root/radiance/ray/src/common/error.c
Sun Jul 27 22:12:01 2003 UTC (21 years, 2 months ago) by schorsch
CVS Tags: rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Thu Jul 17 09:21:29 2003 UTC (21 years, 2 months ago) by schorsch
Fri Jun 27 06:53:21 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.7: +4 -2 lines
Tue Feb 25 02:47:21 2003 UTC (21 years, 7 months ago) by greg
Sat Feb 22 02:07:22 2003 UTC (21 years, 7 months ago) by greg
Changes since 2.5: +63 -12 lines
Tue Dec 2 15:54:44 1997 UTC (26 years, 9 months ago) by gregl
avoid calls to output empty strings
Tue Nov 11 19:02:15 1997 UTC (26 years, 10 months ago) by gregl
Changes since 2.3: +19 -33 lines
Wed May 28 17:23:31 1997 UTC (27 years, 4 months ago) by gregl
fix for Alpha Linux
Fri Apr 5 15:48:18 1996 UTC (28 years, 5 months ago) by greg
increased size of global errmsg buffer
Tue Nov 12 16:56:00 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1 , to selected 2.6
Fri Jul 19 13:34:32 1991 UTC (33 years, 2 months ago) by greg
Diff to selected 2.6
