root/radiance/ray/src/common/face.c
Mon Sep 9 02:48:03 2024 UTC (10 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.17: +4 -5 lines
Diff to previous 2.17 , to selected 2.10
fix: Thanks to Peter A-B for spotting errors caused by FRELEQ()
Sun Aug 18 00:06:10 2024 UTC (11 months, 2 weeks ago) by greg
Changes since 2.16: +7 -6 lines
Diff to previous 2.16 , to selected 2.10
fix: slight improvement in edge case check
Tue Feb 16 16:48:11 2021 UTC (4 years, 5 months ago) by greg
Diff to previous 2.15 , to selected 2.10
fix: major bug introduced in 2.15 revision with axis selection
Fri Feb 12 00:47:33 2021 UTC (4 years, 5 months ago) by greg
Changes since 2.14: +13 -7 lines
fix: Added explicit edge tests to eliminate light leaks at corners
Sun Jun 14 02:10:44 2020 UTC (5 years, 1 month ago) by greg
Added check for triangle before removing "redundant" vertex
Fri Sep 16 15:09:21 2016 UTC (8 years, 10 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.12: +15 -12 lines
Added checks for illegal cones/rings/cylinders
Thu Mar 2 16:51:54 2006 UTC (19 years, 5 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Made some minor optimizations in face intersection code
Thu Jun 26 00:58:09 2003 UTC (22 years, 1 month ago) by schorsch
Fri Mar 21 18:48:46 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.9: +6 -2 lines
Fri Mar 14 21:27:45 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.8: +4 -4 lines
Wed Mar 12 17:26:58 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.7: +7 -4 lines
Tue Feb 25 02:47:21 2003 UTC (22 years, 5 months ago) by greg
Sat Feb 22 02:07:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.5: +59 -5 lines
Fri Mar 22 09:01:16 1996 UTC (29 years, 4 months ago) by greg
slight efficiency improvement
Thu Aug 24 20:54:54 1995 UTC (29 years, 11 months ago) by greg
added check for last vertex connected to first
Fri May 14 13:42:53 1993 UTC (32 years, 3 months ago) by greg
Changes since 2.2: +4 -0 lines
made vertex error a function of SMLFLT define
Fri Oct 2 16:02:20 1992 UTC (32 years, 10 months ago) by greg
Tue Nov 12 16:55:08 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.6 , to selected 2.10
Wed Oct 23 13:43:14 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.5 , to selected 2.10
Fri Aug 2 10:29:42 1991 UTC (34 years ago) by greg
Diff to previous 1.4 , to selected 2.10
fixed potential problem with /= on some compilers
Wed Jul 17 14:10:13 1991 UTC (34 years ago) by greg
Changes since 1.3: +2 -0 lines
Diff to previous 1.3 , to selected 2.10
made call to free structures more robust
Fri Jul 28 14:27:44 1989 UTC (36 years ago) by greg
Changes since 1.2: +2 -1 lines
Diff to previous 1.2 , to selected 2.10
minor bug fix for zero area faces
Tue Feb 21 14:39:54 1989 UTC (36 years, 5 months ago) by greg
Changes since 1.1: +7 -7 lines
Diff to previous 1.1 , to selected 2.10
portability fixes for SGI
Thu Feb 2 10:34:31 1989 UTC (36 years, 6 months ago) by greg
Diff to selected 2.10
