root/radiance/ray/src/common/face.h
Revision: 2.2
Committed: Sat Feb 22 02:07:22 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.1: +69 -5 lines
1 /* RCSid: $Id$ */
2 /*
3 * face.h - header for routines using polygonal faces.
4 */
5
6 /* ====================================================================
7 * The Radiance Software License, Version 1.0
8 *
9 * Copyright (c) 1990 - 2002 The Regents of the University of California,
10 * through Lawrence Berkeley National Laboratory. All rights reserved.
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 *
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 *
19 * 2. Redistributions in binary form must reproduce the above copyright
20 * notice, this list of conditions and the following disclaimer in
21 * the documentation and/or other materials provided with the
22 * distribution.
23 *
24 * 3. The end-user documentation included with the redistribution,
25 * if any, must include the following acknowledgment:
26 * "This product includes Radiance software
27 * (http://radsite.lbl.gov/)
28 * developed by the Lawrence Berkeley National Laboratory
29 * (http://www.lbl.gov/)."
30 * Alternately, this acknowledgment may appear in the software itself,
31 * if and wherever such third-party acknowledgments normally appear.
32 *
33 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
34 * and "The Regents of the University of California" must
35 * not be used to endorse or promote products derived from this
36 * software without prior written permission. For written
37 * permission, please contact [email protected].
38 *
39 * 5. Products derived from this software may not be called "Radiance",
40 * nor may "Radiance" appear in their name, without prior written
41 * permission of Lawrence Berkeley National Laboratory.
42 *
43 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
44 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
45 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
46 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
47 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
48 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
49 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
50 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
51 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
52 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
53 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
54 * SUCH DAMAGE.
55 * ====================================================================
56 *
57 * This software consists of voluntary contributions made by many
58 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
59 * information on Lawrence Berkeley National Laboratory, please see
60 * <http://www.lbl.gov/>.
61 */
62
63 #define VERTEX(f,n) ((f)->va + 3*(n))
64
65 typedef struct { /* a polygonal face */
66 FVECT norm; /* the plane's unit normal */
67 FLOAT offset; /* plane equation: DOT(norm, v) == offset */
68 FLOAT area; /* area of face */
69 FLOAT *va; /* vertex array (o->oargs.farg) */
70 short nv; /* # of vertices */
71 short ax; /* axis closest to normal */
72 } FACE;
73
74 #ifdef NOPROTO
75
76 extern FACE *getface();
77 extern void freeface();
78 extern int inface();
79
80 #else
81
82 extern FACE *getface(OBJREC *o);
83 extern void freeface(OBJREC *o);
84 extern int inface(FVECT p, FACE *f);
85
86 #endif
