.0; |
147 |
return(0); |
148 |
149 |
VSUB(o0o1, rorg0, rorg1); |
150 |
o1o2_d1 = DOT(o0o1, rdir1); |
151 |
t[0] = (o1o2_d1*dotprod - DOT(o0o1,rdir0)) / denom; |
152 |
t[1] = o1o2_d1 + t[0]*dotprod; |
153 |
return(1); |
154 |
155 |
156 |
157 |
void |
158 |
spinvector( /* rotate vector around normal */ |
159 |
FVECT vres, /* returned vector (same magnitude as vorig) */ |
160 |
const FVECT vorig, /* original vector */ |
161 |
const FVECT vnorm, /* normalized vector for rotation */ |
162 |
double theta /* right-hand radians */ |
163 |
164 |
165 |
double sint, cost, normprod; |
166 |
FVECT vperp; |
167 |
int i; |
168 |
169 |
if (theta == 0.0) { |
170 |
if (vres != vorig) |
171 |
VCOPY(vres, vorig); |
172 |
return; |
173 |
174 |
cost = cos(theta); |
175 |
sint = sin(theta); |
176 |
normprod = DOT(vorig, vnorm)*(1.-cost); |
177 |
VCROSS(vperp, vnorm, vorig); |
178 |
for (i = 0; i < 3; i++) |
179 |
vres[i] = vorig[i]*cost + vnorm[i]*normprod + vperp[i]*sint; |
180 |
181 |
182 |
double |
183 |
geodesic( /* rotate vector on great circle towards target */ |
184 |
185 |
186 |
const FVECT vtarg, /* vector we are rotating towards */ |
187 |
double t, /* amount along arc directed towards vtarg */ |
188 |
int meas /* distance measure (radians, absolute, relative) */ |
189 |
190 |
191 |
FVECT normtarg; |
192 |
double volen, dotprod, sintr, cost; |
193 |
int i; |
194 |
195 |
VCOPY(normtarg, vtarg); /* in case vtarg==vres */ |
196 |
197 |
198 |
if (t == 0.0) |
199 |
return(VLEN(vres)); /* no rotation requested */ |
200 |
if ((volen = normalize(vres)) == 0.0) |
201 |
return(0.0); |
202 |
if (normalize(normtarg) == 0.0) |
203 |
return(0.0); /* target vector is zero */ |
204 |
dotprod = DOT(vres, normtarg); |
205 |
/* check for colinear */ |
206 |
if (dotprod >= 1.0-FTINY*FTINY) { |
207 |
if (meas != GEOD_REL) |
208 |
return(0.0); |
209 |
vres[0] *= volen; vres[1] *= volen; vres[2] *= volen; |
210 |
return(volen); |
211 |
212 |
if (dotprod <= -1.0+FTINY*FTINY) |
213 |
return(0.0); |
214 |
if (meas == GEOD_ABS) |
215 |
t /= volen; |
216 |
else if (meas == GEOD_REL) |
217 |
t *= acos(dotprod); |
218 |
cost = cos(t); |
219 |
sintr = sin(t) / sqrt(1. - dotprod*dotprod); |
220 |
221 |
vres[i] = volen*( cost*vres[i] + |
222 |
sintr*(normtarg[i] - dotprod*vres[i]) ); |
223 |
224 |
return(volen); /* return vector length */ |
225 |
