1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: fixargv0.c,v 2.7 2016/03/20 16:36:17 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Fix argv[0] for DOS environments |
6 |
7 |
* External symbols declared in paths.h |
8 |
9 |
10 |
#include <ctype.h> |
11 |
#include <string.h> |
12 |
13 |
char * |
14 |
fixargv0(char *av0) /* extract command name from full path */ |
15 |
16 |
char *cp = av0, *end; |
17 |
18 |
while (*cp) cp++; /* start from end */ |
19 |
end = cp; |
20 |
while (cp-- > av0) |
21 |
switch (*cp) { /* fix up command name */ |
22 |
case '.': /* remove extension */ |
23 |
*cp = '\0'; |
24 |
end = cp; |
25 |
continue; |
26 |
case '\\': /* remove directory */ |
27 |
/* make sure the original pointer remains the same */ |
28 |
memmove(av0, cp+1, end-cp); |
29 |
return(av0); |
30 |
default: /* convert to lower case */ |
31 |
*cp = tolower(*cp); |
32 |
continue; |
33 |
34 |
return(av0); |
35 |
