root/radiance/ray/src/common/ezxml.h
Revision: 2.1
Committed: Wed Jun 17 20:41:47 2009 UTC (16 years, 1 month ago) by greg
# User Rev Content
1 greg 2.1 /* RCSid $Id: ezxml.h,v 2.2 2008/06/05 21:34:34 greg Exp $ */
2     /* ezxml.h
3     *
4     * Copyright 2004-2006 Aaron Voisine <[email protected]>
5     *
6     * Permission is hereby granted, free of charge, to any person obtaining
7     * a copy of this software and associated documentation files (the
8     * "Software"), to deal in the Software without restriction, including
9     * without limitation the rights to use, copy, modify, merge, publish,
10     * distribute, sublicense, and/or sell copies of the Software, and to
11     * permit persons to whom the Software is furnished to do so, subject to
12     * the following conditions:
13     *
14     * The above copyright notice and this permission notice shall be included
15     * in all copies or substantial portions of the Software.
16     *
17     * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
18     * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
19     * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
20     * IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
21     * CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
22     * TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
23     * SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
24     */
25
26     #ifndef _EZXML_H
27     #define _EZXML_H
28
29     #include <stdlib.h>
30     #include <stdio.h>
31     #include <stdarg.h>
32     #include <fcntl.h>
33
34     #ifdef __cplusplus
35     extern "C" {
36     #endif
37
38     /* disable MMAP on CYGWIN, seems to cause problems... */
39     #ifdef CYGWIN
40     #define EZXML_NOMMAP
41     #endif
42
43     #define EZXML_BUFSIZE 1024 // size of internal memory buffers
44     #define EZXML_NAMEM 0x80 // name is malloced
45     #define EZXML_TXTM 0x40 // txt is malloced
46     #define EZXML_DUP 0x20 // attribute name and value are strduped
47
48     typedef struct ezxml *ezxml_t;
49     struct ezxml {
50     char *name; // tag name
51     char **attr; // tag attributes { name, value, name, value, ... NULL }
52     char *txt; // tag character content, empty string if none
53     size_t off; // tag offset from start of parent tag character content
54     ezxml_t next; // next tag with same name in this section at this depth
55     ezxml_t sibling; // next tag with different name in same section and depth
56     ezxml_t ordered; // next tag, same section and depth, in original order
57     ezxml_t child; // head of sub tag list, NULL if none
58     ezxml_t parent; // parent tag, NULL if current tag is root tag
59     short flags; // additional information
60     };
61
62     // Given a string of xml data and its length, parses it and creates an ezxml
63     // structure. For efficiency, modifies the data by adding null terminators
64     // and decoding ampersand sequences. If you don't want this, copy the data and
65     // pass in the copy. Returns NULL on failure.
66     ezxml_t ezxml_parse_str(char *s, size_t len);
67
68     // A wrapper for ezxml_parse_str() that accepts a file descriptor. First
69     // attempts to mem map the file. Failing that, reads the file into memory.
70     // Returns NULL on failure.
71     ezxml_t ezxml_parse_fd(int fd);
72
73     // a wrapper for ezxml_parse_fd() that accepts a file name
74     ezxml_t ezxml_parse_file(const char *file);
75
76     // Wrapper for ezxml_parse_str() that accepts a file stream. Reads the entire
77     // stream into memory and then parses it. For xml files, use ezxml_parse_file()
78     // or ezxml_parse_fd()
79     ezxml_t ezxml_parse_fp(FILE *fp);
80
81     // returns the first child tag (one level deeper) with the given name or NULL
82     // if not found
83     ezxml_t ezxml_child(ezxml_t xml, const char *name);
84
85     // returns the next tag of the same name in the same section and depth or NULL
86     // if not found
87     #define ezxml_next(xml) ((xml) ? xml->next : NULL)
88
89     // Returns the Nth tag with the same name in the same section at the same depth
90     // or NULL if not found. An index of 0 returns the tag given.
91     ezxml_t ezxml_idx(ezxml_t xml, int idx);
92
93     // returns the name of the given tag
94     #define ezxml_name(xml) ((xml) ? xml->name : NULL)
95
96     // returns the given tag's character content or empty string if none
97     #define ezxml_txt(xml) ((xml) ? xml->txt : "")
98
99     // returns the value of the requested tag attribute, or NULL if not found
100     const char *ezxml_attr(ezxml_t xml, const char *attr);
101
102     // Traverses the ezxml sturcture to retrieve a specific subtag. Takes a
103     // variable length list of tag names and indexes. The argument list must be
104     // terminated by either an index of -1 or an empty string tag name. Example:
105     // title = ezxml_get(library, "shelf", 0, "book", 2, "title", -1);
106     // This retrieves the title of the 3rd book on the 1st shelf of library.
107     // Returns NULL if not found.
108     ezxml_t ezxml_get(ezxml_t xml, ...);
109
110     // Converts an ezxml structure back to xml. Returns a string of xml data that
111     // must be freed.
112     char *ezxml_toxml(ezxml_t xml);
113
114     // returns a NULL terminated array of processing instructions for the given
115     // target
116     const char **ezxml_pi(ezxml_t xml, const char *target);
117
118     // frees the memory allocated for an ezxml structure
119     void ezxml_free(ezxml_t xml);
120
121     // returns parser error message or empty string if none
122     const char *ezxml_error(ezxml_t xml);
123
124     // returns a new empty ezxml structure with the given root tag name
125     ezxml_t ezxml_new(const char *name);
126
127     // wrapper for ezxml_new() that strdup()s name
128     #define ezxml_new_d(name) ezxml_set_flag(ezxml_new(strdup(name)), EZXML_NAMEM)
129
130     // Adds a child tag. off is the offset of the child tag relative to the start
131     // of the parent tag's character content. Returns the child tag.
132     ezxml_t ezxml_add_child(ezxml_t xml, const char *name, size_t off);
133
134     // wrapper for ezxml_add_child() that strdup()s name
135     #define ezxml_add_child_d(xml, name, off) \
136     ezxml_set_flag(ezxml_add_child(xml, strdup(name), off), EZXML_NAMEM)
137
138     // sets the character content for the given tag and returns the tag
139     ezxml_t ezxml_set_txt(ezxml_t xml, const char *txt);
140
141     // wrapper for ezxml_set_txt() that strdup()s txt
142     #define ezxml_set_txt_d(xml, txt) \
143     ezxml_set_flag(ezxml_set_txt(xml, strdup(txt)), EZXML_TXTM)
144
145     // Sets the given tag attribute or adds a new attribute if not found. A value
146     // of NULL will remove the specified attribute. Returns the tag given.
147     ezxml_t ezxml_set_attr(ezxml_t xml, const char *name, const char *value);
148
149     // Wrapper for ezxml_set_attr() that strdup()s name/value. Value cannot be NULL
150     #define ezxml_set_attr_d(xml, name, value) \
151     ezxml_set_attr(ezxml_set_flag(xml, EZXML_DUP), strdup(name), strdup(value))
152
153     // sets a flag for the given tag and returns the tag
154     ezxml_t ezxml_set_flag(ezxml_t xml, short flag);
155
156     // removes a tag along with its subtags without freeing its memory
157     ezxml_t ezxml_cut(ezxml_t xml);
158
159     // inserts an existing tag into an ezxml structure
160     ezxml_t ezxml_insert(ezxml_t xml, ezxml_t dest, size_t off);
161
162     // Moves an existing tag to become a subtag of dest at the given offset from
163     // the start of dest's character content. Returns the moved tag.
164     #define ezxml_move(xml, dest, off) ezxml_insert(ezxml_cut(xml), dest, off)
165
166     // removes a tag along with all its subtags
167     #define ezxml_remove(xml) ezxml_free(ezxml_cut(xml))
168
169     #ifdef __cplusplus
170     }
171     #endif
172
173     #endif // _EZXML_H
