root/Development/ray/src/common/error.c
Sun Jul 27 22:12:01 2003 UTC (22 years, 5 months ago) by schorsch
CVS Tags: rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Diff to previous 2.9 , to selected 1.1
Thu Jul 17 09:21:29 2003 UTC (22 years, 5 months ago) by schorsch
Diff to previous 2.8 , to selected 1.1
Fri Jun 27 06:53:21 2003 UTC (22 years, 6 months ago) by greg
Changes since 2.7: +4 -2 lines
Diff to previous 2.7 , to selected 1.1
Tue Feb 25 02:47:21 2003 UTC (22 years, 10 months ago) by greg
Diff to previous 2.6 , to selected 1.1
Sat Feb 22 02:07:22 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.5: +63 -12 lines
Diff to previous 2.5 , to selected 1.1
Tue Dec 2 15:54:44 1997 UTC (28 years ago) by gregl
Diff to previous 2.4 , to selected 1.1
avoid calls to output empty strings
Tue Nov 11 19:02:15 1997 UTC (28 years, 1 month ago) by gregl
Changes since 2.3: +19 -33 lines
Diff to previous 2.3 , to selected 1.1
Wed May 28 17:23:31 1997 UTC (28 years, 7 months ago) by gregl
Diff to previous 2.2 , to selected 1.1
fix for Alpha Linux
Fri Apr 5 15:48:18 1996 UTC (29 years, 8 months ago) by greg
Diff to previous 2.1 , to selected 1.1
increased size of global errmsg buffer
Tue Nov 12 16:56:00 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1
Revision 1.1 - (view) (download) (annotate) - [selected]
Fri Jul 19 13:34:32 1991 UTC (34 years, 5 months ago) by greg
