1 |
2 |
* dmessage.h |
3 |
* panlib |
4 |
5 |
* Depends on <stdio.h> |
6 |
7 |
* Debug and error message logging and recovery. |
8 |
9 |
* Created by gward on Thu May 10 2001. |
10 |
* Modified by plonghurst on Thursday Feb 15 2007. |
11 |
* Copyright (c) 2001 Anyhere Software. All rights reserved. |
12 |
13 |
14 |
15 |
#ifndef _DMESSAGE_H_ |
16 |
#define _DMESSAGE_H_ |
17 |
18 |
#ifdef __cplusplus |
19 |
extern "C" { |
20 |
#endif |
21 |
22 |
23 |
* Type Definitions * |
24 |
25 |
26 |
27 |
* Debug message classes |
28 |
29 |
* If you are unsure what class to report, guess on the high side, which |
30 |
* is less serious. For example, report an error like DMCdata even |
31 |
* when you think it's DMCsystem, unless you really know. |
32 |
* That way, more serious errors will be recorded from higher in the call |
33 |
* tree. The vast majority of errors fall into the DMCdata class. |
34 |
35 |
typedef enum { |
36 |
DMCassert, /* assertion failure */ |
37 |
DMCmemory, /* out of memory */ |
38 |
DMCsystem, /* system error */ |
39 |
DMCparameter, /* program parameter error */ |
40 |
DMCresource, /* file/resource unavailable */ |
41 |
DMCdata, /* data error */ |
42 |
DMCinput, /* input error */ |
43 |
DMCwarning, /* warning message */ |
44 |
DMCinfo, /* informative output */ |
45 |
DMCtrace, /* trace point */ |
46 |
DMCnerr /* no error (terminator) */ |
47 |
} DMsgClass; |
48 |
49 |
50 |
* Message flags: record, write to logfile, send to stderr, |
51 |
* alert user, exit program, abort |
52 |
53 |
typedef enum { |
54 |
DMFrecord=01, DMFlog=02, DMFstderr=04, |
55 |
DMFalert=010, DMFexit=020, DMFabort=040 |
56 |
} DMsgFlag; |
57 |
58 |
59 |
* Functions and Macros * |
60 |
61 |
62 |
63 |
* int |
64 |
* dmessage(int cls, const char *msg, const char *file, int line); |
65 |
66 |
* Basic call interface to debug message handler. The file name |
67 |
* and line number are generally taken from the ANSI-C __FILE__ |
68 |
* and __LINE__ predefined macros. The message class are taken |
69 |
* from the list above, and the message should not contain newlines. |
70 |
* All DMsgClass classes except DMCassert are recoverable and |
71 |
* dmessage() will return. The return value is an or'ing of |
72 |
* DMsgFlags according to what was done. |
73 |
74 |
75 |
extern int dmessage(DMsgClass cls, const char *msg, |
76 |
const char *file = NULL, int line = 0); |
77 |
#else |
78 |
79 |
80 |
#endif |
81 |
82 |
83 |
* int |
84 |
* DMESG(int cls, const char *msg) |
85 |
86 |
* Basic macro call for message reporting. What actually happens to |
87 |
* the message depends on the current settings, controlled by |
88 |
* global variables described in the next section. |
89 |
90 |
#define DMESG(cls, msg) dmessage(cls, msg, __FILE__, __LINE__) |
91 |
92 |
93 |
* int |
94 |
* DTEST(int cnd, int cls, const char *msg) |
95 |
96 |
* Conditional call to DMESG() for convenience. Zero is returned if |
97 |
* the condition (cnd) evaluates to zero, and a collection of DMsgFlags |
98 |
* saying what was done if the condition evaluates to non-zero. |
99 |
100 |
#define DTEST(cnd, cls, msg) ((cnd) ? DMESG(cls, msg) : 0) |
101 |
102 |
103 |
* int |
104 |
* DMESGF(int cls, const char *fmt, va_list..) |
105 |
106 |
* Formatting version of DMESG() takes printf(3) format string |
107 |
* and a variable argument list to format the message. |
108 |
109 |
#define DMESGF(cls, fmt, val) (sprintf(dmessage_buf, fmt, val), \ |
110 |
DMESG(cls, dmessage_buf)) |
111 |
112 |
113 |
* int |
114 |
* DTESTF(int cnd, DMsgClass cls, const char *fmt, va_list..) |
115 |
116 |
* Formatting version of DTEST() takes printf(3) format string |
117 |
* and a variable argument list to format the message, but only |
118 |
* if the condition (cnd) evaluates to non-zero. |
119 |
120 |
#define DTESTF(cnd, cls, fmt, val) \ |
121 |
((cnd) ? DMESGF(cls, fmt, val) : 0) |
122 |
123 |
124 |
* int |
125 |
* DRESET() |
126 |
127 |
* Reset last error message class. Call before potential error- |
128 |
* producing subroutine, then call DMESC() or DMESCF() afterwards. |
129 |
130 |
#define DRESET() (dmessage_last_class = DMCnerr) |
131 |
132 |
133 |
* int |
134 |
* DMESC(int cls, const char *msg) |
135 |
136 |
* Report only if this error is a higher priority than any since |
137 |
* DRESET() was last called. |
138 |
139 |
#define DMESC(cls, msg) DTEST((cls) < dmessage_last_class, \ |
140 |
cls, msg) |
141 |
142 |
143 |
* int |
144 |
* DMESCF(int cls, const char *fmt, va_list..) |
145 |
146 |
* Formatting version of DMESC() takes printf(3) format string, but |
147 |
* only reports if this error is higher priority than any since |
148 |
149 |
150 |
#define DMESCF(cls, fmt, val) DTESTF((cls) < dmessage_last_class, \ |
151 |
cls, fmt, val) |
152 |
153 |
154 |
* void |
155 |
* DASSERT(int cnd) |
156 |
157 |
* Replacement for assert() macro; calls DTEST() with DMCassert class |
158 |
* if asc yeilds 0. If NDEBUG is defined, the macro becomes a no-op. |
159 |
160 |
#ifdef NDEBUG |
161 |
#define DASSERT(asc) ((void)0) |
162 |
#else |
163 |
#if defined(__STDC__) || defined(__cplusplus) |
164 |
#define DASSERT(asc) ((void)DTESTF(!(asc), DMCassert, \ |
165 |
"assertion failed ! (%s)", #asc)) |
166 |
#else |
167 |
168 |
"assertion failed ! (%s)", "asc")) |
169 |
#endif |
170 |
#endif |
171 |
172 |
173 |
* Global Variabless * |
174 |
175 |
176 |
177 |
* char dmessage_buf[DM_BUF_LEN] |
178 |
179 |
* Buffer to hold formatted message contents temporarily. |
180 |
181 |
#define DM_BUF_LEN 1024 |
182 |
183 |
extern char dmessage_buf[DM_BUF_LEN]; |
184 |
185 |
186 |
* const char * dmessage_class_name[] |
187 |
188 |
* The name of each of class in DMsgClass. |
189 |
190 |
extern const char * dmessage_class_name[]; |
191 |
192 |
193 |
* int dmessage_class_flags[] |
194 |
195 |
* Flags indicating what to do with each message class. By default, |
196 |
* the most recent message will be stored in the dmessage_last[] array |
197 |
* (DMFrecord), but if other flags are set, the message will be sent |
198 |
* other places as well. These flags are available to be altered by the |
199 |
* controlling application, and will not be changed from their initial |
200 |
* defaults (DMFrecord at minimum) by any of the dmessage routines. |
201 |
* Beware: if the DMrecord flag is turned off for a given class and |
202 |
* dmessage() fails to do anything, it will return zero and |
203 |
* the DTEST() and DTESTF() macro calls may return zero even |
204 |
* though their condition evaluated to non-zero. This problem is |
205 |
* avoided by keeping DMrecord set for all classes. |
206 |
207 |
extern int dmessage_class_flags[]; |
208 |
209 |
210 |
* int dmessage_class_done[] |
211 |
212 |
* Flags indicating what was last done with each message class. |
213 |
* In other words, the last result of dmessage() for each class. |
214 |
215 |
extern int dmessage_class_done[]; |
216 |
217 |
218 |
* const char * dmessage_file[] |
219 |
220 |
* Most recent file reported for each error class. |
221 |
222 |
extern const char * dmessage_file[]; |
223 |
224 |
225 |
* int dmessage_line[] |
226 |
227 |
* Most recent line number reported for each error class. |
228 |
229 |
extern int dmessage_line[]; |
230 |
231 |
232 |
* const char * dmessage_record[] |
233 |
234 |
* Most recent message for each class with the DMFrecord flag set, |
235 |
* exactly as passed to dmessage(). If no message of |
236 |
* a given class has been reported, then the corresponding |
237 |
* dmessage_record pointer will be NULL. |
238 |
239 |
extern const char * dmessage_record[]; |
240 |
241 |
242 |
* int dmessage_last_class |
243 |
244 |
* The lowest class message reported so far, set to DMCnerr initially. |
245 |
* The DMESG_LAST macro provides convenient access to most recent error. |
246 |
247 |
extern DMsgClass dmessage_last_class; |
248 |
249 |
#define DMESG_LAST (dmessage_record[dmessage_last_class]) |
250 |
251 |
252 |
* FILE * dmessage_logfp |
253 |
254 |
* Pointer to open log file. Each message is preceeded by the file |
255 |
* name, line number, and class for log file and stderr output. Data |
256 |
* is flushed after each message. If this pointer is NULL (the default), |
257 |
* then logging is disabled even for classes with the DMFlog flag set. |
258 |
259 |
extern FILE * dmessage_logfp; |
260 |
261 |
262 |
* int (*dmessage_call)(DMsgClass cls, const char *msg, |
263 |
* const char *file, int line) |
264 |
265 |
* Pointer to function called by dmessage() to share error handling. |
266 |
* If assigned, this function is called with the same arguments passed |
267 |
* to dmessage(), independent of the class flag settings. The returned |
268 |
* value is then used as a mask on the class flags to turn off some or |
269 |
* all of the default actions. The flagged actions are considered |
270 |
* "done" and set accordingly in the dmessage_class_done global. |
271 |
* Defaults to NULL. |
272 |
273 |
extern int (*dmessage_call)(DMsgClass cls, const char *msg, |
274 |
275 |
276 |
277 |
* int (*dmessage_alert)(const char *msg) |
278 |
279 |
* Pointer to function called by dmessage() to alert user. |
280 |
* The function should return non-zero if the user was notified, |
281 |
* or zero if the message could not be displayed for some reason. |
282 |
* Defaults to NULL, which results in no DMFalert action. |
283 |
284 |
extern int (*dmessage_alert)(const char *msg); |
285 |
286 |
287 |
* void (*dmessage_exit)(int status) |
288 |
289 |
* Pointer to function called by dmessage() for classes with the |
290 |
* DMFexit flag set, which is usually reserved for the DMCmemory class. |
291 |
* Defaults to system exit() function, but may be reassigned by the |
292 |
* controlling application. Assigning a value of NULL causes dmessage() |
293 |
* to return from these calls, which might result in a memory fault if |
294 |
* your program does not check for NULL pointer values. In general, |
295 |
* library authors should NOT assume the DMCmemory class calls exit(). |
296 |
297 |
extern void (*dmessage_exit)(int status); |
298 |
299 |
300 |
* void (*dmessage_abort)() |
301 |
302 |
303 |
* DMFabort flag set, which is usually reserved for the DMCassert class. |
304 |
* Defaults to system abort() function, but may be reassigned by the |
305 |
306 |
* to return from these calls, which will probably prove disasterous. |
307 |
* A better idea if the program wants to continue is to use setjmp() and |
308 |
* longjmp() to recover control at a lower point in the call tree. If |
309 |
* assigned, this call should never return. |
310 |
311 |
extern void (*dmessage_abort)(); |
312 |
313 |
314 |
315 |
#endif |
316 |
317 |
#endif /* ! _DMESSAGE_H_ */ |
