root/radiance/ray/src/common/fltdepth.c
Revision: 3.5
Committed: Thu Mar 5 17:37:09 2020 UTC (4 years, 2 months ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
Changes since 3.4: +8 -9 lines
Minor change should have no effect on results
# User Rev Content
1 greg 3.2 #ifndef lint
2 greg 3.5 static const char RCSid[] = "$Id: fltdepth.c,v 3.4 2019/11/11 16:45:30 greg Exp $";
3 greg 3.2 #endif
4 greg 3.1 /*
5     * Function to open floating-point depth file, making sure it's
6     * the correct length, and converting from encoded 16-bit
7     * depth into a temporary file if needed
8     */
9
10     #include "rtio.h"
11     #include "paths.h"
12
13     #if defined(_WIN32) || defined(_WIN64)
14
15     #include "platform.h"
16
17     /* Return file descriptor for open raw float file, or -1 on error */
18     /* Set expected_length to width*height, or 0 if unknown */
19     /* We don't translate encoded depth under Windows because of temp file issue */
20     int
21     open_float_depth(const char *fname, long expected_length)
22     {
23     int fd = open(fname, O_RDONLY|O_BINARY);
24
25 greg 3.4 if (fd < 0) {
26     fprintf(stderr, "%s: cannot open for reading\n", fname);
27 greg 3.1 return(-1);
28 greg 3.4 }
29 greg 3.1 if (expected_length > 0) {
30     off_t flen = lseek(fd, 0, SEEK_END);
31     if (flen != expected_length*sizeof(float)) {
32     fprintf(stderr, "%s: expected length is %ld, actual length is %ld\n",
33     fname, expected_length, (long)(flen/sizeof(float)));
34     close(fd);
35     return(-1);
36     }
37     lseek(fd, 0, SEEK_SET);
38     }
39     return(fd);
40     }
41
42     #else /* ! defined(_WIN32) || defined(_WIN64) */
43
44     #include <ctype.h>
45     #include "fvect.h"
46     #include "depthcodec.h"
47
48     #define FBUFLEN 1024 /* depth conversion batch size */
49
50     /* Return file descriptor for open raw float file, or -1 on error */
51     /* Set expected_length to width*height, or 0 if unknown */
52     int
53     open_float_depth(const char *fname, long expected_length)
54     {
55     char buf[FBUFLEN*sizeof(float)];
56     DEPTHCODEC dc;
57     ssize_t n, nleft;
58     int fd = open(fname, O_RDONLY);
59
60 greg 3.4 if (fd < 0) {
61     perror(fname);
62 greg 3.1 return(-1);
63 greg 3.4 }
64 greg 3.1 dc.finp = NULL;
65     if (expected_length <= 0) { /* need to sniff file? */
66     extern const char HDRSTR[];
67     const int len = strlen(HDRSTR);
68 greg 3.3 if (read(fd, buf, len+1) < len+1)
69 greg 3.4 goto badEOF;
70 greg 3.1 if (lseek(fd, 0, SEEK_SET) != 0)
71     goto seek_error;
72     for (n = 0; n < len; n++)
73     if (buf[n] != HDRSTR[n])
74     break;
75 greg 3.3 if ((n < len) | !isprint(buf[len]))
76 greg 3.1 return(fd); /* unknown length raw float... */
77     } else {
78     off_t flen = lseek(fd, 0, SEEK_END);
79     if (flen < 0 || lseek(fd, 0, SEEK_SET) != 0)
80     goto seek_error;
81     if (flen == expected_length*sizeof(float))
82     return(fd); /* it's the right length for raw */
83     }
84     /* We're thinking it's an encoded depth file at this point... */
85     set_dc_defaults(&dc); /* load & convert if we can */
86     dc.finp = fdopen(fd, "r");
87     if (!dc.finp) { /* out of memory?? */
88     perror("fdopen");
89     close(fd);
90     return(-1);
91     }
92     dc.inpname = fname; /* check encoded depth header */
93     dc.hdrflags = HF_HEADIN|HF_RESIN|HF_STDERR;
94     if (!process_dc_header(&dc, 0, NULL) || !check_decode_depths(&dc)) {
95     fclose(dc.finp); /* already reported error */
96     return(-1);
97     }
98 greg 3.3 if ((expected_length > 0) &
99     ((long)dc.res.xr*dc.res.yr != expected_length)) {
100 greg 3.1 fprintf(stderr, "%s: expected length is %ld, actual length is %ld\n",
101 greg 3.3 fname, expected_length, (long)dc.res.xr*dc.res.yr);
102 greg 3.1 fclose(dc.finp);
103     return(-1);
104     }
105     strcpy(buf, TEMPLATE); /* create temporary file to hold raw */
106     fd = mkstemp(buf);
107     if (fd < 0) {
108 greg 3.3 perror(buf);
109 greg 3.1 fclose(dc.finp);
110     return(-1);
111     }
112 greg 3.3 unlink(buf); /* preemptive remove (Windows forbids) */
113 greg 3.1 for (nleft = (ssize_t)dc.res.xr*dc.res.yr; nleft > 0; nleft -= FBUFLEN) {
114     for (n = 0; n < FBUFLEN; n++) {
115     double d = decode_depth_next(&dc);
116 greg 3.5 if (d < -FTINY) {
117 greg 3.1 if (n < nleft)
118 greg 3.4 goto badEOF;
119 greg 3.1 break;
120     }
121 greg 3.3 ((float *)buf)[n] = d;
122 greg 3.1 }
123     n *= sizeof(float);
124     if (write(fd, buf, n) != n) {
125     perror("write");
126     fclose(dc.finp);
127     close(fd);
128     return(-1);
129     }
130     }
131     fclose(dc.finp); /* all done -- clean up */
132 greg 3.5 if (lseek(fd, 0, SEEK_SET) == 0)
133     return(fd);
134     seek_error:
135     perror("lseek");
136     close(fd);
137     return(-1);
138 greg 3.4 badEOF:
139 greg 3.1 fputs(fname, stderr);
140     fputs(": unexpected end-of-file\n", stderr);
141     if (dc.finp) fclose(dc.finp);
142     close(fd);
143     return(-1);
144     }
145
146 greg 3.2 #endif
