root/radiance/ray/src/common/face.c
Thu Jun 26 00:58:09 2003 UTC (21 years ago) by schorsch
Fri Mar 21 18:48:46 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.9: +6 -2 lines
Fri Mar 14 21:27:45 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.8: +4 -4 lines
Wed Mar 12 17:26:58 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.7: +7 -4 lines
Sat Feb 22 02:07:22 2003 UTC (21 years, 4 months ago) by greg
Changes since 2.5: +59 -5 lines
Fri Mar 22 09:01:16 1996 UTC (28 years, 3 months ago) by greg
slight efficiency improvement
Thu Aug 24 20:54:54 1995 UTC (28 years, 10 months ago) by greg
added check for last vertex connected to first
Fri May 14 13:42:53 1993 UTC (31 years, 1 month ago) by greg
Changes since 2.2: +4 -0 lines
made vertex error a function of SMLFLT define
Fri Oct 2 16:02:20 1992 UTC (31 years, 8 months ago) by greg
Tue Nov 12 16:55:08 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.6 , to selected 2.11
Wed Oct 23 13:43:14 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.5 , to selected 2.11
Fri Aug 2 10:29:42 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.4 , to selected 2.11
fixed potential problem with /= on some compilers
Wed Jul 17 14:10:13 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.3: +2 -0 lines
Diff to previous 1.3 , to selected 2.11
made call to free structures more robust
Fri Jul 28 14:27:44 1989 UTC (34 years, 11 months ago) by greg
Changes since 1.2: +2 -1 lines
Diff to previous 1.2 , to selected 2.11
minor bug fix for zero area faces
Tue Feb 21 14:39:54 1989 UTC (35 years, 4 months ago) by greg
Changes since 1.1: +7 -7 lines
portability fixes for SGI
Thu Feb 2 10:34:31 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.11
