| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: fixargv0.c,v 2.7 2016/03/20 16:36:17 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Fix argv[0] for DOS environments
| 6 |
| 7 |
* External symbols declared in paths.h
| 8 |
| 9 |
| 10 |
#include <ctype.h>
| 11 |
#include <string.h>
| 12 |
| 13 |
char *
| 14 |
fixargv0(char *av0) /* extract command name from full path */
| 15 |
| 16 |
char *cp = av0, *end;
| 17 |
| 18 |
while (*cp) cp++; /* start from end */
| 19 |
end = cp;
| 20 |
while (cp-- > av0)
| 21 |
switch (*cp) { /* fix up command name */
| 22 |
case '.': /* remove extension */
| 23 |
*cp = '\0';
| 24 |
end = cp;
| 25 |
continue;
| 26 |
case '\\': /* remove directory */
| 27 |
/* make sure the original pointer remains the same */
| 28 |
memmove(av0, cp+1, end-cp);
| 29 |
return(av0);
| 30 |
default: /* convert to lower case */
| 31 |
*cp = tolower(*cp);
| 32 |
continue;
| 33 |
| 34 |
return(av0);
| 35 |
