root/radiance/ray/src/common/fixargv0.c
Revision: 2.6
Committed: Sat Mar 19 00:44:46 2016 UTC (9 years, 3 months ago) by schorsch
When argv is dynamically allocated, changing the pointer values crashes deallocation (yes, I'm doing weird things).
2 static const char RCSid[] = "$Id: fixargv0.c,v 2.5 2003/10/27 10:19:31 schorsch Exp $";
5 * Fix argv[0] for DOS environments
6 *
7 * External symbols declared in paths.h
8 */
9
10 #include "copyright.h"
11
12 #include <ctype.h>
13 #include <string.h>
14
15 extern char *
16 fixargv0(av0) /* extract command name from full path */
17 char *av0;
18 {
19 register char *cp = av0;
20
21 while (*cp) cp++; /* start from end */
22 while (cp-- > av0)
23 switch (*cp) { /* fix up command name */
24 case '.': /* remove extension */
25 *cp = '\0';
26 continue;
27 case '\\': /* remove directory */
28 strcpy(av0, cp+1);
29 break;
30 default: /* convert to lower case */
31 *cp = tolower(*cp);
32 continue;
33 }
34 return(av0);
35 }
36
37
