root/radiance/ray/src/common/ezxml.h
Revision: 2.1
Committed: Wed Jun 17 20:41:47 2009 UTC (16 years, 1 month ago) by greg
1 /* RCSid $Id: ezxml.h,v 2.2 2008/06/05 21:34:34 greg Exp $ */
2 /* ezxml.h
3 *
4 * Copyright 2004-2006 Aaron Voisine <[email protected]>
5 *
6 * Permission is hereby granted, free of charge, to any person obtaining
7 * a copy of this software and associated documentation files (the
8 * "Software"), to deal in the Software without restriction, including
9 * without limitation the rights to use, copy, modify, merge, publish,
10 * distribute, sublicense, and/or sell copies of the Software, and to
11 * permit persons to whom the Software is furnished to do so, subject to
12 * the following conditions:
13 *
14 * The above copyright notice and this permission notice shall be included
15 * in all copies or substantial portions of the Software.
16 *
17 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
18 * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
19 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
20 * IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
21 * CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
22 * TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
23 * SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
24 */
25
26 #ifndef _EZXML_H
27 #define _EZXML_H
28
29 #include <stdlib.h>
30 #include <stdio.h>
31 #include <stdarg.h>
32 #include <fcntl.h>
33
34 #ifdef __cplusplus
35 extern "C" {
36 #endif
37
38 /* disable MMAP on CYGWIN, seems to cause problems... */
39 #ifdef CYGWIN
40 #define EZXML_NOMMAP
41 #endif
42
43 #define EZXML_BUFSIZE 1024 // size of internal memory buffers
44 #define EZXML_NAMEM 0x80 // name is malloced
45 #define EZXML_TXTM 0x40 // txt is malloced
46 #define EZXML_DUP 0x20 // attribute name and value are strduped
47
48 typedef struct ezxml *ezxml_t;
49 struct ezxml {
50 char *name; // tag name
51 char **attr; // tag attributes { name, value, name, value, ... NULL }
52 char *txt; // tag character content, empty string if none
53 size_t off; // tag offset from start of parent tag character content
54 ezxml_t next; // next tag with same name in this section at this depth
55 ezxml_t sibling; // next tag with different name in same section and depth
56 ezxml_t ordered; // next tag, same section and depth, in original order
57 ezxml_t child; // head of sub tag list, NULL if none
58 ezxml_t parent; // parent tag, NULL if current tag is root tag
59 short flags; // additional information
60 };
61
62 // Given a string of xml data and its length, parses it and creates an ezxml
63 // structure. For efficiency, modifies the data by adding null terminators
64 // and decoding ampersand sequences. If you don't want this, copy the data and
65 // pass in the copy. Returns NULL on failure.
66 ezxml_t ezxml_parse_str(char *s, size_t len);
67
68 // A wrapper for ezxml_parse_str() that accepts a file descriptor. First
69 // attempts to mem map the file. Failing that, reads the file into memory.
70 // Returns NULL on failure.
71 ezxml_t ezxml_parse_fd(int fd);
72
73 // a wrapper for ezxml_parse_fd() that accepts a file name
74 ezxml_t ezxml_parse_file(const char *file);
75
76 // Wrapper for ezxml_parse_str() that accepts a file stream. Reads the entire
77 // stream into memory and then parses it. For xml files, use ezxml_parse_file()
78 // or ezxml_parse_fd()
79 ezxml_t ezxml_parse_fp(FILE *fp);
80
81 // returns the first child tag (one level deeper) with the given name or NULL
82 // if not found
83 ezxml_t ezxml_child(ezxml_t xml, const char *name);
84
85 // returns the next tag of the same name in the same section and depth or NULL
86 // if not found
87 #define ezxml_next(xml) ((xml) ? xml->next : NULL)
88
89 // Returns the Nth tag with the same name in the same section at the same depth
90 // or NULL if not found. An index of 0 returns the tag given.
91 ezxml_t ezxml_idx(ezxml_t xml, int idx);
92
93 // returns the name of the given tag
94 #define ezxml_name(xml) ((xml) ? xml->name : NULL)
95
96 // returns the given tag's character content or empty string if none
97 #define ezxml_txt(xml) ((xml) ? xml->txt : "")
98
99 // returns the value of the requested tag attribute, or NULL if not found
100 const char *ezxml_attr(ezxml_t xml, const char *attr);
101
102 // Traverses the ezxml sturcture to retrieve a specific subtag. Takes a
103 // variable length list of tag names and indexes. The argument list must be
104 // terminated by either an index of -1 or an empty string tag name. Example:
105 // title = ezxml_get(library, "shelf", 0, "book", 2, "title", -1);
106 // This retrieves the title of the 3rd book on the 1st shelf of library.
107 // Returns NULL if not found.
108 ezxml_t ezxml_get(ezxml_t xml, ...);
109
110 // Converts an ezxml structure back to xml. Returns a string of xml data that
111 // must be freed.
112 char *ezxml_toxml(ezxml_t xml);
113
114 // returns a NULL terminated array of processing instructions for the given
115 // target
116 const char **ezxml_pi(ezxml_t xml, const char *target);
117
118 // frees the memory allocated for an ezxml structure
119 void ezxml_free(ezxml_t xml);
120
121 // returns parser error message or empty string if none
122 const char *ezxml_error(ezxml_t xml);
123
124 // returns a new empty ezxml structure with the given root tag name
125 ezxml_t ezxml_new(const char *name);
126
127 // wrapper for ezxml_new() that strdup()s name
128 #define ezxml_new_d(name) ezxml_set_flag(ezxml_new(strdup(name)), EZXML_NAMEM)
129
130 // Adds a child tag. off is the offset of the child tag relative to the start
131 // of the parent tag's character content. Returns the child tag.
132 ezxml_t ezxml_add_child(ezxml_t xml, const char *name, size_t off);
133
134 // wrapper for ezxml_add_child() that strdup()s name
135 #define ezxml_add_child_d(xml, name, off) \
136 ezxml_set_flag(ezxml_add_child(xml, strdup(name), off), EZXML_NAMEM)
137
138 // sets the character content for the given tag and returns the tag
139 ezxml_t ezxml_set_txt(ezxml_t xml, const char *txt);
140
141 // wrapper for ezxml_set_txt() that strdup()s txt
142 #define ezxml_set_txt_d(xml, txt) \
143 ezxml_set_flag(ezxml_set_txt(xml, strdup(txt)), EZXML_TXTM)
144
145 // Sets the given tag attribute or adds a new attribute if not found. A value
146 // of NULL will remove the specified attribute. Returns the tag given.
147 ezxml_t ezxml_set_attr(ezxml_t xml, const char *name, const char *value);
148
149 // Wrapper for ezxml_set_attr() that strdup()s name/value. Value cannot be NULL
150 #define ezxml_set_attr_d(xml, name, value) \
151 ezxml_set_attr(ezxml_set_flag(xml, EZXML_DUP), strdup(name), strdup(value))
152
153 // sets a flag for the given tag and returns the tag
154 ezxml_t ezxml_set_flag(ezxml_t xml, short flag);
155
156 // removes a tag along with its subtags without freeing its memory
157 ezxml_t ezxml_cut(ezxml_t xml);
158
159 // inserts an existing tag into an ezxml structure
160 ezxml_t ezxml_insert(ezxml_t xml, ezxml_t dest, size_t off);
161
162 // Moves an existing tag to become a subtag of dest at the given offset from
163 // the start of dest's character content. Returns the moved tag.
164 #define ezxml_move(xml, dest, off) ezxml_insert(ezxml_cut(xml), dest, off)
165
166 // removes a tag along with all its subtags
167 #define ezxml_remove(xml) ezxml_free(ezxml_cut(xml))
168
169 #ifdef __cplusplus
170 }
171 #endif
172
173 #endif // _EZXML_H
