| 1 |
| 2 |
* Function to open floating-point depth file, making sure it's
| 3 |
* the correct length, and converting from encoded 16-bit
| 4 |
* depth into a temporary file if needed
| 5 |
| 6 |
| 7 |
#include "rtio.h"
| 8 |
#include "paths.h"
| 9 |
| 10 |
#if defined(_WIN32) || defined(_WIN64)
| 11 |
| 12 |
#include "platform.h"
| 13 |
| 14 |
/* Return file descriptor for open raw float file, or -1 on error */
| 15 |
/* Set expected_length to width*height, or 0 if unknown */
| 16 |
/* We don't translate encoded depth under Windows because of temp file issue */
| 17 |
int
| 18 |
open_float_depth(const char *fname, long expected_length)
| 19 |
| 20 |
int fd = open(fname, O_RDONLY|O_BINARY);
| 21 |
| 22 |
if (fd < 0)
| 23 |
return(-1);
| 24 |
if (expected_length > 0) {
| 25 |
off_t flen = lseek(fd, 0, SEEK_END);
| 26 |
if (flen != expected_length*sizeof(float)) {
| 27 |
fprintf(stderr, "%s: expected length is %ld, actual length is %ld\n",
| 28 |
fname, expected_length, (long)(flen/sizeof(float)));
| 29 |
close(fd);
| 30 |
return(-1);
| 31 |
| 32 |
lseek(fd, 0, SEEK_SET);
| 33 |
| 34 |
return(fd);
| 35 |
| 36 |
| 37 |
#else /* ! defined(_WIN32) || defined(_WIN64) */
| 38 |
| 39 |
#include <ctype.h>
| 40 |
#include "fvect.h"
| 41 |
#include "depthcodec.h"
| 42 |
| 43 |
#define FBUFLEN 1024 /* depth conversion batch size */
| 44 |
| 45 |
| 46 |
| 47 |
int
| 48 |
| 49 |
| 50 |
char buf[FBUFLEN*sizeof(float)];
| 51 |
DEPTHCODEC dc;
| 52 |
ssize_t n, nleft;
| 53 |
int fd = open(fname, O_RDONLY);
| 54 |
| 55 |
if (fd < 0)
| 56 |
return(-1);
| 57 |
dc.finp = NULL;
| 58 |
if (expected_length <= 0) { /* need to sniff file? */
| 59 |
extern const char HDRSTR[];
| 60 |
const int len = strlen(HDRSTR);
| 61 |
n = read(fd, buf, len+1);
| 62 |
if (n < len+1)
| 63 |
goto gotEOF;
| 64 |
if (lseek(fd, 0, SEEK_SET) != 0)
| 65 |
goto seek_error;
| 66 |
for (n = 0; n < len; n++)
| 67 |
if (buf[n] != HDRSTR[n])
| 68 |
break;
| 69 |
if (n < len || !isprint(buf[len]))
| 70 |
return(fd); /* unknown length raw float... */
| 71 |
} else {
| 72 |
| 73 |
if (flen < 0 || lseek(fd, 0, SEEK_SET) != 0)
| 74 |
goto seek_error;
| 75 |
if (flen == expected_length*sizeof(float))
| 76 |
return(fd); /* it's the right length for raw */
| 77 |
| 78 |
/* We're thinking it's an encoded depth file at this point... */
| 79 |
set_dc_defaults(&dc); /* load & convert if we can */
| 80 |
dc.finp = fdopen(fd, "r");
| 81 |
if (!dc.finp) { /* out of memory?? */
| 82 |
perror("fdopen");
| 83 |
close(fd);
| 84 |
return(-1);
| 85 |
| 86 |
dc.inpname = fname; /* check encoded depth header */
| 87 |
dc.hdrflags = HF_HEADIN|HF_RESIN|HF_STDERR;
| 88 |
if (!process_dc_header(&dc, 0, NULL) || !check_decode_depths(&dc)) {
| 89 |
fclose(dc.finp); /* already reported error */
| 90 |
return(-1);
| 91 |
| 92 |
if (expected_length > 0 && (long)dc.res.xr*dc.res.yr != expected_length) {
| 93 |
| 94 |
fname, (long)expected_length, (long)dc.res.xr*dc.res.yr);
| 95 |
fclose(dc.finp);
| 96 |
return(-1);
| 97 |
| 98 |
strcpy(buf, TEMPLATE); /* create temporary file to hold raw */
| 99 |
fd = mkstemp(buf);
| 100 |
if (fd < 0) {
| 101 |
fputs(buf, stderr);
| 102 |
fputs(": cannot create temporary file\n", stderr);
| 103 |
fclose(dc.finp);
| 104 |
return(-1);
| 105 |
| 106 |
unlink(buf); /* unlink it now (Windows forbids) */
| 107 |
for (nleft = (ssize_t)dc.res.xr*dc.res.yr; nleft > 0; nleft -= FBUFLEN) {
| 108 |
for (n = 0; n < FBUFLEN; n++) {
| 109 |
double d = decode_depth_next(&dc);
| 110 |
if (d < 0) {
| 111 |
if (n < nleft)
| 112 |
goto gotEOF;
| 113 |
break;
| 114 |
| 115 |
((float *)buf)[n] = (float)d;
| 116 |
| 117 |
n *= sizeof(float);
| 118 |
if (write(fd, buf, n) != n) {
| 119 |
perror("write");
| 120 |
fclose(dc.finp);
| 121 |
close(fd);
| 122 |
return(-1);
| 123 |
| 124 |
| 125 |
fclose(dc.finp); /* all done -- clean up */
| 126 |
| 127 |
goto seek_error;
| 128 |
return(fd);
| 129 |
gotEOF:
| 130 |
fputs(fname, stderr);
| 131 |
fputs(": unexpected end-of-file\n", stderr);
| 132 |
if (dc.finp) fclose(dc.finp);
| 133 |
close(fd);
| 134 |
return(-1);
| 135 |
seek_error:
| 136 |
perror("lseek");
| 137 |
close(fd);
| 138 |
return(-1);
| 139 |
| 140 |
| 141 |
#endif |
