| 1 |
/* RCSid $Id: falsecolor.h,v 3.2 2005/11/15 06:52:38 greg Exp $ */
| 2 |
| 3 |
* Header file for false color tone-mapping.
| 4 |
| 5 |
* Include after "color.h" and "tonemap.h"
| 6 |
| 7 |
#ifndef _RAD_FALSECOLOR_H_
| 8 |
#define _RAD_FALSECOLOR_H_
| 9 |
| 10 |
#ifdef __cplusplus
| 11 |
extern "C" {
| 12 |
#endif
| 13 |
/* false color mapping data structure */
| 14 |
typedef struct {
| 15 |
TMbright mbrmin, mbrmax; /* mapped min. & max. brightnesses */
| 16 |
BYTE *lumap; /* false color luminance map */
| 17 |
BYTE (*scale)[3]; /* false color ordinal scale */
| 18 |
} FCstruct;
| 19 |
| 20 |
extern BYTE fcDefaultScale[256][3]; /* default false color scale */
| 21 |
| 22 |
extern FCstruct *
| 23 |
fcInit(BYTE fcscale[256][3]);
| 24 |
| 25 |
Allocate and initialize false color mapping data structure.
| 26 |
| 27 |
fcscale - false color ordinal scale.
| 28 |
| 29 |
returns - new false color mapping pointer, or NULL if no memory.
| 30 |
| 31 |
| 32 |
extern int
| 33 |
fcFixedLinear(FCstruct *fcs, double Lwmax);
| 34 |
| 35 |
Assign fixed linear false color map.
| 36 |
| 37 |
fcs - false color structure pointer.
| 38 |
Lwmax - maximum luminance for scaling
| 39 |
| 40 |
returns - 0 on success, TM_E_* on failure.
| 41 |
| 42 |
| 43 |
extern int
| 44 |
fcFixedLog(FCstruct *fcs, double Lwmin, double Lwmax);
| 45 |
| 46 |
Assign fixed logarithmic false color map.
| 47 |
| 48 |
| 49 |
Lwmin - minimum luminance for scaling
| 50 |
| 51 |
| 52 |
| 53 |
| 54 |
| 55 |
extern int
| 56 |
fcLinearMapping(FCstruct *fcs, TMstruct *tms, double pctile);
| 57 |
| 58 |
Compute linear false color map.
| 59 |
| 60 |
| 61 |
tms - tone mapping structure pointer, with histogram.
| 62 |
pctile - percentile to ignore on top
| 63 |
| 64 |
| 65 |
| 66 |
| 67 |
extern int
| 68 |
fcLogMapping(FCstruct *fcs, TMstruct *tms, double pctile);
| 69 |
| 70 |
Compute logarithmic false color map.
| 71 |
| 72 |
| 73 |
| 74 |
pctile - percentile to ignore on top and bottom
| 75 |
| 76 |
| 77 |
| 78 |
| 79 |
extern int
| 80 |
fcMapPixels(FCstruct *fcs, BYTE *ps, TMbright *ls, int len);
| 81 |
| 82 |
Apply false color mapping to pixel values.
| 83 |
| 84 |
| 85 |
ps - returned RGB pixel values.
| 86 |
ls - encoded luminance values.
| 87 |
len - number of pixels.
| 88 |
| 89 |
| 90 |
| 91 |
| 92 |
extern int
| 93 |
fcIsLogMap(FCstruct *fcs);
| 94 |
| 95 |
Determine if false color mapping is logarithmic.
| 96 |
| 97 |
| 98 |
| 99 |
returns - 1 if map follows logarithmic mapping, -1 on error.
| 100 |
| 101 |
| 102 |
extern FCstruct *
| 103 |
fcDup(FCstruct *fcs);
| 104 |
| 105 |
Duplicate a false color structure.
| 106 |
| 107 |
| 108 |
| 109 |
returns - duplicate structure, or NULL if no memory.
| 110 |
| 111 |
| 112 |
extern void
| 113 |
fcDone(FCstruct *fcs);
| 114 |
| 115 |
Free data associated with the given false color mapping structure.
| 116 |
| 117 |
fcs - false color mapping structure to free.
| 118 |
| 119 |
| 120 |
#ifdef __cplusplus
| 121 |
| 122 |
#endif
| 123 |
#endif /* _RAD_FALSECOLOR_H_ */
