root/radiance/ray/src/common/fixargv0.c
Revision: 2.1
Committed: Fri Oct 9 10:27:41 1992 UTC (32 years, 9 months ago) by greg
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Fix argv[0] for DOS environments
9 */
10
11
12 char *
13 fixargv0(av0) /* extract command name from full path */
14 char *av0;
15 {
16 register char *cp = av0;
17
18 while (*cp) cp++; /* start from end */
19 while (cp-- > av0)
20 switch (*cp) { /* fix up command name */
21 case '.': /* remove extension */
22 *cp = '\0';
23 continue;
24 case '\\': /* remove directory */
25 return(cp+1);
26 default: /* convert to lower case */
27 *cp = tolower(*cp);
28 continue;
29 }
30 return(av0);
31 }
32
33
