root/radiance/ray/src/common/fropen.c
Thu Dec 19 16:38:12 2013 UTC (10 years, 5 months ago) by greg
Changes since 2.15: +5 -4 lines
Diff to previous 2.15 , to selected 2.10
Fri Jun 29 23:09:06 2012 UTC (11 years, 10 months ago) by greg
Fixed check of absolute paths for frlibopen() under Windows
Tue Aug 26 04:24:26 2003 UTC (20 years, 9 months ago) by greg
Changes since 2.13: +2 -3 lines
Minor improvements
Mon Jun 30 18:18:22 2003 UTC (20 years, 10 months ago) by greg
Removed stray strcpy() declarations
Tue May 13 17:58:32 2003 UTC (21 years ago) by greg
Changes since 2.7: +60 -4 lines
Wed Mar 1 10:40:17 1995 UTC (29 years, 3 months ago) by greg
changed fropen() call to frlibopen()
Thu Apr 14 04:44:45 1994 UTC (30 years, 1 month ago) by greg
Changes since 2.5: +2 -10 lines
Tue Sep 8 10:04:29 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.4: +4 -4 lines
Tue Sep 8 09:09:23 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.3: +3 -14 lines
Tue Jun 16 13:07:45 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.2: +12 -9 lines
added macros for directory and path separation characters
Tue Jun 16 13:06:58 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.1: +5 -2 lines
added escape character
Tue Nov 12 16:54:47 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.2 , to selected 2.10
Sun Dec 9 09:21:05 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.1: +7 -6 lines
Diff to previous 1.1 , to selected 2.10
made libpath global so it could be set before call
Sat Dec 8 09:28:15 1990 UTC (33 years, 5 months ago) by greg
Diff to selected 2.10
