root/Development/ray/src/common/disk2square.c
Revision: 3.6
Committed: Wed Dec 15 01:39:52 2021 UTC (3 years, 11 months ago) by greg
CVS Tags: rad6R0, rad5R4, HEAD
Changes since 3.5: +2 -1 lines
fix: added #include needed from last change
# User Rev Content
1 greg 3.2 #ifndef lint
2 greg 3.6 static const char RCSid[] = "$Id: disk2square.c,v 3.5 2021/12/15 01:38:50 greg Exp $";
3 greg 3.2 #endif
4 greg 3.1 /*
5     * Disk2Square.c
6     *
7     * Code by Peter Shirley and Kenneth Chiu
8     *
9     * Associated paper in ~/Documents/Others/Shirley+Chiu_JGT-97.pdf
10     *
11     * Modified interface slightly (G. Ward)
12     */
13
14 greg 3.3 #define _USE_MATH_DEFINES
15 greg 3.1 #include <math.h>
16 greg 3.6 #include "fvect.h"
17 greg 3.1
18     /*
19     This transforms points on [0,1]^2 to points on unit disk centered at
20     origin. Each "pie-slice" quadrant of square is handled as a seperate
21     case. The bad floating point cases are all handled appropriately.
22     The regions for (a,b) are:
23
24     phi = pi/2
25     -----*-----
26     |\ /|
27     | \ 2 / |
28     | \ / |
29     phi=pi* 3 * 1 *phi = 0
30     | / \ |
31     | / 4 \ |
32     |/ \|
33     -----*-----
34     phi = 3pi/2
35
36     change log:
37     26 feb 2004. bug fix in computation of phi (now this matches the paper,
38     which is correct). thanks to Atilim Cetin for catching this.
39     */
40
41
42     /* Map a [0,1]^2 square to a unit radius disk */
43     void
44 greg 3.5 square2disk(RREAL ds[2], double seedx, double seedy)
45 greg 3.1 {
46
47     double phi, r;
48     double a = 2.*seedx - 1; /* (a,b) is now on [-1,1]^2 */
49     double b = 2.*seedy - 1;
50
51     if (a > -b) { /* region 1 or 2 */
52     if (a > b) { /* region 1, also |a| > |b| */
53     r = a;
54     phi = (M_PI/4.) * (b/a);
55     }
56     else { /* region 2, also |b| > |a| */
57     r = b;
58     phi = (M_PI/4.) * (2. - (a/b));
59     }
60     }
61     else { /* region 3 or 4 */
62     if (a < b) { /* region 3, also |a| >= |b|, a != 0 */
63     r = -a;
64     phi = (M_PI/4.) * (4. + (b/a));
65     }
66     else { /* region 4, |b| >= |a|, but a==0 and b==0 could occur. */
67     r = -b;
68     if (b != 0.)
69     phi = (M_PI/4.) * (6. - (a/b));
70     else
71     phi = 0.;
72     }
73     }
74 greg 3.4 r *= 0.9999999999999; /* prophylactic against MS sin()/cos() impl. */
75 greg 3.1 ds[0] = r * cos(phi);
76     ds[1] = r * sin(phi);
77
78     }
79
80     /* Map point on unit disk to a unit square in [0,1]^2 range */
81     void
82 greg 3.5 disk2square(RREAL sq[2], double diskx, double disky)
83 greg 3.1 {
84     double r = sqrt( diskx*diskx + disky*disky );
85     double phi = atan2( disky, diskx );
86     double a, b;
87
88     if (phi < -M_PI/4) phi += 2*M_PI; /* in range [-pi/4,7pi/4] */
89     if ( phi < M_PI/4) { /* region 1 */
90     a = r;
91     b = phi * a / (M_PI/4);
92     }
93     else if ( phi < 3*M_PI/4 ) { /* region 2 */
94     b = r;
95     a = -(phi - M_PI/2) * b / (M_PI/4);
96     }
97     else if ( phi < 5*M_PI/4 ) { /* region 3 */
98     a = -r;
99     b = (phi - M_PI) * a / (M_PI/4);
100     }
101     else { /* region 4 */
102     b = -r;
103     a = -(phi - 3*M_PI/2) * b / (M_PI/4);
104     }
105
106 greg 3.4 sq[0] = a*(0.5/0.9999999999999) + 0.5;
107     sq[1] = b*(0.5/0.9999999999999) + 0.5;
108 greg 3.1 }
