root/radiance/ray/src/common/fixargv0.c
Revision: 2.2
Committed: Sat Feb 22 02:07:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.1: +60 -4 lines
5 * Fix argv[0] for DOS environments
6 *
7 * External symbols declared in standard.h
8 */
9
10 /* ====================================================================
11 * The Radiance Software License, Version 1.0
12 *
13 * Copyright (c) 1990 - 2002 The Regents of the University of California,
14 * through Lawrence Berkeley National Laboratory. All rights reserved.
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 *
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 *
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in
25 * the documentation and/or other materials provided with the
26 * distribution.
27 *
28 * 3. The end-user documentation included with the redistribution,
29 * if any, must include the following acknowledgment:
30 * "This product includes Radiance software
31 * (http://radsite.lbl.gov/)
32 * developed by the Lawrence Berkeley National Laboratory
33 * (http://www.lbl.gov/)."
34 * Alternately, this acknowledgment may appear in the software itself,
35 * if and wherever such third-party acknowledgments normally appear.
36 *
37 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
38 * and "The Regents of the University of California" must
39 * not be used to endorse or promote products derived from this
40 * software without prior written permission. For written
41 * permission, please contact [email protected].
42 *
43 * 5. Products derived from this software may not be called "Radiance",
44 * nor may "Radiance" appear in their name, without prior written
45 * permission of Lawrence Berkeley National Laboratory.
46 *
47 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
48 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
49 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
50 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
51 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
52 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
53 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
54 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
55 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
56 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
57 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
58 * SUCH DAMAGE.
59 * ====================================================================
60 *
61 * This software consists of voluntary contributions made by many
62 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
63 * information on Lawrence Berkeley National Laboratory, please see
64 * <http://www.lbl.gov/>.
65 */
66
67
68 char *
69 fixargv0(av0) /* extract command name from full path */
70 char *av0;
71 {
72 register char *cp = av0;
73
74 while (*cp) cp++; /* start from end */
75 while (cp-- > av0)
76 switch (*cp) { /* fix up command name */
77 case '.': /* remove extension */
78 *cp = '\0';
79 continue;
80 case '\\': /* remove directory */
81 return(cp+1);
82 default: /* convert to lower case */
83 *cp = tolower(*cp);
84 continue;
85 }
86 return(av0);
87 }
88
89
