--- ray/src/common/ealloc.c 2003/07/17 09:21:29 2.5 +++ ray/src/common/ealloc.c 2003/10/27 10:19:31 2.7 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ealloc.c,v 2.5 2003/07/17 09:21:29 schorsch Exp $"; +static const char RCSid[] = "$Id: ealloc.c,v 2.7 2003/10/27 10:19:31 schorsch Exp $"; #endif /* * ealloc.c - memory routines which call quit on error. @@ -13,9 +13,8 @@ static const char RCSid[] = "$Id: ealloc.c,v 2.5 2003/ #include "rterror.h" -char * -emalloc(n) /* return pointer to n uninitialized bytes */ -unsigned int n; +extern char * /* return pointer to n uninitialized bytes */ +emalloc(unsigned int n) { register char *cp; @@ -30,10 +29,8 @@ unsigned int n; } -char * -ecalloc(ne, es) /* return pointer to initialized memory */ -register unsigned int ne; -unsigned int es; +extern char * /* return pointer to initialized memory */ +ecalloc(register unsigned int ne, unsigned int es) { register char *cp; @@ -52,10 +49,8 @@ unsigned int es; } -char * -erealloc(cp, n) /* reallocate cp to size n */ -register char *cp; -unsigned int n; +extern char * /* reallocate cp to size n */ +erealloc(register char *cp, unsigned int n) { if (n == 0) { if (cp != NULL) @@ -76,9 +71,8 @@ unsigned int n; } -void -efree(cp) /* free memory allocated by above */ -char *cp; +extern void /* free memory allocated by above */ +efree(char *cp) { free((void *)cp); }
