root/radiance/ray/src/common/fixargv0.c
Revision: 2.11
Committed: Sat Jun 7 05:09:45 2025 UTC (17 hours, 54 minutes ago) by greg
Changes since 2.10: +26 -1 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.11 static const char RCSid[] = "$Id: fixargv0.c,v 2.10 2025/06/03 21:31:51 greg Exp $";
3 greg 2.1 #endif
4     /*
5 greg 2.10 * Fix argv[0] and assign global progname variable
6 greg 2.2 *
7 schorsch 2.4 * External symbols declared in paths.h
8 greg 2.2 */
9
10 greg 2.11 #include "rtio.h"
11 greg 2.10 #include "paths.h"
12 schorsch 2.4 #include <ctype.h>
13 greg 2.10
14     char *progname = NULL; /* global argv[0] */
15 greg 2.1
16 greg 2.8 char *
17     fixargv0(char *av0) /* extract command name from full path */
18 greg 2.1 {
19 greg 2.10 char *cp = av0;
20 greg 2.1
21     while (*cp) cp++; /* start from end */
22 greg 2.10
23 greg 2.1 while (cp-- > av0)
24 greg 2.10 switch (*cp) {
25     CASEDIRSEP: /* remove directory */
26     av0 = cp+1;
27     break;
28     #if defined(_WIN32) || defined(_WIN64) /* only do for Windows: */
29 greg 2.1 case '.': /* remove extension */
30     *cp = '\0';
31     continue;
32     default: /* convert to lower case */
33     *cp = tolower(*cp);
34     continue;
35 greg 2.10 #endif
36 greg 2.1 }
37 greg 2.10 return(progname = av0);
38 greg 2.1 }
39 greg 2.11
40
41     void
42     printargs( /* print command arguments to a file */
43     int ac,
44     char **av,
45     FILE *fp
46     )
47     {
48     if (ac <= 0) return;
49
50     if (progname == NULL)
51     fixargv0(av[0]);
52
53     if (progname >= av[0] && progname - av[0] < strlen(av[0]))
54     fputword(progname, fp);
55     else
56     fputword(av[0], fp);
57     while (--ac > 0) {
58     fputc(' ', fp);
59     fputword(*++av, fp);
60     }
61     fputc('\n', fp);
62     }
