fix: syntax(!)
feat: added maximum # glyph vertices for font
fix: removed reference to errmsg[], which was causing link errors
fix: switched call back from fprintf() to eputs() for error messages
refactor: made font load errors non-fatal
chore: added ANSI function prototypes
Made error messages more consistent when library file not found
Fixed missing R_OK definition under Unix
Small fixes to reduce warnings. Added bmpfile.c to SConscript.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added comments to font file using new fgetval() routine
fixed problem with hexbit font (spacing from 256 to 255 per char)
fixed similar bug to 2.7 in squeeztext() that returned wrong width
fixed bug in proptext() that caused it to report incorrect width
added global free routines
Changes for PC port
changed proptext() so that zero can be given for nsi to mean inf.
finally got proptext() working
added top and bottom and changed beg, end to left, right
