root/radiance/ray/src/common/fixargv0.c
Fri Jul 24 16:58:16 2020 UTC (3 years, 9 months ago) by greg
Hopeful fix to Windows test issues
Fri Aug 5 00:12:46 2016 UTC (7 years, 8 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.7: +5 -10 lines
Minor fixes for Windows suggested by Nathaniel Jones
Sun Mar 20 16:36:17 2016 UTC (8 years, 1 month ago) by schorsch
Changes since 2.6: +6 -3 lines
copy from testfile, don't retype...
Sat Mar 19 00:44:46 2016 UTC (8 years, 1 month ago) by schorsch
When argv is dynamically allocated, changing the pointer values crashes deallocation (yes, I'm doing weird things).
Tue Oct 21 19:19:28 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 2.2: +1 -56 lines
Changes since 2.1: +60 -4 lines
Diff to previous 2.1
Fri Oct 9 10:27:41 1992 UTC (31 years, 6 months ago) by greg
