root/radiance/ray/src/common/fvect.c
Revision: 2.16
Committed: Thu Nov 8 00:31:17 2012 UTC (12 years, 7 months ago) by greg
2 static const char RCSid[] = "$Id: fvect.c,v 2.15 2012/09/06 00:07:43 greg Exp $";
5 * fvect.c - routines for floating-point vector calculations
6 */
7
8 #include "copyright.h"
9
10 #include <math.h>
11 #include "fvect.h"
12
13
14 double
15 fdot( /* return the dot product of two vectors */
16 const FVECT v1,
17 const FVECT v2
18 )
19 {
20 return(DOT(v1,v2));
21 }
22
23
24 double
25 dist2( /* return square of distance between points */
26 const FVECT p1,
27 const FVECT p2
28 )
29 {
30 FVECT delta;
31
32 delta[0] = p2[0] - p1[0];
33 delta[1] = p2[1] - p1[1];
34 delta[2] = p2[2] - p1[2];
35
36 return(DOT(delta, delta));
37 }
38
39
40 double
41 dist2line( /* return square of distance to line */
42 const FVECT p, /* the point */
43 const FVECT ep1,
44 const FVECT ep2 /* points on the line */
45 )
46 {
47 double d, d1, d2;
48
49 d = dist2(ep1, ep2);
50 d1 = dist2(ep1, p);
51 d2 = d + d1 - dist2(ep2, p);
52
53 return(d1 - 0.25*d2*d2/d);
54 }
55
56
57 double
58 dist2lseg( /* return square of distance to line segment */
59 const FVECT p, /* the point */
60 const FVECT ep1,
61 const FVECT ep2 /* the end points */
62 )
63 {
64 double d, d1, d2;
65
66 d = dist2(ep1, ep2);
67 d1 = dist2(ep1, p);
68 d2 = dist2(ep2, p);
69
70 if (d2 > d1) { /* check if past endpoints */
71 if (d2 - d1 > d)
72 return(d1);
73 } else {
74 if (d1 - d2 > d)
75 return(d2);
76 }
77 d2 = d + d1 - d2;
78
79 return(d1 - 0.25*d2*d2/d); /* distance to line */
80 }
81
82
83 void
84 fcross( /* vres = v1 X v2 */
85 FVECT vres,
86 const FVECT v1,
87 const FVECT v2
88 )
89 {
90 vres[0] = v1[1]*v2[2] - v1[2]*v2[1];
91 vres[1] = v1[2]*v2[0] - v1[0]*v2[2];
92 vres[2] = v1[0]*v2[1] - v1[1]*v2[0];
93 }
94
95
96 void
97 fvsum( /* vres = v0 + f*v1 */
98 FVECT vres,
99 const FVECT v0,
100 const FVECT v1,
101 double f
102 )
103 {
104 vres[0] = v0[0] + f*v1[0];
105 vres[1] = v0[1] + f*v1[1];
106 vres[2] = v0[2] + f*v1[2];
107 }
108
109
110 double
111 normalize( /* normalize a vector, return old magnitude */
112 FVECT v
113 )
114 {
115 double len, d;
116
117 d = DOT(v, v);
118
119 if (d == 0.0)
120 return(0.0);
121
122 if ((d <= 1.0+FTINY) & (d >= 1.0-FTINY)) {
123 len = 0.5 + 0.5*d; /* first order approximation */
124 d = 2.0 - len;
125 } else {
126 len = sqrt(d);
127 d = 1.0/len;
128 }
129 v[0] *= d;
130 v[1] *= d;
131 v[2] *= d;
132
133 return(len);
134 }
135
136
137 int
138 closestapproach( /* closest approach of two rays */
139 RREAL t[2], /* returned distances along each ray */
140 const FVECT rorg0, /* first origin */
141 const FVECT rdir0, /* first direction (normalized) */
142 const FVECT rorg1, /* second origin */
143 const FVECT rdir1 /* second direction (normalized) */
144 )
145 {
146 double dotprod = DOT(rdir0, rdir1);
147 double denom = 1. - dotprod*dotprod;
148 double o1o2_d1;
149 FVECT o0o1;
150
151 if (denom <= FTINY) { /* check if lines are parallel */
152 t[0] = t[1] = 0.0;
153 return(0);
154 }
155 VSUB(o0o1, rorg0, rorg1);
156 o1o2_d1 = DOT(o0o1, rdir1);
157 t[0] = (o1o2_d1*dotprod - DOT(o0o1,rdir0)) / denom;
158 t[1] = o1o2_d1 + t[0]*dotprod;
159 return(1);
160 }
161
162
163 void
164 spinvector( /* rotate vector around normal */
165 FVECT vres, /* returned vector (same magnitude as vorig) */
166 const FVECT vorig, /* original vector */
167 const FVECT vnorm, /* normalized vector for rotation */
168 double theta /* right-hand radians */
169 )
170 {
171 double sint, cost, normprod;
172 FVECT vperp;
173 int i;
174
175 if (theta == 0.0) {
176 if (vres != vorig)
177 VCOPY(vres, vorig);
178 return;
179 }
180 cost = cos(theta);
181 sint = sin(theta);
182 normprod = DOT(vorig, vnorm)*(1.-cost);
183 fcross(vperp, vnorm, vorig);
184 for (i = 0; i < 3; i++)
185 vres[i] = vorig[i]*cost + vnorm[i]*normprod + vperp[i]*sint;
186 }
187
188 double
189 geodesic( /* rotate vector on great circle towards target */
190 FVECT vres, /* returned vector (same magnitude as vorig) */
191 const FVECT vorig, /* original vector */
192 const FVECT vtarg, /* vector we are rotating towards */
193 double t, /* amount along arc directed towards vtarg */
194 int meas /* distance measure (radians, absolute, relative) */
195 )
196 {
197 FVECT normtarg;
198 double volen, dotprod, sint, cost;
199 int i;
200
201 VCOPY(normtarg, vtarg); /* in case vtarg==vres */
202 if (vres != vorig)
203 VCOPY(vres, vorig);
204 if (t == 0.0)
205 return(VLEN(vres)); /* no rotation requested */
206 if ((volen = normalize(vres)) == 0.0)
207 return(0.0);
208 if (normalize(normtarg) == 0.0)
209 return(0.0); /* target vector is zero */
210 dotprod = DOT(vres, normtarg);
211 /* check for colinear */
212 if (dotprod >= 1.0-FTINY*FTINY) {
213 if (meas != GEOD_REL)
214 return(0.0);
215 vres[0] *= volen; vres[1] *= volen; vres[2] *= volen;
216 return(volen);
217 }
218 if (dotprod <= -1.0+FTINY*FTINY)
219 return(0.0);
220 if (meas == GEOD_ABS)
221 t /= volen;
222 else if (meas == GEOD_REL)
223 t *= acos(dotprod);
224 cost = cos(t);
225 sint = sin(t);
226 for (i = 0; i < 3; i++)
227 vres[i] = volen*( cost*vres[i] +
228 sint*(normtarg[i] - dotprod*vres[i]) );
229
230 return(volen); /* return vector length */
231 }
