root/radiance/ray/src/common/fdate.c
Fri Jun 27 06:53:21 2003 UTC (21 years, 11 months ago) by greg
Sun Jun 8 12:03:09 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.6: +13 -2 lines
Tue Feb 25 02:47:21 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.4: +60 -4 lines
Mon Oct 24 13:47:25 1994 UTC (30 years, 7 months ago) by greg
Changes since 2.3: +14 -1 lines
added setfdate function
Mon Nov 22 09:31:59 1993 UTC (31 years, 6 months ago) by greg
compatibility fix
Wed Sep 15 15:36:25 1993 UTC (31 years, 8 months ago) by greg
Diff to previous 2.1
changed non-existent file return from -1 to 0
Wed Mar 10 19:39:54 1993 UTC (32 years, 2 months ago) by greg
