root/radiance/ray/src/common/fixargv0.c
Revision: 2.8
Committed: Fri Aug 5 00:12:46 2016 UTC (8 years, 8 months ago) by greg
CVS Tags: rad5R2, rad5R1
Changes since 2.7: +5 -10 lines
Minor fixes for Windows suggested by Nathaniel Jones
2 static const char RCSid[] = "$Id: fixargv0.c,v 2.7 2016/03/20 16:36:17 schorsch Exp $";
5 * Fix argv[0] for DOS environments
6 *
7 * External symbols declared in paths.h
8 */
9
10 #include <ctype.h>
11 #include <string.h>
12
13 char *
14 fixargv0(char *av0) /* extract command name from full path */
15 {
16 char *cp = av0, *end;
17
18 while (*cp) cp++; /* start from end */
19 end = cp;
20 while (cp-- > av0)
21 switch (*cp) { /* fix up command name */
22 case '.': /* remove extension */
23 *cp = '\0';
24 end = cp;
25 continue;
26 case '\\': /* remove directory */
27 /* make sure the original pointer remains the same */
28 memmove(av0, cp+1, end-cp);
29 return(av0);
30 default: /* convert to lower case */
31 *cp = tolower(*cp);
32 continue;
33 }
34 return(av0);
35 }
