root/radiance/ray/src/common/fltdepth.c
Revision: 3.3
Committed: Fri Nov 8 17:08:21 2019 UTC (4 years, 6 months ago) by greg
Changes since 3.2: +9 -10 lines
Minor changes should not affect behavior
2 static const char RCSid[] = "$Id: fltdepth.c,v 3.2 2019/11/07 23:33:45 greg Exp $";
5 * Function to open floating-point depth file, making sure it's
6 * the correct length, and converting from encoded 16-bit
7 * depth into a temporary file if needed
8 */
9
10 #include "rtio.h"
11 #include "paths.h"
12
13 #if defined(_WIN32) || defined(_WIN64)
14
15 #include "platform.h"
16
17 /* Return file descriptor for open raw float file, or -1 on error */
18 /* Set expected_length to width*height, or 0 if unknown */
19 /* We don't translate encoded depth under Windows because of temp file issue */
20 int
21 open_float_depth(const char *fname, long expected_length)
22 {
23 int fd = open(fname, O_RDONLY|O_BINARY);
24
25 if (fd < 0)
26 return(-1);
27 if (expected_length > 0) {
28 off_t flen = lseek(fd, 0, SEEK_END);
29 if (flen != expected_length*sizeof(float)) {
30 fprintf(stderr, "%s: expected length is %ld, actual length is %ld\n",
31 fname, expected_length, (long)(flen/sizeof(float)));
32 close(fd);
33 return(-1);
34 }
35 lseek(fd, 0, SEEK_SET);
36 }
37 return(fd);
38 }
39
40 #else /* ! defined(_WIN32) || defined(_WIN64) */
41
42 #include <ctype.h>
43 #include "fvect.h"
44 #include "depthcodec.h"
45
46 #define FBUFLEN 1024 /* depth conversion batch size */
47
48 /* Return file descriptor for open raw float file, or -1 on error */
49 /* Set expected_length to width*height, or 0 if unknown */
50 int
51 open_float_depth(const char *fname, long expected_length)
52 {
53 char buf[FBUFLEN*sizeof(float)];
54 DEPTHCODEC dc;
55 ssize_t n, nleft;
56 int fd = open(fname, O_RDONLY);
57
58 if (fd < 0)
59 return(-1);
60 dc.finp = NULL;
61 if (expected_length <= 0) { /* need to sniff file? */
62 extern const char HDRSTR[];
63 const int len = strlen(HDRSTR);
64 if (read(fd, buf, len+1) < len+1)
65 goto gotEOF;
66 if (lseek(fd, 0, SEEK_SET) != 0)
67 goto seek_error;
68 for (n = 0; n < len; n++)
69 if (buf[n] != HDRSTR[n])
70 break;
71 if ((n < len) | !isprint(buf[len]))
72 return(fd); /* unknown length raw float... */
73 } else {
74 off_t flen = lseek(fd, 0, SEEK_END);
75 if (flen < 0 || lseek(fd, 0, SEEK_SET) != 0)
76 goto seek_error;
77 if (flen == expected_length*sizeof(float))
78 return(fd); /* it's the right length for raw */
79 }
80 /* We're thinking it's an encoded depth file at this point... */
81 set_dc_defaults(&dc); /* load & convert if we can */
82 dc.finp = fdopen(fd, "r");
83 if (!dc.finp) { /* out of memory?? */
84 perror("fdopen");
85 close(fd);
86 return(-1);
87 }
88 dc.inpname = fname; /* check encoded depth header */
89 dc.hdrflags = HF_HEADIN|HF_RESIN|HF_STDERR;
90 if (!process_dc_header(&dc, 0, NULL) || !check_decode_depths(&dc)) {
91 fclose(dc.finp); /* already reported error */
92 return(-1);
93 }
94 if ((expected_length > 0) &
95 ((long)dc.res.xr*dc.res.yr != expected_length)) {
96 fprintf(stderr, "%s: expected length is %ld, actual length is %ld\n",
97 fname, expected_length, (long)dc.res.xr*dc.res.yr);
98 fclose(dc.finp);
99 return(-1);
100 }
101 strcpy(buf, TEMPLATE); /* create temporary file to hold raw */
102 fd = mkstemp(buf);
103 if (fd < 0) {
104 perror(buf);
105 fclose(dc.finp);
106 return(-1);
107 }
108 unlink(buf); /* preemptive remove (Windows forbids) */
109 for (nleft = (ssize_t)dc.res.xr*dc.res.yr; nleft > 0; nleft -= FBUFLEN) {
110 for (n = 0; n < FBUFLEN; n++) {
111 double d = decode_depth_next(&dc);
112 if (d < 0) {
113 if (n < nleft)
114 goto gotEOF;
115 break;
116 }
117 ((float *)buf)[n] = d;
118 }
119 n *= sizeof(float);
120 if (write(fd, buf, n) != n) {
121 perror("write");
122 fclose(dc.finp);
123 close(fd);
124 return(-1);
125 }
126 }
127 fclose(dc.finp); /* all done -- clean up */
128 if (lseek(fd, 0, SEEK_SET) != 0)
129 goto seek_error;
130 return(fd);
131 gotEOF:
132 fputs(fname, stderr);
133 fputs(": unexpected end-of-file\n", stderr);
134 if (dc.finp) fclose(dc.finp);
135 close(fd);
136 return(-1);
137 seek_error:
138 perror("lseek");
139 close(fd);
140 return(-1);
141 }
142
143 #endif
