root/radiance/ray/src/common/font.c
Fri Mar 26 23:04:23 2004 UTC (21 years, 4 months ago) by greg
Changes since 2.18: +2 -1 lines
Diff to previous 2.18 , to selected 2.17
Fixed missing R_OK definition under Unix
Fri Mar 26 21:29:19 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.17: +3 -1 lines
Diff to previous 2.17
Small fixes to reduce warnings. Added bmpfile.c to SConscript.
Revision 2.17 - (view) (download) (annotate) - [selected]
Fri Nov 14 17:22:06 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 2.16: +5 -5 lines
Diff to previous 2.16
Sun Jul 27 22:12:01 2003 UTC (22 years ago) by schorsch
Diff to previous 2.15 , to selected 2.17
Sat Jun 7 12:50:20 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.14 , to selected 2.17
Tue May 13 17:58:32 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 2.13 , to selected 2.17
Tue Feb 25 02:47:21 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.12: +1 -56 lines
Diff to previous 2.12 , to selected 2.17
Sat Feb 22 02:07:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.11: +78 -16 lines
Diff to previous 2.11 , to selected 2.17
Fri Jun 30 16:06:40 1995 UTC (30 years, 1 month ago) by greg
Changes since 2.10: +6 -12 lines
Diff to previous 2.10 , to selected 2.17
added comments to font file using new fgetval() routine
Thu May 25 15:14:03 1995 UTC (30 years, 2 months ago) by greg
Diff to previous 2.9 , to selected 2.17
fixed problem with hexbit font (spacing from 256 to 255 per char)
Thu Apr 14 04:44:43 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.8: +2 -4 lines
Diff to previous 2.8 , to selected 2.17
Thu May 20 14:32:50 1993 UTC (32 years, 2 months ago) by greg
Diff to previous 2.7 , to selected 2.17
fixed similar bug to 2.7 in squeeztext() that returned wrong width
Fri May 14 11:30:17 1993 UTC (32 years, 2 months ago) by greg
Changes since 2.6: +2 -4 lines
Diff to previous 2.6 , to selected 2.17
fixed bug in proptext() that caused it to report incorrect width
Sat Nov 21 21:35:36 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.5: +23 -0 lines
Diff to previous 2.5 , to selected 2.17
added global free routines
Mon Sep 21 12:02:03 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.4: +5 -3 lines
Diff to previous 2.4 , to selected 2.17
Changes for PC port
Wed Jun 24 19:01:00 1992 UTC (33 years, 1 month ago) by greg
Diff to previous 2.3 , to selected 2.17
changed proptext() so that zero can be given for nsi to mean inf.
Wed Jun 24 17:52:58 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.2: +72 -6 lines
Diff to previous 2.2 , to selected 2.17
finally got proptext() working
Tue Jun 16 13:16:50 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.1: +58 -7 lines
Diff to previous 2.1 , to selected 2.17
added top and bottom and changed beg, end to left, right
Sat Jun 6 07:38:40 1992 UTC (33 years, 2 months ago) by greg
Diff to selected 2.17
