root/radiance/ray/src/common/falsecolor.c
Fri May 20 02:06:38 2011 UTC (12 years, 11 months ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Changes since 3.9: +8 -8 lines
Diff to previous 3.9 , to selected 3.3
Thu Jul 3 03:35:10 2008 UTC (15 years, 10 months ago) by greg
Changes since 3.8: +3 -3 lines
Diff to previous 3.8 , to selected 3.3
Another cosmetic improvement similar to last
Thu Jul 3 03:30:21 2008 UTC (15 years, 10 months ago) by greg
Changes since 3.7: +5 -5 lines
Diff to previous 3.7 , to selected 3.3
Cosmetic simplification to history array access
Thu Jan 26 03:33:16 2006 UTC (18 years, 3 months ago) by greg
CVS Tags: rad3R8, rad3R9
Diff to previous 3.6 , to selected 3.3
Better fix in IsLogMap()
Thu Jan 26 03:13:36 2006 UTC (18 years, 3 months ago) by greg
Changes since 3.5: +11 -7 lines
Diff to previous 3.5 , to selected 3.3
Bug fix in fcIsLogMap() for small max/min ratios
Fri Nov 18 22:50:20 2005 UTC (18 years, 5 months ago) by greg
Changes since 3.4: +257 -257 lines
Diff to previous 3.4 , to selected 3.3
Made false color scale less bloody than before
Wed Nov 16 08:30:15 2005 UTC (18 years, 5 months ago) by greg
Changes since 3.3: +28 -18 lines
Diff to previous 3.3
Fixed bug in TMstruct-based false color mappings
Revision 3.3 - (view) (download) (annotate) - [selected]
Tue Nov 15 20:04:50 2005 UTC (18 years, 5 months ago) by greg
Changes since 3.2: +264 -50 lines
Diff to previous 3.2
Bug fixes and parameter changes
Tue Nov 15 06:52:38 2005 UTC (18 years, 5 months ago) by greg
Changes since 3.1: +45 -14 lines
Diff to previous 3.1 , to selected 3.3
Added fcDup() and fcIsLogMap() calls
Mon Nov 14 22:18:18 2005 UTC (18 years, 5 months ago) by greg
Diff to selected 3.3
