refactor: Switched to using irandom() where appropriate
Made it so we'll never generate another segfault from this code
Minor optimization on last change
Minor fixes should not affect operation
Added more use of macros
Fixed interface for determining BSDF solid angles
Improved speed of near-normalized approximation
Removed some dead code.
Eliminated FTINY test in normalize(), comparing to zero instead
Added epsilon back to normalize() test
Wrote closestapproach() function to find closest point for two rays
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
modest efficiency improvements
changed static variables to register
added first order approximation for sqrt() to normalize()
improved efficiency of spinvector() slightly
added spinvector()
added fvsum() to compute v0+f*v1
changed length test to absolute zero
removed conditional code from normalize()
