root/radiance/ray/src/common/ezxml.c
Sun Mar 6 01:13:17 2016 UTC (9 years, 2 months ago) by schorsch
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.8: +6 -7 lines
Thu Apr 2 16:40:32 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.7: +9 -1 lines
Support for color BSDF rendering using Klems representation
Sat Feb 14 00:34:43 2015 UTC (10 years, 3 months ago) by greg
Changes since 2.6: +19 -1 lines
Created ezxml_add_txt() call
Sun Oct 26 17:35:53 2014 UTC (10 years, 7 months ago) by greg
CVS Tags: rad4R2P2
Changes since 2.5: +4 -3 lines
Sat Feb 25 01:15:02 2012 UTC (13 years, 3 months ago) by greg
CVS Tags: rad4R2, rad4R2P1
Changes since 2.4: +11 -7 lines
Fixed long loop for DOS source files
Sat Jun 11 01:04:08 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.3: +2 -3 lines
Removed problematic reference to snprintf()
Thu Jun 9 17:09:39 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.2: +9 -1 lines
Fixes for Windows and bug fix in bsdf_m.c
Wed Jun 1 00:29:40 2011 UTC (14 years ago) by greg
Changes since 2.1: +280 -280 lines
Diff to previous 2.1
Wed Jun 17 20:41:47 2009 UTC (15 years, 11 months ago) by greg
