root/Development/ray/src/common/fixargv0.c
Sat Jun 7 05:09:45 2025 UTC (6 months ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.10: +26 -1 lines
Tue Jun 3 21:31:51 2025 UTC (6 months, 1 week ago) by greg
Changes since 2.9: +14 -13 lines
Fri Jul 24 16:58:16 2020 UTC (5 years, 4 months ago) by greg
CVS Tags: rad5R3, rad5R4
Hopeful fix to Windows test issues
Fri Aug 5 00:12:46 2016 UTC (9 years, 4 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.7: +5 -10 lines
Minor fixes for Windows suggested by Nathaniel Jones
Sun Mar 20 16:36:17 2016 UTC (9 years, 8 months ago) by schorsch
Changes since 2.6: +6 -3 lines
copy from testfile, don't retype...
Sat Mar 19 00:44:46 2016 UTC (9 years, 8 months ago) by schorsch
When argv is dynamically allocated, changing the pointer values crashes deallocation (yes, I'm doing weird things).
Mon Oct 27 10:19:31 2003 UTC (22 years, 1 month ago) by schorsch
Tue Oct 21 19:19:28 2003 UTC (22 years, 1 month ago) by schorsch
Tue Feb 25 02:47:21 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.2: +1 -56 lines
Sat Feb 22 02:07:22 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.1: +60 -4 lines
Fri Oct 9 10:27:41 1992 UTC (33 years, 2 months ago) by greg
