root/Development/ray/src/common/fixargv0.c
Revision: 2.9
Committed: Fri Jul 24 16:58:16 2020 UTC (5 years, 4 months ago) by greg
CVS Tags: rad5R4, rad5R3
Hopeful fix to Windows test issues
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.9 static const char RCSid[] = "$Id: fixargv0.c,v 2.8 2016/08/05 00:12:46 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Fix argv[0] for DOS environments
6 greg 2.2 *
7 schorsch 2.4 * External symbols declared in paths.h
8 greg 2.2 */
9
10 schorsch 2.4 #include <ctype.h>
11 schorsch 2.6 #include <string.h>
12 greg 2.1
13 greg 2.8 char *
14     fixargv0(char *av0) /* extract command name from full path */
15 greg 2.1 {
16 greg 2.8 char *cp = av0, *end;
17 greg 2.1
18     while (*cp) cp++; /* start from end */
19 schorsch 2.7 end = cp;
20 greg 2.1 while (cp-- > av0)
21     switch (*cp) { /* fix up command name */
22     case '.': /* remove extension */
23     *cp = '\0';
24 schorsch 2.7 end = cp;
25 greg 2.1 continue;
26     case '\\': /* remove directory */
27 greg 2.9 case '/':
28 schorsch 2.7 /* make sure the original pointer remains the same */
29     memmove(av0, cp+1, end-cp);
30 greg 2.8 return(av0);
31 greg 2.1 default: /* convert to lower case */
32     *cp = tolower(*cp);
33     continue;
34     }
35     return(av0);
36     }
