root/radiance/ray/src/common/ezxml.c
Revision: 2.1
Committed: Wed Jun 17 20:41:47 2009 UTC (14 years, 11 months ago) by greg
2 static const char RCSid[] = "$Id: ezxml.c,v 2.4 2008/11/12 03:54:31 greg Exp $";
4 /* ezxml.c
5 *
6 * Copyright 2004-2006 Aaron Voisine <[email protected]>
7 *
8 * Permission is hereby granted, free of charge, to any person obtaining
9 * a copy of this software and associated documentation files (the
10 * "Software"), to deal in the Software without restriction, including
11 * without limitation the rights to use, copy, modify, merge, publish,
12 * distribute, sublicense, and/or sell copies of the Software, and to
13 * permit persons to whom the Software is furnished to do so, subject to
14 * the following conditions:
15 *
16 * The above copyright notice and this permission notice shall be included
17 * in all copies or substantial portions of the Software.
18 *
19 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
20 * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
21 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
22 * IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
23 * CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
24 * TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
25 * SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
26 */
27
28 #include <stdlib.h>
29 #include <stdio.h>
30 #include <stdarg.h>
31 #include <string.h>
32 #include <ctype.h>
33 #include <sys/types.h>
34 #ifndef EZXML_NOMMAP
35 #include <unistd.h>
36 #include <sys/mman.h>
37 #endif // EZXML_NOMMAP
38 #include <sys/stat.h>
39 #include "ezxml.h"
40
41 #define EZXML_WS "\t\r\n " // whitespace
42 #define EZXML_ERRL 128 // maximum error string length
43
44 typedef struct ezxml_root *ezxml_root_t;
45 struct ezxml_root { // additional data for the root tag
46 struct ezxml xml; // is a super-struct built on top of ezxml struct
47 ezxml_t cur; // current xml tree insertion point
48 char *m; // original xml string
49 size_t len; // length of allocated memory for mmap, -1 for malloc
50 char *u; // UTF-8 conversion of string if original was UTF-16
51 char *s; // start of work area
52 char *e; // end of work area
53 char **ent; // general entities (ampersand sequences)
54 char ***attr; // default attributes
55 char ***pi; // processing instructions
56 short standalone; // non-zero if <?xml standalone="yes"?>
57 char err[EZXML_ERRL]; // error string
58 };
59
60 char *EZXML_NIL[] = { NULL }; // empty, null terminated array of strings
61
62 // returns the first child tag with the given name or NULL if not found
63 ezxml_t ezxml_child(ezxml_t xml, const char *name)
64 {
65 xml = (xml) ? xml->child : NULL;
66 while (xml && strcmp(name, xml->name)) xml = xml->sibling;
67 return xml;
68 }
69
70 // returns the Nth tag with the same name in the same subsection or NULL if not
71 // found
72 ezxml_t ezxml_idx(ezxml_t xml, int idx)
73 {
74 for (; xml && idx; idx--) xml = xml->next;
75 return xml;
76 }
77
78 // returns the value of the requested tag attribute or NULL if not found
79 const char *ezxml_attr(ezxml_t xml, const char *attr)
80 {
81 int i = 0, j = 1;
82 ezxml_root_t root = (ezxml_root_t)xml;
83
84 if (! xml || ! xml->attr) return NULL;
85 while (xml->attr[i] && strcmp(attr, xml->attr[i])) i += 2;
86 if (xml->attr[i]) return xml->attr[i + 1]; // found attribute
87
88 while (root->xml.parent) root = (ezxml_root_t)root->xml.parent; // root tag
89 for (i = 0; root->attr[i] && strcmp(xml->name, root->attr[i][0]); i++);
90 if (! root->attr[i]) return NULL; // no matching default attributes
91 while (root->attr[i][j] && strcmp(attr, root->attr[i][j])) j += 3;
92 return (root->attr[i][j]) ? root->attr[i][j + 1] : NULL; // found default
93 }
94
95 // same as ezxml_get but takes an already initialized va_list
96 ezxml_t ezxml_vget(ezxml_t xml, va_list ap)
97 {
98 char *name = va_arg(ap, char *);
99 int idx = -1;
100
101 if (name && *name) {
102 idx = va_arg(ap, int);
103 xml = ezxml_child(xml, name);
104 }
105 return (idx < 0) ? xml : ezxml_vget(ezxml_idx(xml, idx), ap);
106 }
107
108 // Traverses the xml tree to retrieve a specific subtag. Takes a variable
109 // length list of tag names and indexes. The argument list must be terminated
110 // by either an index of -1 or an empty string tag name. Example:
111 // title = ezxml_get(library, "shelf", 0, "book", 2, "title", -1);
112 // This retrieves the title of the 3rd book on the 1st shelf of library.
113 // Returns NULL if not found.
114 ezxml_t ezxml_get(ezxml_t xml, ...)
115 {
116 va_list ap;
117 ezxml_t r;
118
119 va_start(ap, xml);
120 r = ezxml_vget(xml, ap);
121 va_end(ap);
122 return r;
123 }
124
125 // returns a null terminated array of processing instructions for the given
126 // target
127 const char **ezxml_pi(ezxml_t xml, const char *target)
128 {
129 ezxml_root_t root = (ezxml_root_t)xml;
130 int i = 0;
131
132 if (! root) return (const char **)EZXML_NIL;
133 while (root->xml.parent) root = (ezxml_root_t)root->xml.parent; // root tag
134 while (root->pi[i] && strcmp(target, root->pi[i][0])) i++; // find target
135 return (const char **)((root->pi[i]) ? root->pi[i] + 1 : EZXML_NIL);
136 }
137
138 // set an error string and return root
139 ezxml_t ezxml_err(ezxml_root_t root, char *s, const char *err, ...)
140 {
141 va_list ap;
142 int line = 1;
143 char *t, fmt[EZXML_ERRL];
144
145 for (t = root->s; t < s; t++) if (*t == '\n') line++;
146 snprintf(fmt, EZXML_ERRL, "[error near line %d]: %s", line, err);
147
148 va_start(ap, err);
149 vsnprintf(root->err, EZXML_ERRL, fmt, ap);
150 va_end(ap);
151
152 return &root->xml;
153 }
154
155 // Recursively decodes entity and character references and normalizes new lines
156 // ent is a null terminated array of alternating entity names and values. set t
157 // to '&' for general entity decoding, '%' for parameter entity decoding, 'c'
158 // for cdata sections, ' ' for attribute normalization, or '*' for non-cdata
159 // attribute normalization. Returns s, or if the decoded string is longer than
160 // s, returns a malloced string that must be freed.
161 char *ezxml_decode(char *s, char **ent, char t)
162 {
163 char *e, *r = s, *m = s;
164 long b, c, d, l;
165
166 for (; *s; s++) { // normalize line endings
167 while (*s == '\r') {
168 *(s++) = '\n';
169 if (*s == '\n') memmove(s, (s + 1), strlen(s));
170 }
171 }
172
173 for (s = r; ; ) {
174 while (*s && *s != '&' && (*s != '%' || t != '%') && !isspace(*s)) s++;
175
176 if (! *s) break;
177 else if (t != 'c' && ! strncmp(s, "&#", 2)) { // character reference
178 if (s[2] == 'x') c = strtol(s + 3, &e, 16); // base 16
179 else c = strtol(s + 2, &e, 10); // base 10
180 if (! c || *e != ';') { s++; continue; } // not a character ref
181
182 if (c < 0x80) *(s++) = c; // US-ASCII subset
183 else { // multi-byte UTF-8 sequence
184 for (b = 0, d = c; d; d /= 2) b++; // number of bits in c
185 b = (b - 2) / 5; // number of bytes in payload
186 *(s++) = (0xFF << (7 - b)) | (c >> (6 * b)); // head
187 while (b) *(s++) = 0x80 | ((c >> (6 * --b)) & 0x3F); // payload
188 }
189
190 memmove(s, strchr(s, ';') + 1, strlen(strchr(s, ';')));
191 }
192 else if ((*s == '&' && (t == '&' || t == ' ' || t == '*')) ||
193 (*s == '%' && t == '%')) { // entity reference
194 for (b = 0; ent[b] && strncmp(s + 1, ent[b], strlen(ent[b]));
195 b += 2); // find entity in entity list
196
197 if (ent[b++]) { // found a match
198 if ((c = strlen(ent[b])) - 1 > (e = strchr(s, ';')) - s) {
199 l = (d = (s - r)) + c + strlen(e); // new length
200 r = (r == m) ? strcpy(malloc(l), r) : realloc(r, l);
201 e = strchr((s = r + d), ';'); // fix up pointers
202 }
203
204 memmove(s + c, e + 1, strlen(e)); // shift rest of string
205 strncpy(s, ent[b], c); // copy in replacement text
206 }
207 else s++; // not a known entity
208 }
209 else if ((t == ' ' || t == '*') && isspace(*s)) *(s++) = ' ';
210 else s++; // no decoding needed
211 }
212
213 if (t == '*') { // normalize spaces for non-cdata attributes
214 for (s = r; *s; s++) {
215 if ((l = strspn(s, " "))) memmove(s, s + l, strlen(s + l) + 1);
216 while (*s && *s != ' ') s++;
217 }
218 if (--s >= r && *s == ' ') *s = '\0'; // trim any trailing space
219 }
220 return r;
221 }
222
223 // called when parser finds start of new tag
224 void ezxml_open_tag(ezxml_root_t root, char *name, char **attr)
225 {
226 ezxml_t xml = root->cur;
227
228 if (xml->name) xml = ezxml_add_child(xml, name, strlen(xml->txt));
229 else xml->name = name; // first open tag
230
231 xml->attr = attr;
232 root->cur = xml; // update tag insertion point
233 }
234
235 // called when parser finds character content between open and closing tag
236 void ezxml_char_content(ezxml_root_t root, char *s, size_t len, char t)
237 {
238 ezxml_t xml = root->cur;
239 char *m = s;
240 size_t l;
241
242 if (! xml || ! xml->name || ! len) return; // sanity check
243
244 s[len] = '\0'; // null terminate text (calling functions anticipate this)
245 len = strlen(s = ezxml_decode(s, root->ent, t)) + 1;
246
247 if (! *(xml->txt)) xml->txt = s; // initial character content
248 else { // allocate our own memory and make a copy
249 xml->txt = (xml->flags & EZXML_TXTM) // allocate some space
250 ? realloc(xml->txt, (l = strlen(xml->txt)) + len)
251 : strcpy(malloc((l = strlen(xml->txt)) + len), xml->txt);
252 strcpy(xml->txt + l, s); // add new char content
253 if (s != m) free(s); // free s if it was malloced by ezxml_decode()
254 }
255
256 if (xml->txt != m) ezxml_set_flag(xml, EZXML_TXTM);
257 }
258
259 // called when parser finds closing tag
260 ezxml_t ezxml_close_tag(ezxml_root_t root, char *name, char *s)
261 {
262 if (! root->cur || ! root->cur->name || strcmp(name, root->cur->name))
263 return ezxml_err(root, s, "unexpected closing tag </%s>", name);
264
265 root->cur = root->cur->parent;
266 return NULL;
267 }
268
269 // checks for circular entity references, returns non-zero if no circular
270 // references are found, zero otherwise
271 int ezxml_ent_ok(char *name, char *s, char **ent)
272 {
273 int i;
274
275 for (; ; s++) {
276 while (*s && *s != '&') s++; // find next entity reference
277 if (! *s) return 1;
278 if (! strncmp(s + 1, name, strlen(name))) return 0; // circular ref.
279 for (i = 0; ent[i] && strncmp(ent[i], s + 1, strlen(ent[i])); i += 2);
280 if (ent[i] && ! ezxml_ent_ok(name, ent[i + 1], ent)) return 0;
281 }
282 }
283
284 // called when the parser finds a processing instruction
285 void ezxml_proc_inst(ezxml_root_t root, char *s, size_t len)
286 {
287 int i = 0, j = 1;
288 char *target = s;
289
290 s[len] = '\0'; // null terminate instruction
291 if (*(s += strcspn(s, EZXML_WS))) {
292 *s = '\0'; // null terminate target
293 s += strspn(s + 1, EZXML_WS) + 1; // skip whitespace after target
294 }
295
296 if (! strcmp(target, "xml")) { // <?xml ... ?>
297 if ((s = strstr(s, "standalone")) && ! strncmp(s + strspn(s + 10,
298 EZXML_WS "='\"") + 10, "yes", 3)) root->standalone = 1;
299 return;
300 }
301
302 if (! root->pi[0]) *(root->pi = malloc(sizeof(char **))) = NULL; //first pi
303
304 while (root->pi[i] && strcmp(target, root->pi[i][0])) i++; // find target
305 if (! root->pi[i]) { // new target
306 root->pi = realloc(root->pi, sizeof(char **) * (i + 2));
307 root->pi[i] = malloc(sizeof(char *) * 3);
308 root->pi[i][0] = target;
309 root->pi[i][1] = (char *)(root->pi[i + 1] = NULL); // terminate pi list
310 root->pi[i][2] = strdup(""); // empty document position list
311 }
312
313 while (root->pi[i][j]) j++; // find end of instruction list for this target
314 root->pi[i] = realloc(root->pi[i], sizeof(char *) * (j + 3));
315 root->pi[i][j + 2] = realloc(root->pi[i][j + 1], j + 1);
316 strcpy(root->pi[i][j + 2] + j - 1, (root->xml.name) ? ">" : "<");
317 root->pi[i][j + 1] = NULL; // null terminate pi list for this target
318 root->pi[i][j] = s; // set instruction
319 }
320
321 // called when the parser finds an internal doctype subset
322 short ezxml_internal_dtd(ezxml_root_t root, char *s, size_t len)
323 {
324 char q, *c, *t, *n = NULL, *v, **ent, **pe;
325 int i, j;
326
327 pe = memcpy(malloc(sizeof(EZXML_NIL)), EZXML_NIL, sizeof(EZXML_NIL));
328
329 for (s[len] = '\0'; s; ) {
330 while (*s && *s != '<' && *s != '%') s++; // find next declaration
331
332 if (! *s) break;
333 else if (! strncmp(s, "<!ENTITY", 8)) { // parse entity definitions
334 c = s += strspn(s + 8, EZXML_WS) + 8; // skip white space separator
335 n = s + strspn(s, EZXML_WS "%"); // find name
336 *(s = n + strcspn(n, EZXML_WS)) = ';'; // append ; to name
337
338 v = s + strspn(s + 1, EZXML_WS) + 1; // find value
339 if ((q = *(v++)) != '"' && q != '\'') { // skip externals
340 s = strchr(s, '>');
341 continue;
342 }
343
344 for (i = 0, ent = (*c == '%') ? pe : root->ent; ent[i]; i++);
345 ent = realloc(ent, (i + 3) * sizeof(char *)); // space for next ent
346 if (*c == '%') pe = ent;
347 else root->ent = ent;
348
349 *(++s) = '\0'; // null terminate name
350 if ((s = strchr(v, q))) *(s++) = '\0'; // null terminate value
351 ent[i + 1] = ezxml_decode(v, pe, '%'); // set value
352 ent[i + 2] = NULL; // null terminate entity list
353 if (! ezxml_ent_ok(n, ent[i + 1], ent)) { // circular reference
354 if (ent[i + 1] != v) free(ent[i + 1]);
355 ezxml_err(root, v, "circular entity declaration &%s", n);
356 break;
357 }
358 else ent[i] = n; // set entity name
359 }
360 else if (! strncmp(s, "<!ATTLIST", 9)) { // parse default attributes
361 t = s + strspn(s + 9, EZXML_WS) + 9; // skip whitespace separator
362 if (! *t) { ezxml_err(root, t, "unclosed <!ATTLIST"); break; }
363 if (*(s = t + strcspn(t, EZXML_WS ">")) == '>') continue;
364 else *s = '\0'; // null terminate tag name
365 for (i = 0; root->attr[i] && strcmp(n, root->attr[i][0]); i++);
366
367 while (*(n = ++s + strspn(s, EZXML_WS)) && *n != '>') {
368 if (*(s = n + strcspn(n, EZXML_WS))) *s = '\0'; // attr name
369 else { ezxml_err(root, t, "malformed <!ATTLIST"); break; }
370
371 s += strspn(s + 1, EZXML_WS) + 1; // find next token
372 c = (strncmp(s, "CDATA", 5)) ? "*" : " "; // is it cdata?
373 if (! strncmp(s, "NOTATION", 8))
374 s += strspn(s + 8, EZXML_WS) + 8;
375 s = (*s == '(') ? strchr(s, ')') : s + strcspn(s, EZXML_WS);
376 if (! s) { ezxml_err(root, t, "malformed <!ATTLIST"); break; }
377
378 s += strspn(s, EZXML_WS ")"); // skip white space separator
379 if (! strncmp(s, "#FIXED", 6))
380 s += strspn(s + 6, EZXML_WS) + 6;
381 if (*s == '#') { // no default value
382 s += strcspn(s, EZXML_WS ">") - 1;
383 if (*c == ' ') continue; // cdata is default, nothing to do
384 v = NULL;
385 }
386 else if ((*s == '"' || *s == '\'') && // default value
387 (s = strchr(v = s + 1, *s))) *s = '\0';
388 else { ezxml_err(root, t, "malformed <!ATTLIST"); break; }
389
390 if (! root->attr[i]) { // new tag name
391 root->attr = (! i) ? malloc(2 * sizeof(char **))
392 : realloc(root->attr,
393 (i + 2) * sizeof(char **));
394 root->attr[i] = malloc(2 * sizeof(char *));
395 root->attr[i][0] = t; // set tag name
396 root->attr[i][1] = (char *)(root->attr[i + 1] = NULL);
397 }
398
399 for (j = 1; root->attr[i][j]; j += 3); // find end of list
400 root->attr[i] = realloc(root->attr[i],
401 (j + 4) * sizeof(char *));
402
403 root->attr[i][j + 3] = NULL; // null terminate list
404 root->attr[i][j + 2] = c; // is it cdata?
405 root->attr[i][j + 1] = (v) ? ezxml_decode(v, root->ent, *c)
406 : NULL;
407 root->attr[i][j] = n; // attribute name
408 }
409 }
410 else if (! strncmp(s, "<!--", 4)) s = strstr(s + 4, "-->"); // comments
411 else if (! strncmp(s, "<?", 2)) { // processing instructions
412 if ((s = strstr(c = s + 2, "?>")))
413 ezxml_proc_inst(root, c, s++ - c);
414 }
415 else if (*s == '<') s = strchr(s, '>'); // skip other declarations
416 else if (*(s++) == '%' && ! root->standalone) break;
417 }
418
419 free(pe);
420 return ! *root->err;
421 }
422
423 // Converts a UTF-16 string to UTF-8. Returns a new string that must be freed
424 // or NULL if no conversion was needed.
425 char *ezxml_str2utf8(char **s, size_t *len)
426 {
427 char *u;
428 size_t l = 0, sl, max = *len;
429 long c, d;
430 int b, be = (**s == '\xFE') ? 1 : (**s == '\xFF') ? 0 : -1;
431
432 if (be == -1) return NULL; // not UTF-16
433
434 u = malloc(max);
435 for (sl = 2; sl < *len - 1; sl += 2) {
436 c = (be) ? (((*s)[sl] & 0xFF) << 8) | ((*s)[sl + 1] & 0xFF) //UTF-16BE
437 : (((*s)[sl + 1] & 0xFF) << 8) | ((*s)[sl] & 0xFF); //UTF-16LE
438 if (c >= 0xD800 && c <= 0xDFFF && (sl += 2) < *len - 1) { // high-half
439 d = (be) ? (((*s)[sl] & 0xFF) << 8) | ((*s)[sl + 1] & 0xFF)
440 : (((*s)[sl + 1] & 0xFF) << 8) | ((*s)[sl] & 0xFF);
441 c = (((c & 0x3FF) << 10) | (d & 0x3FF)) + 0x10000;
442 }
443
444 while (l + 6 > max) u = realloc(u, max += EZXML_BUFSIZE);
445 if (c < 0x80) u[l++] = c; // US-ASCII subset
446 else { // multi-byte UTF-8 sequence
447 for (b = 0, d = c; d; d /= 2) b++; // bits in c
448 b = (b - 2) / 5; // bytes in payload
449 u[l++] = (0xFF << (7 - b)) | (c >> (6 * b)); // head
450 while (b) u[l++] = 0x80 | ((c >> (6 * --b)) & 0x3F); // payload
451 }
452 }
453 return *s = realloc(u, *len = l);
454 }
455
456 // frees a tag attribute list
457 void ezxml_free_attr(char **attr) {
458 int i = 0;
459 char *m;
460
461 if (! attr || attr == EZXML_NIL) return; // nothing to free
462 while (attr[i]) i += 2; // find end of attribute list
463 m = attr[i + 1]; // list of which names and values are malloced
464 for (i = 0; m[i]; i++) {
465 if (m[i] & EZXML_NAMEM) free(attr[i * 2]);
466 if (m[i] & EZXML_TXTM) free(attr[(i * 2) + 1]);
467 }
468 free(m);
469 free(attr);
470 }
471
472 // parse the given xml string and return an ezxml structure
473 ezxml_t ezxml_parse_str(char *s, size_t len)
474 {
475 ezxml_root_t root = (ezxml_root_t)ezxml_new(NULL);
476 char q, e, *d, **attr, **a = NULL; // initialize a to avoid compile warning
477 int l, i, j;
478
479 root->m = s;
480 if (! len) return ezxml_err(root, NULL, "root tag missing");
481 root->u = ezxml_str2utf8(&s, &len); // convert utf-16 to utf-8
482 root->e = (root->s = s) + len; // record start and end of work area
483
484 e = s[len - 1]; // save end char
485 s[len - 1] = '\0'; // turn end char into null terminator
486
487 while (*s && *s != '<') s++; // find first tag
488 if (! *s) return ezxml_err(root, s, "root tag missing");
489
490 for (; ; ) {
491 attr = (char **)EZXML_NIL;
492 d = ++s;
493
494 if (isalpha(*s) || *s == '_' || *s == ':' || *s < '\0') { // new tag
495 if (! root->cur)
496 return ezxml_err(root, d, "markup outside of root element");
497
498 s += strcspn(s, EZXML_WS "/>");
499 while (isspace(*s)) *(s++) = '\0'; // null terminate tag name
500
501 if (*s && *s != '/' && *s != '>') // find tag in default attr list
502 for (i = 0; (a = root->attr[i]) && strcmp(a[0], d); i++);
503
504 for (l = 0; *s && *s != '/' && *s != '>'; l += 2) { // new attrib
505 attr = (l) ? realloc(attr, (l + 4) * sizeof(char *))
506 : malloc(4 * sizeof(char *)); // allocate space
507 attr[l + 3] = (l) ? realloc(attr[l + 1], (l / 2) + 2)
508 : malloc(2); // mem for list of maloced vals
509 strcpy(attr[l + 3] + (l / 2), " "); // value is not malloced
510 attr[l + 2] = NULL; // null terminate list
511 attr[l + 1] = ""; // temporary attribute value
512 attr[l] = s; // set attribute name
513
514 s += strcspn(s, EZXML_WS "=/>");
515 if (*s == '=' || isspace(*s)) {
516 *(s++) = '\0'; // null terminate tag attribute name
517 q = *(s += strspn(s, EZXML_WS "="));
518 if (q == '"' || q == '\'') { // attribute value
519 attr[l + 1] = ++s;
520 while (*s && *s != q) s++;
521 if (*s) *(s++) = '\0'; // null terminate attribute val
522 else {
523 ezxml_free_attr(attr);
524 return ezxml_err(root, d, "missing %c", q);
525 }
526
527 for (j = 1; a && a[j] && strcmp(a[j], attr[l]); j +=3);
528 attr[l + 1] = ezxml_decode(attr[l + 1], root->ent, (a
529 && a[j]) ? *a[j + 2] : ' ');
530 if (attr[l + 1] < d || attr[l + 1] > s)
531 attr[l + 3][l / 2] = EZXML_TXTM; // value malloced
532 }
533 }
534 while (isspace(*s)) s++;
535 }
536
537 if (*s == '/') { // self closing tag
538 *(s++) = '\0';
539 if ((*s && *s != '>') || (! *s && e != '>')) {
540 if (l) ezxml_free_attr(attr);
541 return ezxml_err(root, d, "missing >");
542 }
543 ezxml_open_tag(root, d, attr);
544 ezxml_close_tag(root, d, s);
545 }
546 else if ((q = *s) == '>' || (! *s && e == '>')) { // open tag
547 *s = '\0'; // temporarily null terminate tag name
548 ezxml_open_tag(root, d, attr);
549 *s = q;
550 }
551 else {
552 if (l) ezxml_free_attr(attr);
553 return ezxml_err(root, d, "missing >");
554 }
555 }
556 else if (*s == '/') { // close tag
557 s += strcspn(d = s + 1, EZXML_WS ">") + 1;
558 if (! (q = *s) && e != '>') return ezxml_err(root, d, "missing >");
559 *s = '\0'; // temporarily null terminate tag name
560 if (ezxml_close_tag(root, d, s)) return &root->xml;
561 if (isspace(*s = q)) s += strspn(s, EZXML_WS);
562 }
563 else if (! strncmp(s, "!--", 3)) { // xml comment
564 if (! (s = strstr(s + 3, "--")) || (*(s += 2) != '>' && *s) ||
565 (! *s && e != '>')) return ezxml_err(root, d, "unclosed <!--");
566 }
567 else if (! strncmp(s, "![CDATA[", 8)) { // cdata
568 if ((s = strstr(s, "]]>")))
569 ezxml_char_content(root, d + 8, (s += 2) - d - 10, 'c');
570 else return ezxml_err(root, d, "unclosed <![CDATA[");
571 }
572 else if (! strncmp(s, "!DOCTYPE", 8)) { // dtd
573 for (l = 0; *s && ((! l && *s != '>') || (l && (*s != ']' ||
574 *(s + strspn(s + 1, EZXML_WS) + 1) != '>')));
575 l = (*s == '[') ? 1 : l) s += strcspn(s + 1, "[]>") + 1;
576 if (! *s && e != '>')
577 return ezxml_err(root, d, "unclosed <!DOCTYPE");
578 d = (l) ? strchr(d, '[') + 1 : d;
579 if (l && ! ezxml_internal_dtd(root, d, s++ - d)) return &root->xml;
580 }
581 else if (*s == '?') { // <?...?> processing instructions
582 do { s = strchr(s, '?'); } while (s && *(++s) && *s != '>');
583 if (! s || (! *s && e != '>'))
584 return ezxml_err(root, d, "unclosed <?");
585 else ezxml_proc_inst(root, d + 1, s - d - 2);
586 }
587 else return ezxml_err(root, d, "unexpected <");
588
589 if (! s || ! *s) break;
590 *s = '\0';
591 d = ++s;
592 if (*s && *s != '<') { // tag character content
593 while (*s && *s != '<') s++;
594 if (*s) ezxml_char_content(root, d, s - d, '&');
595 else break;
596 }
597 else if (! *s) break;
598 }
599
600 if (! root->cur) return &root->xml;
601 else if (! root->cur->name) return ezxml_err(root, d, "root tag missing");
602 else return ezxml_err(root, d, "unclosed tag <%s>", root->cur->name);
603 }
604
605 // Wrapper for ezxml_parse_str() that accepts a file stream. Reads the entire
606 // stream into memory and then parses it. For xml files, use ezxml_parse_file()
607 // or ezxml_parse_fd()
608 ezxml_t ezxml_parse_fp(FILE *fp)
609 {
610 ezxml_root_t root;
611 size_t l, len = 0;
612 char *s;
613
614 if (! (s = malloc(EZXML_BUFSIZE))) return NULL;
615 do {
616 len += (l = fread((s + len), 1, EZXML_BUFSIZE, fp));
617 if (l == EZXML_BUFSIZE) s = realloc(s, len + EZXML_BUFSIZE);
618 } while (s && l == EZXML_BUFSIZE);
619
620 if (! s) return NULL;
621 root = (ezxml_root_t)ezxml_parse_str(s, len);
622 root->len = -1; // so we know to free s in ezxml_free()
623 return &root->xml;
624 }
625
626 // A wrapper for ezxml_parse_str() that accepts a file descriptor. First
627 // attempts to mem map the file. Failing that, reads the file into memory.
628 // Returns NULL on failure.
629 ezxml_t ezxml_parse_fd(int fd)
630 {
631 ezxml_root_t root;
632 struct stat st;
633 size_t l;
634 void *m;
635
636 if (fd < 0) return NULL;
637 fstat(fd, &st);
638
639 #ifndef EZXML_NOMMAP
640 l = (st.st_size + sysconf(_SC_PAGESIZE) - 1) & ~(sysconf(_SC_PAGESIZE) -1);
641 if ((m = mmap(NULL, l, PROT_READ|PROT_WRITE, MAP_PRIVATE, fd, 0))
642 != MAP_FAILED) {
643 madvise(m, l, MADV_SEQUENTIAL); // optimize for sequential access
644 root = (ezxml_root_t)ezxml_parse_str(m, st.st_size);
645 madvise(m, root->len = l, MADV_NORMAL); // put it back to normal
646 }
647 else { // mmap failed, read file into memory
648 #endif // EZXML_NOMMAP
649 l = read(fd, m = malloc(st.st_size), st.st_size);
650 root = (ezxml_root_t)ezxml_parse_str(m, l);
651 root->len = -1; // so we know to free s in ezxml_free()
652 #ifndef EZXML_NOMMAP
653 }
654 #endif // EZXML_NOMMAP
655 return &root->xml;
656 }
657
658 // a wrapper for ezxml_parse_fd that accepts a file name
659 ezxml_t ezxml_parse_file(const char *file)
660 {
661 int fd = open(file, O_RDONLY, 0);
662 ezxml_t xml = ezxml_parse_fd(fd);
663
664 if (fd >= 0) close(fd);
665 return xml;
666 }
667
668 // Encodes ampersand sequences appending the results to *dst, reallocating *dst
669 // if length excedes max. a is non-zero for attribute encoding. Returns *dst
670 char *ezxml_ampencode(const char *s, size_t len, char **dst, size_t *dlen,
671 size_t *max, short a)
672 {
673 const char *e;
674
675 for (e = s + len; s != e; s++) {
676 while (*dlen + 10 > *max) *dst = realloc(*dst, *max += EZXML_BUFSIZE);
677
678 switch (*s) {
679 case '\0': return *dst;
680 case '&': *dlen += sprintf(*dst + *dlen, "&amp;"); break;
681 case '<': *dlen += sprintf(*dst + *dlen, "&lt;"); break;
682 case '>': *dlen += sprintf(*dst + *dlen, "&gt;"); break;
683 case '"': *dlen += sprintf(*dst + *dlen, (a) ? "&quot;" : "\""); break;
684 case '\n': *dlen += sprintf(*dst + *dlen, (a) ? "&#xA;" : "\n"); break;
685 case '\t': *dlen += sprintf(*dst + *dlen, (a) ? "&#x9;" : "\t"); break;
686 case '\r': *dlen += sprintf(*dst + *dlen, "&#xD;"); break;
687 default: (*dst)[(*dlen)++] = *s;
688 }
689 }
690 return *dst;
691 }
692
693 // Recursively converts each tag to xml appending it to *s. Reallocates *s if
694 // its length excedes max. start is the location of the previous tag in the
695 // parent tag's character content. Returns *s.
696 char *ezxml_toxml_r(ezxml_t xml, char **s, size_t *len, size_t *max,
697 size_t start, char ***attr)
698 {
699 int i, j;
700 char *txt = (xml->parent) ? xml->parent->txt : "";
701 size_t off = 0;
702
703 // parent character content up to this tag
704 *s = ezxml_ampencode(txt + start, xml->off - start, s, len, max, 0);
705
706 while (*len + strlen(xml->name) + 4 > *max) // reallocate s
707 *s = realloc(*s, *max += EZXML_BUFSIZE);
708
709 *len += sprintf(*s + *len, "<%s", xml->name); // open tag
710 for (i = 0; xml->attr[i]; i += 2) { // tag attributes
711 if (ezxml_attr(xml, xml->attr[i]) != xml->attr[i + 1]) continue;
712 while (*len + strlen(xml->attr[i]) + 7 > *max) // reallocate s
713 *s = realloc(*s, *max += EZXML_BUFSIZE);
714
715 *len += sprintf(*s + *len, " %s=\"", xml->attr[i]);
716 ezxml_ampencode(xml->attr[i + 1], -1, s, len, max, 1);
717 *len += sprintf(*s + *len, "\"");
718 }
719
720 for (i = 0; attr[i] && strcmp(attr[i][0], xml->name); i++);
721 for (j = 1; attr[i] && attr[i][j]; j += 3) { // default attributes
722 if (! attr[i][j + 1] || ezxml_attr(xml, attr[i][j]) != attr[i][j + 1])
723 continue; // skip duplicates and non-values
724 while (*len + strlen(attr[i][j]) + 7 > *max) // reallocate s
725 *s = realloc(*s, *max += EZXML_BUFSIZE);
726
727 *len += sprintf(*s + *len, " %s=\"", attr[i][j]);
728 ezxml_ampencode(attr[i][j + 1], -1, s, len, max, 1);
729 *len += sprintf(*s + *len, "\"");
730 }
731 *len += sprintf(*s + *len, ">");
732
733 *s = (xml->child) ? ezxml_toxml_r(xml->child, s, len, max, 0, attr) //child
734 : ezxml_ampencode(xml->txt, -1, s, len, max, 0); //data
735
736 while (*len + strlen(xml->name) + 4 > *max) // reallocate s
737 *s = realloc(*s, *max += EZXML_BUFSIZE);
738
739 *len += sprintf(*s + *len, "</%s>", xml->name); // close tag
740
741 while (txt[off] && off < xml->off) off++; // make sure off is within bounds
742 return (xml->ordered) ? ezxml_toxml_r(xml->ordered, s, len, max, off, attr)
743 : ezxml_ampencode(txt + off, -1, s, len, max, 0);
744 }
745
746 // Converts an ezxml structure back to xml. Returns a string of xml data that
747 // must be freed.
748 char *ezxml_toxml(ezxml_t xml)
749 {
750 ezxml_t p = (xml) ? xml->parent : NULL, o = (xml) ? xml->ordered : NULL;
751 ezxml_root_t root = (ezxml_root_t)xml;
752 size_t len = 0, max = EZXML_BUFSIZE;
753 char *s = strcpy(malloc(max), ""), *t, *n;
754 int i, j, k;
755
756 if (! xml || ! xml->name) return realloc(s, len + 1);
757 while (root->xml.parent) root = (ezxml_root_t)root->xml.parent; // root tag
758
759 for (i = 0; ! p && root->pi[i]; i++) { // pre-root processing instructions
760 for (k = 2; root->pi[i][k - 1]; k++);
761 for (j = 1; (n = root->pi[i][j]); j++) {
762 if (root->pi[i][k][j - 1] == '>') continue; // not pre-root
763 while (len + strlen(t = root->pi[i][0]) + strlen(n) + 7 > max)
764 s = realloc(s, max += EZXML_BUFSIZE);
765 len += sprintf(s + len, "<?%s%s%s?>\n", t, *n ? " " : "", n);
766 }
767 }
768
769 xml->parent = xml->ordered = NULL;
770 s = ezxml_toxml_r(xml, &s, &len, &max, 0, root->attr);
771 xml->parent = p;
772 xml->ordered = o;
773
774 for (i = 0; ! p && root->pi[i]; i++) { // post-root processing instructions
775 for (k = 2; root->pi[i][k - 1]; k++);
776 for (j = 1; (n = root->pi[i][j]); j++) {
777 if (root->pi[i][k][j - 1] == '<') continue; // not post-root
778 while (len + strlen(t = root->pi[i][0]) + strlen(n) + 7 > max)
779 s = realloc(s, max += EZXML_BUFSIZE);
780 len += sprintf(s + len, "\n<?%s%s%s?>", t, *n ? " " : "", n);
781 }
782 }
783 return realloc(s, len + 1);
784 }
785
786 // free the memory allocated for the ezxml structure
787 void ezxml_free(ezxml_t xml)
788 {
789 ezxml_root_t root = (ezxml_root_t)xml;
790 int i, j;
791 char **a, *s;
792
793 if (! xml) return;
794 ezxml_free(xml->child);
795 ezxml_free(xml->ordered);
796
797 if (! xml->parent) { // free root tag allocations
798 for (i = 10; root->ent[i]; i += 2) // 0 - 9 are default entites (<>&"')
799 if ((s = root->ent[i + 1]) < root->s || s > root->e) free(s);
800 free(root->ent); // free list of general entities
801
802 for (i = 0; (a = root->attr[i]); i++) {
803 for (j = 1; a[j++]; j += 2) // free malloced attribute values
804 if (a[j] && (a[j] < root->s || a[j] > root->e)) free(a[j]);
805 free(a);
806 }
807 if (root->attr[0]) free(root->attr); // free default attribute list
808
809 for (i = 0; root->pi[i]; i++) {
810 for (j = 1; root->pi[i][j]; j++);
811 free(root->pi[i][j + 1]);
812 free(root->pi[i]);
813 }
814 if (root->pi[0]) free(root->pi); // free processing instructions
815
816 if (root->len == -1) free(root->m); // malloced xml data
817 #ifndef EZXML_NOMMAP
818 else if (root->len) munmap(root->m, root->len); // mem mapped xml data
819 #endif // EZXML_NOMMAP
820 if (root->u) free(root->u); // utf8 conversion
821 }
822
823 ezxml_free_attr(xml->attr); // tag attributes
824 if ((xml->flags & EZXML_TXTM)) free(xml->txt); // character content
825 if ((xml->flags & EZXML_NAMEM)) free(xml->name); // tag name
826 free(xml);
827 }
828
829 // return parser error message or empty string if none
830 const char *ezxml_error(ezxml_t xml)
831 {
832 while (xml && xml->parent) xml = xml->parent; // find root tag
833 return (xml) ? ((ezxml_root_t)xml)->err : "";
834 }
835
836 // returns a new empty ezxml structure with the given root tag name
837 ezxml_t ezxml_new(const char *name)
838 {
839 static char *ent[] = { "lt;", "&#60;", "gt;", "&#62;", "quot;", "&#34;",
840 "apos;", "&#39;", "amp;", "&#38;", NULL };
841 ezxml_root_t root = (ezxml_root_t)memset(malloc(sizeof(struct ezxml_root)),
842 '\0', sizeof(struct ezxml_root));
843 root->xml.name = (char *)name;
844 root->cur = &root->xml;
845 strcpy(root->err, root->xml.txt = "");
846 root->ent = memcpy(malloc(sizeof(ent)), ent, sizeof(ent));
847 root->attr = root->pi = (char ***)(root->xml.attr = EZXML_NIL);
848 return &root->xml;
849 }
850
851 // inserts an existing tag into an ezxml structure
852 ezxml_t ezxml_insert(ezxml_t xml, ezxml_t dest, size_t off)
853 {
854 ezxml_t cur, prev, head;
855
856 xml->next = xml->sibling = xml->ordered = NULL;
857 xml->off = off;
858 xml->parent = dest;
859
860 if ((head = dest->child)) { // already have sub tags
861 if (head->off <= off) { // not first subtag
862 for (cur = head; cur->ordered && cur->ordered->off <= off;
863 cur = cur->ordered);
864 xml->ordered = cur->ordered;
865 cur->ordered = xml;
866 }
867 else { // first subtag
868 xml->ordered = head;
869 dest->child = xml;
870 }
871
872 for (cur = head, prev = NULL; cur && strcmp(cur->name, xml->name);
873 prev = cur, cur = cur->sibling); // find tag type
874 if (cur && cur->off <= off) { // not first of type
875 while (cur->next && cur->next->off <= off) cur = cur->next;
876 xml->next = cur->next;
877 cur->next = xml;
878 }
879 else { // first tag of this type
880 if (prev && cur) prev->sibling = cur->sibling; // remove old first
881 xml->next = cur; // old first tag is now next
882 for (cur = head, prev = NULL; cur && cur->off <= off;
883 prev = cur, cur = cur->sibling); // new sibling insert point
884 xml->sibling = cur;
885 if (prev) prev->sibling = xml;
886 }
887 }
888 else dest->child = xml; // only sub tag
889
890 return xml;
891 }
892
893 // Adds a child tag. off is the offset of the child tag relative to the start
894 // of the parent tag's character content. Returns the child tag.
895 ezxml_t ezxml_add_child(ezxml_t xml, const char *name, size_t off)
896 {
897 ezxml_t child;
898
899 if (! xml) return NULL;
900 child = (ezxml_t)memset(malloc(sizeof(struct ezxml)), '\0',
901 sizeof(struct ezxml));
902 child->name = (char *)name;
903 child->attr = EZXML_NIL;
904 child->txt = "";
905
906 return ezxml_insert(child, xml, off);
907 }
908
909 // sets the character content for the given tag and returns the tag
910 ezxml_t ezxml_set_txt(ezxml_t xml, const char *txt)
911 {
912 if (! xml) return NULL;
913 if (xml->flags & EZXML_TXTM) free(xml->txt); // existing txt was malloced
914 xml->flags &= ~EZXML_TXTM;
915 xml->txt = (char *)txt;
916 return xml;
917 }
918
919 // Sets the given tag attribute or adds a new attribute if not found. A value
920 // of NULL will remove the specified attribute. Returns the tag given.
921 ezxml_t ezxml_set_attr(ezxml_t xml, const char *name, const char *value)
922 {
923 int l = 0, c;
924
925 if (! xml) return NULL;
926 while (xml->attr[l] && strcmp(xml->attr[l], name)) l += 2;
927 if (! xml->attr[l]) { // not found, add as new attribute
928 if (! value) return xml; // nothing to do
929 if (xml->attr == EZXML_NIL) { // first attribute
930 xml->attr = malloc(4 * sizeof(char *));
931 xml->attr[1] = strdup(""); // empty list of malloced names/vals
932 }
933 else xml->attr = realloc(xml->attr, (l + 4) * sizeof(char *));
934
935 xml->attr[l] = (char *)name; // set attribute name
936 xml->attr[l + 2] = NULL; // null terminate attribute list
937 xml->attr[l + 3] = realloc(xml->attr[l + 1],
938 (c = strlen(xml->attr[l + 1])) + 2);
939 strcpy(xml->attr[l + 3] + c, " "); // set name/value as not malloced
940 if (xml->flags & EZXML_DUP) xml->attr[l + 3][c] = EZXML_NAMEM;
941 }
942 else if (xml->flags & EZXML_DUP) free((char *)name); // name was strduped
943
944 for (c = l; xml->attr[c]; c += 2); // find end of attribute list
945 if (xml->attr[c + 1][l / 2] & EZXML_TXTM) free(xml->attr[l + 1]); //old val
946 if (xml->flags & EZXML_DUP) xml->attr[c + 1][l / 2] |= EZXML_TXTM;
947 else xml->attr[c + 1][l / 2] &= ~EZXML_TXTM;
948
949 if (value) xml->attr[l + 1] = (char *)value; // set attribute value
950 else { // remove attribute
951 if (xml->attr[c + 1][l / 2] & EZXML_NAMEM) free(xml->attr[l]);
952 memmove(xml->attr + l, xml->attr + l + 2, (c - l + 2) * sizeof(char*));
953 xml->attr = realloc(xml->attr, (c + 2) * sizeof(char *));
954 memmove(xml->attr[c + 1] + (l / 2), xml->attr[c + 1] + (l / 2) + 1,
955 (c / 2) - (l / 2)); // fix list of which name/vals are malloced
956 }
957 xml->flags &= ~EZXML_DUP; // clear strdup() flag
958 return xml;
959 }
960
961 // sets a flag for the given tag and returns the tag
962 ezxml_t ezxml_set_flag(ezxml_t xml, short flag)
963 {
964 if (xml) xml->flags |= flag;
965 return xml;
966 }
967
968 // removes a tag along with its subtags without freeing its memory
969 ezxml_t ezxml_cut(ezxml_t xml)
970 {
971 ezxml_t cur;
972
973 if (! xml) return NULL; // nothing to do
974 if (xml->next) xml->next->sibling = xml->sibling; // patch sibling list
975
976 if (xml->parent) { // not root tag
977 cur = xml->parent->child; // find head of subtag list
978 if (cur == xml) xml->parent->child = xml->ordered; // first subtag
979 else { // not first subtag
980 while (cur->ordered != xml) cur = cur->ordered;
981 cur->ordered = cur->ordered->ordered; // patch ordered list
982
983 cur = xml->parent->child; // go back to head of subtag list
984 if (strcmp(cur->name, xml->name)) { // not in first sibling list
985 while (strcmp(cur->sibling->name, xml->name))
986 cur = cur->sibling;
987 if (cur->sibling == xml) { // first of a sibling list
988 cur->sibling = (xml->next) ? xml->next
989 : cur->sibling->sibling;
990 }
991 else cur = cur->sibling; // not first of a sibling list
992 }
993
994 while (cur->next && cur->next != xml) cur = cur->next;
995 if (cur->next) cur->next = cur->next->next; // patch next list
996 }
997 }
998 xml->ordered = xml->sibling = xml->next = NULL;
999 return xml;
1000 }
1001
1002 #ifdef EZXML_TEST // test harness
1003 int main(int argc, char **argv)
1004 {
1005 ezxml_t xml;
1006 char *s;
1007 int i;
1008
1009 if (argc != 2) return fprintf(stderr, "usage: %s xmlfile\n", argv[0]);
1010
1011 xml = ezxml_parse_file(argv[1]);
1012 printf("%s\n", (s = ezxml_toxml(xml)));
1013 free(s);
1014 i = fprintf(stderr, "%s", ezxml_error(xml));
1015 ezxml_free(xml);
1016 return (i) ? 1 : 0;
1017 }
1018 #endif // EZXML_TEST
